JamesPi123
Auto poweroff when power bank low?
Mon Apr 24, 2017 5:48 am
Is it possible to use a USB power bank and have the Raspberry Pi automatically (cleanly) shutdown when the power bank's level is critically low?
drgeoff
Re: Auto poweroff when power bank low?
Mon Apr 24, 2017 7:48 am
Short answer. No.
Long answer. There is a DC to DC converter between the cell in the powerbank and the output to the RPi. Without opening the powerpack you cannot access the cell terminals to determine the cell's voltage. And even if you did, an unaided RPi cannot measure voltages. You need to add extra circuitry. So yes it is possible but far from being trivial.
tpylkko
Mon Apr 24, 2017 9:14 pm
and then there is also a whole bunch of workarounds for this problem and vendors at various pi-selling shops that sell specialized hardware to do ready-made.
xamal
Tue Apr 25, 2017 2:22 pm
It depends if you can/want to access to electronic components of the power bank. If you could, the simplest solution would be a voltage divisor (just two resistances) from the battery to a GPIO.
You have a lot of comercial solutions like:
https://shop.pimoroni.com/products/zero-lipo
or
https://www.kickstarter.com/projects/xa ... spberry-pi
(yes, this is mine)
drgeoff
Tue Apr 25, 2017 4:02 pm
xamal wrote:It depends if you can/want to access to electronic components of the power bank. If you could, the simplest solution would be a voltage divisor (just two resistances) from the battery to a GPIO.
It might be the simplest but it would not be reliable. The threshold voltage of a GPIO input is not well defined nor stable eg variation with temperature.
RidingTheFlow
Tue Apr 25, 2017 9:46 pm
Photosensor on the power bank indicator LED is easiest, reliable and requires no internal bank tinkering.
You either need to detect that "low charge" lights up or that "second to first" goes out (in case of bar-like charge indicator).
elkberry
Wed Apr 26, 2017 9:03 pm
In true RPi Foundation style, we should probably add a RPi cam module, and then run some cv app that analyzes the pictures of the power bar status LEDs, shutting itself down when the last LED starts blinking... :mrgreen:
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
Return to “Advanced users”
