underwhelmd
Re: Moving Linux kernel to 4.9
Tue Apr 11, 2017 1:33 pm
gordon@drogon.net wrote:
Maybe spending a few moments reading the rest of this thread would be a good thing
I follow this thread. Been running the 4.9 kernel for some time now on two of five Pi here for the purposes of helping the testing along.
No need to be rude. I've been using Linux for business and personal use for over 20 years. The question i posted was valid because I haven't come across the problem before.
Tue Apr 11, 2017 1:56 pm
bensimmo wrote:Thanks Dougie, but I was meaning, you add an entry into the apt sources yourself, (or it there and you just uncommented). At which point apt switches to that, a bit like people wanting to run or test squeeze or sid, but a specific Raspian testing source.
I like the way it works now. I just think the RPF folks should remove rpi-update so that folks have to positively do something (and hopefully think about it) to get rpi-update running. Then apt-get install rpi-update can give them the details of why they really won't want to run rpi-update.
Two of my Raspberries are already running Raspbian Squeeze - which really isn't ready for the mainstream yet.
This is a doctor free zone.
rpdom
Tue Apr 11, 2017 6:58 pm
DougieLawson wrote:Two of my Raspberries are already running Raspbian Squeeze - which really isn't ready for the mainstream yet.
How is Raspbian 6.0? :lol:
I think you mean Raspbian Stretch. :-)
bensimmo
Tue Apr 11, 2017 7:06 pm
I think that's my fault :lol:
Tue Apr 11, 2017 8:33 pm
It's running some sort of Stretchy Squeezy thing that isn't Jessie.
cjan
Tue Apr 11, 2017 10:33 pm
how to disable 4.4 upgrade?
DirkS
Tue Apr 11, 2017 10:40 pm
cjan wrote:how to disable 4.4 upgrade?
I think
sudo apt-mark hold raspberrypi-bootloader raspberrypi-kernel
should do it.
tpylkko
Thu Apr 13, 2017 5:20 am
DougieLawson wrote: I like the way it works now. I just think the RPF folks should remove rpi-update so that folks have to positively do something (and hopefully think about it) to get rpi-update running. Then apt-get install rpi-update can give them the details of why they really won't want to run rpi-update.
In case you remember, just recently I screwed up a remote Raspbian upgrade when it was shut down in midst. Then you suggested using rpi-update, as that easily makes sure that all the bootloader, kernel and libs are the correct versions. When I did that I noticed that on my Raspbian there was no rpi-update, I had to install it first. I believe that in the past it was a part of the default install...
Thu Apr 13, 2017 5:01 pm
It's definitely still included with Full Raspbian 2017-04-10. It is not part of Raspbian Lite 2017-04-10.
runboy93
Tue Apr 18, 2017 3:29 am
Anyone using 4.9.xx? Or latest 4.9.22?
MaxK1
Tue Apr 18, 2017 3:31 am
Yes.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
runboy93
Tue Apr 18, 2017 3:37 am
MaxK1 wrote:Yes.
Stable enough or keep crashing?
MaxK1
Tue Apr 18, 2017 3:42 am
Too soon to tell. I've only had the latest up for a few hours...
MaxK1
Tue Apr 18, 2017 8:08 am
@runboy93 - I've had it (4.9.22) running on 2 of my 3 Pi 3's for about 24 hours, nothing unusual. I haven't really poked at it with a stick to see if there are any tender areas, though. Are you experiencing some kind of instability or just asking?
bensimmo
Fri Apr 28, 2017 10:42 am
This just came down over apt (normal setup).
Should it have?
PhilE
Fri Apr 28, 2017 10:43 am
Yes, we updated the stable branch and rebuilt the raspberrypi-kernel package yesterday.
bensimmo
Fri Apr 28, 2017 11:08 am
Fri Apr 28, 2017 11:51 am
PhilE wrote:Yes, we updated the stable branch and rebuilt the raspberrypi-kernel package yesterday.
:D :D
uname -a
Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
Retired disgracefully.....
bensimmo
Fri Apr 28, 2017 12:11 pm
Quick question, since I though I had better read the opening thread properly now.
How long is Long Term Support classed as?
Not that it matters to me.
PhilE
Fri Apr 28, 2017 12:17 pm
From https://www.phoronix.com/scan.php?page= ... LTS-Kernel:
Linux 4.9 LTS is expected to be maintained until January of 2019.
The rule seems to be two years from the first full release. However, we are likely to upgrade our stable kernel long before then.
jahboater
Fri Apr 28, 2017 12:25 pm
Running fine on Pi0, Pi0W, Pi2, Pi3, all good as far as I can see.
Thanks to the RPF engineers for this!
Fri Apr 28, 2017 12:30 pm
bensimmo wrote:Quick question, since I though I had better read the opening thread properly now.
https://en.wikipedia.org/wiki/Linux_kernel#Maintenance
Gavinmc42
Sat Apr 29, 2017 1:55 pm
Just been trying to update/upgrade the download version 4.4.50 Jessie Lite.
This will be my third attempt on a third card.
Getting a screen full of "Adding 'diversion of /boot/over...... previous cards failed after this.
Takes a long time to upgrade and is not always successful.
Third time is the charm, now have 4.9.24.
Time to put a copy of 4.9.x in the Downloads?
Been doing progressive updates till now, but rolling out some new Pi's from scratch.
I'm dancing on Rainbows.
bensimmo
Sat Apr 29, 2017 6:59 pm
Gavinmc42 wrote:Just been trying to update/upgrade the download version 4.4.50 Jessie Lite.
No wait till we regular updaters find the problems first and bring out a later May 4.9 release with whatever new stuff is needed/found.
Anyway, let them have the nice long weekend holiday.
Gavinmc42
Sun Apr 30, 2017 12:26 am
But that's when I do my stuff :(
Guess I will have to make an image of my only working latest Jessie Lite.
sudo dd.........
Return to “Advanced users”
