Rtorrent Tracker: [Couldn't connect to server]
Posted: Wed Nov 16, 2016 10:16 pm
by valver
Dear all,
I have a problem witch rtorrent.
I tried with some torrent.
If i download the same torrent in uTorrent (windows another Pc) it is normaly download but when i tried download this torrent rtorrent show:
and
Tracker: [Unable to connect to UDP tracker.]
But nevertheless rtorrent download correctly raspian.iso , debian.iso and another linux images
Tracker list info show:
Trackers: [Key: 54239b81] [             ]
                  0: http://www.spanishtracker.com:2710/announce
                    Id:  Counters: 19f / 0s (0)  on S/L/D: 0/0/0 (0/0)
Info            1: dht://
                    Id:  Counters: 0f / 0s (0) err S/L/D: 0/0/0 (0/0)
My .rtorrent.rc show:
# This is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
min_peers = 1
max_peers = 50
# Same as above but for seeding completed torrents (-1 = same as downloading)
#min_peers_seed = 10
#max_peers_seed = 50
# Maximum number of simultanious uploads per torrent.
max_uploads = 10
# Maximo nĂºmero de download simultanious
max_downloads_global = 3
# Global upload and download rate in KiB. "0" for unlimited.
download_rate = 0
upload_rate = 150
# Default directory to save the downloaded torrents.
directory = /home/pi/Downloads/torrents
# Default session directory. Make sure you don't run multiple instance
# of rtorrent using the same session directory. Perhaps using a
# relative path?
session = /home/pi/Downloads/torrents/sesion
# Watch a directory for new torrents, and stop those that have been
#deleted.
schedule = watch_directory,5,5,load_start=/home/pi/Downloads/torrents/*.torrent
#schedule = untied_directory,5,5,stop_untied=
# Close torrents when diskspace is low.
#schedule = low_diskspace,5,60,close_low_diskspace=100M
# Stop torrents when reaching upload ratio in percent,
# when also reaching total upload in bytes, or when
# reaching final upload ratio in percent.
# example: stop at ratio 2.0 with at least 200 MB uploaded, or else ratio 20.0
#schedule = ratio,60,60,"stop_on_ratio=200,200M,2000"
# The ip address reported to the tracker.
#ip = 127.0.0.1
#ip = rakshasa.no
# The ip address the listening socket and outgoing connections is
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
# Port range to use for listening.
port_range = 17420-17420 #same port uTorrent(windows)
# Start opening ports at a random position within the port range.
port_random = no
# Check hash for finished torrents. Might be usefull until the bug is
# fixed that causes lack of diskspace not to be properly reported.
check_hash = no
# Set whetever the client should try to connect to UDP trackers.
use_udp_trackers = yes
# Alternative calls to bind and ip that should handle dynamic ip's.
#schedule = ip_tick,0,1800,ip=rakshasa
#schedule = bind_tick,0,1800,bind=rakshasa
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
# encryption = allow_incoming,enable_retry,prefer_plaintext
# Enable DHT support for trackerless torrents or when all trackers are down.
# May be set to "disable" (completely disable DHT), "off" (do not start DHT),
# "auto" (start and stop DHT as needed), or "on" (start DHT immediately).
# The default is "off". For DHT to work, a session directory must be defined.
dht = auto
# UDP port to use for DHT.
# dht_port = 7881
# Enable peer exchange (for torrents not marked private)
 peer_exchange = yes
# Do not modify the following parameters unless you know what you're doing.
# Hash read-ahead controls how many MB to request the kernel to read
# ahead. If the value is too low the disk may not be fully utilized,
# while if too high the kernel might not be able to keep the read
# pages in memory thus end up trashing.
#hash_read_ahead = 10
# Interval between attempts to check the hash, in milliseconds.
#hash_interval = 100
# Number of attempts to check the hash while using the mincore status,
# before forcing. Overworked systems might need lower values to get a
# decent hash checking rate.
#hash_max_tries = 10
I have rulet out a bad port configuration because in windows works.
I thinks the problem is in DTH config or i dont know.
Can you help me please?
