sliverstorm
Minimizing SD I/O
Mon Aug 27, 2012 12:25 am
My rpi stays on for long periods, and my SD card is somewhat old and not super high quality. I back it up and all, but either way I'd rather it didn't fail any time soon.
So, I've been on a campaign to minimize I/O activity to the SD card. Nothing insane, mind you- I'm not going to mount my home folder in a temporary directory to prevent writes to ~/.history (although maybe I should turn off history!) I've been focusing on things like doing work in /tmp (which I mount as tmpfs) and turning logging way down. I've left /var alone for now, because aside from the logs I believe most activity there is at boot or shutdown.
Has anyone gone on a similar crusade? Does anyone have any suggestions of good things to target?
kriston
Re: Minimizing SD I/O
Mon Aug 27, 2012 2:10 am
In your lifetime you're not likely to wear out the SD card if it was made after 2005.
The most effective thing to do is to arrange to mount /var into a ramdisk. That's fairly easy to do in BSD Unix and Red Hat Linux but in Debian and Ubuntu it is not so easy since they depend so heavily on persistent things in /var. You might look at unionfs to mount the read/write parts of the filesystem onto a ramdisk but that's a bit too hairy to go into detail here.
SirLagz
Mon Aug 27, 2012 3:16 am
/var/run and /var/logs are safe to mount into tmpfs.
If you're using raspbian, theres a few other directories for apt that can be mounted into tmpfs as well.
/var/lib/apt ? and /var/cache/apt ? I think they were.
I'll find out when I get home.
sliverstorm
Mon Aug 27, 2012 3:53 am
Should have mentioned this is with ArchLinux
Elect
Mon Aug 27, 2012 4:00 pm
http://piserv.nl/blog/index.php/using-t ... pberry-pi/
I couldn't easily find out if it was available for Archlinux, so proceed with some caution.
kriston
Sun Sep 23, 2012 4:10 am
Pretty much mount /var into a ramdisk in order to keep flash memory writes to a minimum. Of course you lose diagnostic data but that's how we did it when we implemented a flash-based filesystem on Linux in the olden days. Some subsystems write to /etc but I forget which they were and even then they don't write that often. The /var volume is the main place to worry about.
Return to “Advanced users”
