fueler
Compiling GCC on Raspberry Pi
Mon Aug 13, 2012 12:57 am
I am trying to compile GCC on the Raspberry Pi itself.
Background:
I am using the the Wheezy distro off the download page.
Steps so far:
1. Added the following to /etc/apt/sources.list
deb-src http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
2. sudo apt-get update
3. sudo apt-get build-dep gcc binutils gdb
During step #3 I run into issues with the package libecj-java-gcj, I am unable to configure it nor finish installing it.
Any help would be great!
scm
Re: Compiling GCC on Raspberry Pi
Fri Sep 14, 2012 7:19 am
Is there a reason you want to build gcc on the Pi rather than on a Desktop Linux machine with a cross-compiler?
I admit, it would be a challenge, but given the Pi's low memory and slow CPU, it seems like a masochistic endeavor.
RaTTuS
Contact: Twitter YouTube
Fri Sep 14, 2012 7:57 am
maek sure you are in in 240 ram config , and have swap space
Covfefe
Hypnos
Fri Sep 14, 2012 10:29 pm
The reason is I have loads of c code some using open gl and id like to convert them to work on linux pi,
rather than completely re-writing the code the code as c is quite stable as i use most of my own functions and structures for the body of the work, maybe there is a way to transfer c text files to the pi via telnet or fttp but I am not a network programmer but specialize in graphics. Any more advice would be a great help.
mupi
Sun Sep 16, 2012 11:05 am
Why not
pacman -S gcc
in arch?
Edit: In case it isn't clear, I'm suggesting you use Arch :)
dom
Sun Sep 16, 2012 11:34 am
Hypnos wrote:The reason is I have loads of c code some using open gl and id like to convert them to work on linux pi,
The Wheezy distribution has gcc installed as standard. No need to build it yourself. Type in:
gcc hello.c
williamhbell
Sun Sep 16, 2012 6:06 pm
If the ssh daemon is setup to run, then
apt-get rsync
is probably a good idea. Then you can
rsync -av somedir/ pi@someaddress:~/somedir/
and copy your source files over. C code should compile as expected without the need to recompile gcc.
Regards,
Will
pbinks
Mon Sep 17, 2012 12:11 pm
Good idea about putting rsync on. Command should be:
apt-get install rsync
Return to “Advanced users”
