Log files & SD Card wear
Posted: Tue Aug 07, 2012 11:26 pm
by kspn
I have been playing with my RasPi (and loving it :D ) but I was wondering if the log files were going to cause issues for the system :? .
As a result of this I was considering moving the log files to a tempfs with the issue being that log files are not stored between sessions. :geek:
Just wondering what people thought about this? (I am also wondering if my SQLite db file will cause problems over time but I am less concerned with that as there is much less data write, it is 95% read)
kspn
Re: Log files & SD Card wear
Posted: Wed Aug 08, 2012 12:39 am
by ejsolutions
Yes, I've being doing a little tweaking to logrotate, reducing the number of saved files and compression of the saved logs. If anything, it saves on disc space but there's still writing going on. I'm sure that there must be some that can be turned off and only resumed for debugging purposes.
Posted: Wed Aug 08, 2012 7:53 am
by fos
SD cards do have a finite number of R/W cycles. Are any of the power users seeing a degradation in reliability?
Has anyone calculated a theroretical lifespan for SD cards running R PI?
Thank you,
Jeff
Posted: Thu Aug 09, 2012 9:49 am
by obcd
sd cards normally should have a wear levelling algoritm build in. This means that the card keeps track of how many times a block got erased and reprogrammed. It tries to keep these numbers equal for every block on the card. So it's not like the same block containing the log file will be rewritten every time.
Things can be improved without much trouble by taking an sd card of a bigger size. It simply means there are more blocks that can be erased and rewritten. As long as you avoid logfiles that change every millisecond, I don't think you have to worry about the sdcard going bad. After all, solid state drives use similar technology if I remember well, and no one seems to ask the question how long they will work.
Posted: Thu Aug 09, 2012 10:15 am
by james968
If you have another Linux/UNIX box on your network, then you can configure syslog to send the logs to that box instead.
*.* @x.x.x.x
James
Posted: Mon Aug 13, 2012 5:16 pm
by Elect
I was looking for a solution to the same problem as well. I'm using my Pi as a webserver and I don't want it to last for a few months before I can buy a new SD card and start all over again.
I found a script called Ramlog which is available for Debian as well. I made a tutorial on my implementation and how you can install it:
http://piserv.nl/blog/index.php/using-t ... pberry-pi/
Posted: Tue Aug 14, 2012 8:11 pm
by Harrkev
With a 4G card being easily available for under $10 USD, if it wears out after two years, toss it and throw another one in.
Posted: Wed Aug 15, 2012 1:03 am
by SirLagz
Ramlog is nice. Wasn't aware of a prebuild package to do that !
If you didn't care about logs, you can just mount /var/log as a ramdisk
add this line in /etc/fstab
tmpfs /var/log tmpfs defaults 0 0
Posted: Wed Aug 15, 2012 1:37 am
by kspn
When I get a chance I think I will try out RAMLog, I am interested in keeping the logs between boots and it looks to be possible.
Running a webserver as well as various python scripts means that having the logs is useful.
Thanks for the tips.
I wonder if it would be worthwhile putting RAMLog (or something like it) into the 'official' installation Disk Image?
Posted: Wed Aug 15, 2012 6:50 am
by Elect
Ramlogs works very well. Every day it syncs the logs to the SD card.
