Ed Raket
Benchmark program
Thu Aug 02, 2012 7:41 pm
My Pi runs really great with current settings! tested under x and with several games
cpu_freq=900
gpu_freq=450
core_freq=300
I just wondered if there is like a bechmark program that runs under Raspbian without x? i read Eben's post about nbench, but i can't apt-get that program...
shalo
Re: Benchmark program
Thu Aug 02, 2012 8:52 pm
Ed Raket wrote:My Pi runs really great with current settings! tested under x and with several games
cpu_freq=900
gpu_freq=450
core_freq=300
Are you sure those are your settings?
Ed Raket
Thu Aug 02, 2012 9:08 pm
Oh yes, typing:
less /boot/config.txt
shows:
arm_freq=900
gpu_freq=450
core_freq=300
And:
cat /proc/cpuinfo
Shows: 898.66 BogoMIPS
And it runs verry nice indeed! :mrgreen: Why do you ask?
shalo
Thu Aug 02, 2012 9:39 pm
Ed Raket wrote:Oh yes, typing:
shows:
arm_freq=900
gpu_freq=450
core_freq=300
And:
cat /proc/cpuinfo
Well, it's very odd. You have the gpu running faster than the core, possible but let's see what your settings mean:
core of 300 gives a pll of 1200, possibly 600, not 100% certain.
Now then, what does that mean for your gpu of 450. Well, if the pll is 600 that means your gpu is either running half the time at 600 and half the time at 300 for an average of 450mhz. I'd be very surprised if the 3d block will actually work like that with any level of over-voltage.
If we go with 1200 pll that would mean what, it's actually running at 600mhz 1/4 of the time and 400mhz 3/4 of the time?
Honestly, everything suggests the core can be run much faster than the 3d block which has much less headroom and yet your settings are the opposite and don't really make sense to me. Perhaps I have missed something.
Ed Raket
Thu Aug 02, 2012 10:07 pm
Is'nt the "core" speed something like the "bus" speed? otherwise i could not guess what "arm" and "gpu" speed changes... :shock: maybe there are some commands or a proggie that i can use to shed some light on this matter.... i used these settings becouse i stumbeled upon a post that mentioned to use GPU 1/2 of ARM speed, and CORE 1/3 of ARM speed. so i did ;)
And im not exactly sure of the effect, thats why i would like to benchmark this setup and compare to other settings.
But i must say.... my i5 laptop seems quite slow all of a suddon... :mrgreen:
portets
Thu Aug 02, 2012 10:40 pm
The gpu should be equal to or half of core speed. Or 1/3 of 2x core speed.
example:
core_freq=420
420 x 2 = 840
840 / 3 = 280
gpu_freq=280
arm_freq is the cpu, core freq is something related to the interaction between the gpu and cpu. Core freq also changes the cpu's l2 cache speed.
Your gpu_freq is really high. Did you test in quake3? The gpu downclocks when it's not being used much, so a demanding 3d game could crash it.
Core freq can usually be upped more than the gpu_freq. I would instead do:
arm_freq=900
core_freq=420
gpu_freq=280
then play around from there.
To use nbench, download http://www.tux.org/~mayer/linux/nbench- ... 2.3.tar.gz click save.
open up your home folder, your download should be there. right click, extract here. open up the new folder just created. At the top, click tools, open in terminal. then type "make" withut quotes. close all applications as to not effect results(except your terminal). make might take a few minutes.
Then type "./nbench" without quotes. copy and paste your results into a text file and compare.
To run without X, just rename the folder "nbench", boot without X, type "cd nbench", type "./nbench", Write down results.
Ed Raket
Thu Aug 02, 2012 11:11 pm
portets wrote:The gpu should be equal to or half of core speed. Or 1/3 of 2x core speed.
example:
core_freq=420
420 x 2 = 840
840 / 3 = 280
gpu_freq=280
arm_freq=900
core_freq=420
gpu_freq=280
Thanks for this explanation!, ill download "nbench" tomorrow and have a go on the values, ill post back here what is say's ;)
Ed Raket
Fri Aug 03, 2012 8:41 am
I have compared my settings with those proposed by "Portets" and the second one gains more speed :D
Settings:
arm_freq=900
gpu_freq=450
core_freq=300
TEST : Iterations/sec. : Old Index : New Index
: : Pentium 90* : AMD K6/233*
NUMERIC SORT : 256.96 : 6.59 : 2.16
STRING SORT : 38.145 : 17.04 : 2.64
BITFIELD : 8.0763e+07 : 13.85 : 2.89
FP EMULATION : 51.698 : 24.81 : 5.72
FOURIER : 2445.1 : 2.78 : 1.56
ASSIGNMENT : 3.0166 : 11.48 : 2.98
IDEA : 868.54 : 13.28 : 3.94
HUFFMAN : 533.81 : 14.80 : 4.73
NEURAL NET : 3.7894 : 6.09 : 2.56
LU DECOMPOSITION : 93.08 : 4.82 : 3.48
==========================ORIGINAL BYTEMARK RESULTS==========================
INTEGER INDEX : 13.624
FLOATING-POINT INDEX: 4.338
Baseline (MSDOS*) : Pentium* 90, 256 KB L2-cache, Watcom* compiler 10.0
==============================LINUX DATA BELOW===============================
CPU :
L2 Cache :
OS : Linux 3.1.9+
C compiler : gcc version 4.6.3 (Debian 4.6.3-8+rpi1)
libc : libc-2.13.so
MEMORY INDEX : 2.833
INTEGER INDEX : 3.898
FLOATING-POINT INDEX: 2.406
Baseline (LINUX) : AMD K6/233*, 512 KB L2-cache, gcc 2.7.2.3, libc-5.4.38
* Trademarks are property of their respective holder.
Settings:
arm_freq=900
gpu_freq=280
core_freq=420
NUMERIC SORT : 264.16 : 6.77 : 2.22
STRING SORT : 38.204 : 17.07 : 2.64
BITFIELD : 8.1188e+07 : 13.93 : 2.91
FP EMULATION : 51.997 : 24.95 : 5.76
FOURIER : 2566.5 : 2.92 : 1.64
ASSIGNMENT : 3.2258 : 12.27 : 3.18
IDEA : 872.32 : 13.34 : 3.96
HUFFMAN : 537.63 : 14.91 : 4.76
NEURAL NET : 3.92 : 6.30 : 2.65
LU DECOMPOSITION : 103.68 : 5.37 : 3.88
INTEGER INDEX : 13.857
FLOATING-POINT INDEX: 4.622
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.903
INTEGER INDEX : 3.942
FLOATING-POINT INDEX: 2.563
Sorry for the "wordwrap", but it's kind off readable... ;)
shalo
Fri Aug 03, 2012 12:19 pm
Ed Raket wrote:Is'nt the "core" speed something like the "bus" speed? otherwise i could not guess what "arm" and "gpu" speed changes... :shock: maybe there are some commands or a proggie that i can use to shed some light on this matter.... i used these settings becouse i stumbeled upon a post that mentioned to use GPU 1/2 of ARM speed, and CORE 1/3 of ARM speed. so i did ;)
I'm not sure where you could have read any of that, but there is lots of advice and explanations of what all the settings do and even newer settings in the overclocking thread in this very forum.
http://www.raspberrypi.org/phpBB3/viewt ... =29&t=6201
You'll also find other suggestions for benchmarks and stress tests.
Ed Raket
Fri Aug 03, 2012 2:33 pm
Thx Shalo, i will look in to this ;)
jerrylamos
Wed Aug 08, 2012 12:28 pm
Followed the directions for nbench above. This set selected from elinux tested configs.
config.txt
arm_freq=900
core_freq=450
sdram_freq=450
BYTEmark* Native Mode Benchmark ver. 2 (10/95)
Index-split by Andrew D. Balsa (11/97)
Linux/Unix* port by Uwe F. Mayer (12/96,11/97)
NUMERIC SORT : 270.88 : 6.95 : 2.28
STRING SORT : 38.354 : 17.14 : 2.65
BITFIELD : 8.227e+07 : 14.11 : 2.95
FP EMULATION : 52.396 : 25.14 : 5.80
FOURIER : 2625.8 : 2.99 : 1.68
ASSIGNMENT : 3.443 : 13.10 : 3.40
IDEA : 877.54 : 13.42 : 3.99
HUFFMAN : 541.59 : 15.02 : 4.80
LU DECOMPOSITION : 107.88 : 5.59 : 4.04
INTEGER INDEX : 14.114
FLOATING-POINT INDEX: 4.719
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.984
INTEGER INDEX : 3.988
FLOATING-POINT INDEX: 2.617
The performance I see from the Pi is mostly internet browser of course.
The most important is a good community of forums - there are other boards out there with higher price and better specs I've no interest until they can match Pi's forums.
Jerry
Return to “Advanced users”
