mad-hatter
eeprom for HATS - find a supplier
Wed May 13, 2015 8:16 pm
I'm trying to find a UK supplier of eeproms suitable for the HAT specification, in small quantities,
just an assortment to play with. I'm not sure what the specifications mean when I read the data sheets.
I would appreciate some help.
Regards
24C32, 24C64, 24C128, 24C256, 24C512, 24C1024
EEPROM Device Specification
    24Cxx type 3.3V I2C EEPROM must be used (some types are 5V only, do not use these).
    The EEPROM must be of the 16-bit addressable type (do not use ones with 8-bit addressing)
    Do not use 'paged' type EEPROMs where the I2C lower address bit(s) select the EEPROM page.
    Only required to support 100kHz I2C mode.
    Devices that perform I2C clock stretching are not supported.
    Write protect pin must be supported and protect the entire device memory.
Return to “Advanced users”
