GadgetUK
USB DVB-T breaks onboard i2c
Wed Apr 01, 2015 11:43 am
Hi All,
Bit of a strange one, i2c works fine until I install an couple of USB DVB-T dongles
No DVB-T
[    4.875288] bcm2708_i2c_init_pinmode(1,2)
[    4.880879] bcm2708_i2c_init_pinmode(1,3)
[    4.883231] bcm2708_i2c 20804000.i2c: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
With DVB-T
[    4.702733] i2c i2c-0: Added multiplexed i2c bus 1
[    4.730719] i2c i2c-0: Added multiplexed i2c bus 2
[    5.082248] bcm2708_i2c_init_pinmode(1,2)
[    5.084456] bcm2708_i2c_init_pinmode(1,3)
[    5.086519] bcm2708_i2c 20804000.i2c: could not add I2C adapter: -16
[    5.124241] bcm2708_i2c: probe of 20804000.i2c failed with error -16
[    6.127301] i2c i2c-3: Added multiplexed i2c bus 4
[    6.205647] i2c i2c-3: Added multiplexed i2c bus 5
Any suggestions on how to resolve ?
beta-tester
Re: USB DVB-T breaks onboard i2c
Thu Apr 02, 2015 2:11 pm
what's you DVB-T card?
its the driver and firmware installed?
what's your OS and RPi version type?
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
GadgetUK
Sat Apr 04, 2015 10:52 am
Ok.
It's an a Pi B
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 2.00
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 000e
Serial		: 00000000e65ab430
The DVB-T usb dongle is a realtek RTL2838, that works as expected, and has been used to stream to VLC
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
I've got the latest version of raspbian installed.
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.18.10+ #774 PREEMPT Wed Mar 25 13:58:34 GMT 2015 armv6l GNU/Linux
Return to “Advanced users”
