Lebalme
Re: Compiling 8812au module on Raspberry Pi 2 and Raspbian
Sat Jul 11, 2015 6:20 pm
Hi xphoto,
I'm a new Linux user and recently received yesterday a EW7811-UTC for my Pi2 and obviously cannot use it.
Could you help and explain me what is the way to install new Kernel (I believe) in my Pi. I downloaded the 8812au.ko file but know undertand what to do with. I created a new folder, put it in and make a lsmod. There I have the folowing lines coming, but do not know what else...
Can you help.
Best regards
pi@raspberrypi ~/fourtout $ sudo lsmod
Module Size Used by
snd_bcm2835 18649 0
snd_pcm 73475 1 snd_bcm2835
snd_seq 53078 0
snd_seq_device 5628 1 snd_seq
snd_timer 17784 2 snd_pcm,snd_seq
snd 51038 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
8192cu 528365 0
uio_pdrv_genirq 2958 0
uio 8119 1 uio_pdrv_genirq
MrEngman
Sat Jul 11, 2015 8:10 pm
Lebalme wrote:Hi xphoto,
Can you help.
Best regards
Module Size Used by
snd_bcm2835 18649 0
snd_seq 53078 0
8192cu 528365 0
Can you connect the EW7811UTC wifi to your Pi and post the output of the two commands
uname -a
lsusb
The output you posted from command lsmod shows the 8192cu driver is installed which would appear to indicate you have a 8192cu/8188cu wifi module installed. Is that right?
MrEngman
innocube
Mon Nov 14, 2016 9:17 am
I would like to know if anybody successfully cross-compiled for Raspberry Pi 1? I am using 1 B+. Had put some hours but not successful yet. I want to use rtl8812au for openWrt in Raspberry Pi B+.
Please let me know if you have done this or could help me in this.
Thank you in advance!
Return to “Advanced users”
