ofey
Epiphany Javascript console.log()
Sat Jan 24, 2015 11:41 am
I am learning a little javascript and using Epiphany as the browser on a RPi.
In the book i am using, 'Eloquent Javascript', most examples output with console.log() but I can't see how to see this output in Epiphany.
Is there no console output in Epiphany?
Any ideas?
Thanks,
Shane
Pi = too much fun!
r3d4
Re: Epiphany Javascript console.log()
Sat Jan 24, 2015 11:56 am
perhaps not you can allwats create the console object and create a log() function in it ...
or create a div and push the log content to that ...
Sorry cant be much help .
Real life is, to most, a long second-best, a perpetual compromise between the ideal and the possible.
Meanwhile, the sysadmin who accidentally nuked the data reckons "its best not run anything more with sudo today"
what about spike milligan?
ofey
Sat Jan 24, 2015 12:08 pm
r3d4 wrote:create the console object and create a log() function in it ... or create a div and push the log content to that ...
Thanks for your reply. Objects are the next chapter, so this is a little beyond me at the moment.
Should try a different browser?
Thanks,
Shane
Pi = too much fun!
r3d4
Sat Jan 24, 2015 1:08 pm
Thanks,
Shane
Well im no expert ;) (and i dont have Epiphany on a pi to hand ... perhaps it has so other way of looking at logs/errors ?? )
but i would just skip a head a chaper to read up on objects and or use this
var console = {} ; // <---- This is an object called console
console.log = function (str) { alert( str ) ; }
// you can write the above in a diffrent way like
var console = { "log" : function (str){ alert(str) ;  }     } ;
Json.org has some good diagrams of the object notation used en JS .
Realy it is up to you , when i was learning js console.log() was not avalable as a 'built in function' of the browser
so you can survive without it if need be , one alternative method would be to just use
 alert('somthing happened') ;
Sat Jan 24, 2015 5:24 pm
ofey wrote: Should try a different browser?
Firefox with the web developer (on Windows) stuff is going to be much better.
Develop & debug on Windows, deploy on Raspberry Pi.
This is a doctor free zone.
ofey
Sat Jan 24, 2015 6:18 pm
r3d4 thanks i will just use alert() for the moment.
json.org does have very clear diagrams. Thanks for this.
Thanks Dougie, I think this the best option.
Shane
Pi = too much fun!
r3d4
Sat Jan 24, 2015 8:11 pm
DougieLawson wrote: Firefox with the web developer (on Windows) stuff is going to be much better.
\r\n
ofey
Sat Jan 24, 2015 10:33 pm
\r\n
and this means it is all the same?
Like carriage return / newline... probably a techie joke... :?:
Pi = too much fun!
Sat Jan 24, 2015 11:29 pm
r3d4 wrote:
\r\n
I'll see your carriage return & newline and raise you
I assume it's some kind of poker bidding, because it doesn't make any sense otherwise.
ofey
Sun Jan 25, 2015 3:12 pm
DougieLawson wrote:...some kind of poker bidding, ... it doesn't make any sense otherwise.
Glad to hear that!
Pi = too much fun!
r3d4
Mon Jan 26, 2015 9:38 am
DougieLawson wrote:
r3d4 wrote:
\r\n
:lol:
Its the first thing i can remember about working between windows n other os that wiill trip up any one using default text editors ; that dont display chars you cant see .
Perhaps this is no longer a problem ??
i did not see the OP didnt mention windows ..
>> 'Develop & debug on Windows, deploy on Raspberry Pi.'
to me apperars like pointing some asking for directions the wrongway :?
Mon Jan 26, 2015 11:33 am
The newline vs carriage return/newline is not a problem with Javascript.
If it ever is a problem then dos2unix is the simple tool to undo the \r\n stuff.
jweob
Sun Jul 19, 2015 9:09 pm
I'm launching epiphany from the command line using SSH using "epiphany-browser -a --profile ~/.config <URL>"
console.log() messages appear in the SSH terminal output
r3d4
Wed Jul 22, 2015 4:01 pm
DougieLawson wrote:If it ever is a problem then dos2unix is the simple tool to undo the \r\n stuff.
True but i would guess that the 'command line' tools ect is a bit further along the 'learning curve' for most who wander in off the web scripting js !
gadgetoid
Wed Mar 16, 2016 2:17 pm
I hate to resurrect a dinosaur thread, but in this case I think it's warranted.
This thread turns up in searches about how to enable the JS debugger, so for the help of future JS tinkerers, I'd like to supply the answer:
Open up Terminal, and run Epiphany like so:
EPHY_ENABLE_INSPECTOR=true epiphany
Developing and debugging on Windows/Chrome is not always the right answer, since you can very easily fall into traps set by ECMA Script 6 only features which are not supported in Epiphany. IE: Something can work absolutely *fine* on Windows/Chrome but fail in Epiphany 3.8.x on the Pi.
The magic words above will give you a clunky albeit functional debugger for catching any incompatibilities which slip through.
r3d4
Thu Apr 14, 2016 1:20 pm
Thanks!
(from a current tinkerer)
