Onira
after yesterday's update the i2c clock doesn't work (solved)
Wed Jan 21, 2015 5:05 am
Hello
I did an update yesterday
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get dist-upgrade
$ sudo rpi-update
and rebooted the system
Like usually I did
$ sudo hwclock
but I got
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
so
$ sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
$ sudo i2cdetect -y 1
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
$ lsmod
fuse                   92153  3
tun                    20798  2
w1_therm                3325  0
w1_gpio                 4068  0
wire                   31280  2 w1_gpio,w1_therm
cn                      5756  1 wire
rtc_ds1307              9868  0
i2c_dev                 6709  0
i2c_bcm2708             6004  0
snd_bcm2835            21342  0
sg                     21787  0
snd_usb_audio         127474  0
snd_hwdep               6545  1 snd_usb_audio
snd_usbmidi_lib        22236  1 snd_usb_audio
snd_seq_midi            5037  0
snd_seq_midi_event      7831  1 snd_seq_midi
snd_rawmidi            23955  2 snd_usbmidi_lib,snd_seq_midi
snd_pcm                93100  2 snd_bcm2835,snd_usb_audio
snd_seq                61097  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device          7209  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              23007  2 snd_pcm,snd_seq
snd                    67211  9 snd_bcm2835,snd_usb_audio,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_usbmidi_lib,snd_seq_device
evdev                  11000  2
joydev                  9766  0
uio_pdrv_genirq         3666  0
uio                     9897  1 uio_pdrv_genirq
uas                    15604  0
Cogito ergo sum
ame
Re: after yesterday's update the i2c clock doesn't work anym
Wed Jan 21, 2015 5:15 am
Surprise!
http://www.raspberrypi.org/forums/viewt ... 29&t=97216
I got around the problem I was seeing by adding "device_tree=" in /boot/config.txt
Section 4.3 in the documentation here:
https://github.com/raspberrypi/document ... ce-tree.md
YMMV
Onira
Wed Jan 21, 2015 5:32 am
didn't help or did I do something wrong?
$ dmesg | grep i2c
[   12.946174] i2c /dev entries driver
$ sudo hwclock
$ cat /boot/cmdline.txt
#dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
dwc_otg.lpm_enable=0 console=ttyUSB0,115200 kgdboc=ttyUSB0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
device_tree=
Cogito ergo sum
ame
Wed Jan 21, 2015 5:34 am
It should be in /boot/config.txt
I think you added it to /boot/cmdline.txt
Onira
Wed Jan 21, 2015 6:20 am
I'm sooo silly :P
$ sudo hwclock
śro, 21 sty 2015, 07:17:31  -0.878636 seconds
dispalaying in polish 'cos I'm PL
LANG=C doesn't change
Thank you ame
Cogito ergo sum
Re: [SOLVED] after yesterday's update the i2c clock doesn't
Wed Jan 21, 2015 8:46 am
Model A & B users should add this to /boot/config.txt
device_tree=bcm2708-rpi-b.dtb
device_tree_param=i2c1=on
device_tree_param=spi=on
Model A+ & B+ users should add this
device_tree=bcm2708-rpi-b-plus.dtb
Reboot and SPI & I2C will work in the way they did with 3.12.35+
The problem is that folks got in the bad habit of running sudo rpi-update when they don't need to push the kernel/firmware forwards to the leading edge of the RPF's development version.
This is a doctor free zone.
Onira
Wed Jan 21, 2015 8:53 am
But what is the difference between adding "device_tree=" or those lines you mentioned?
Bad habbits are major human diseases ;)
Cogito ergo sum
Wed Jan 21, 2015 9:43 am
Onira wrote:But what is the difference between adding "device_tree=" or those lines you mentioned?
Adding "device_tree=" disables the new method and forces it to run the old way.
Adding the other lines will correctly set up the new method.
Onira
Wed Jan 21, 2015 9:50 am
Now I understand :)
Cogito ergo sum
Wed Jan 21, 2015 9:54 am
Onira wrote: But what is the difference between adding "device_tree=" or those lines you mentioned?
One embraces the new technology. The other disables it.
Device tree is the future, so if you can get your system running with it you should use it. Moving forwards and solving problems as we meet them is better in the long run than taking a retrograde step and sticking with something that "works for me".
pluggy
Wed Jan 21, 2015 1:56 pm
I often wonder why rpi-update is installed by default in recent versions of Raspbian, it was nice and safe hidden away in github and the 2 people who actually needed it could install it. Its a complete waste of time (or in this case worse) for 99.9% of Pi users.
PhilE
Wed Jan 21, 2015 1:59 pm
I would argue it gives us another tier of testing, before a release hits the real mainstream.
blachanc
Wed Jan 21, 2015 2:05 pm
PhilE wrote:I would argue it gives us another tier of testing, before a release hits the real mainstream.
Agreed,
but a call for beta testers would cover this, and keep regular users from using the command without understanding what it will achieve.
maybe sudo rpi-update should output a warning like:
"you are leaving the main path to the equivalent of nightly builds, are you sure you want to do this ?" (I know, I am exaggerating a bit ;) )
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
pluggy
Wed Jan 21, 2015 2:06 pm
Maybe it should be made a lot clearer in the program that it is completely unnecessary and can break things.
Standard users should not be used as unwitting beta-testers. Leave on github, for those who do want to be and understand the implications of being a beta-tester.
Wed Jan 21, 2015 2:19 pm
Testing in the field is a very risky operation that's 100% guaranteed to upset some folks.
The problem is that the rpi-update genie is out of the bottle. The update-meme throught "morphic resonance" has lead to folks thinking it's a requirement as part of their update/upgrade process.
milhouse
Wed Jan 21, 2015 3:50 pm
Perhaps there should be a "release" thread - no discussion - with details of the changes (and potential problems/solutions) for each release, described in such a way that the user can quickly determine the changes that have occurred since their current kernel was installed.
Display the url of this release thread whenever rpi-update is run, and quiz the user to enter a randomly selected word from the first post (Manic Miner style) to confirm the release thread has been accessed and ideally, read and understood, with all consequences accepted. :)
Being able to run rpi-update is useful, but being able to run it when totally unprepared for the potential consequences is simply asking for trouble.
ShiftPlusOne
Wed Jan 21, 2015 4:01 pm
milhouse wrote:Perhaps there should be a "release" thread - no discussion - with details of the changes (and potential problems/solutions) for each release, described in such a way that the user can quickly determine the changes that have occurred since their current kernel was installed.
That would just be duplicating what's already on github though. https://github.com/raspberrypi/firmware/commits/master
milhouse
Wed Jan 21, 2015 4:35 pm
ShiftPlusOne wrote:That would just be duplicating what's already on github though. https://github.com/raspberrypi/firmware/commits/master
True, and while there are users here who read and understand what is posted on github, there are a lot more that don't. However the main point of my post was to somehow ensure the user had read and understood the changes they were about to apply. You could use github for that too, but a single forum thread might be easier to "digest", perhaps even worded using slightly less "techy" language.
PhilE
Wed Jan 21, 2015 4:53 pm
FYI, there is a new post explaining the Device Tree changes here: http://www.raspberrypi.org/forums/viewt ... 29&t=97314
subnet
Sun Jan 25, 2015 9:02 pm
DougieLawson wrote: The problem is that folks got in the bad habit of running sudo rpi-update when they don't need to push the kernel/firmware forwards to the leading edge of the RPF's development version.
I totally agree (especially referring to me). Almost every time I launch rpi-update I have a problem (in this case with i2c, but solved thanks to this post).
I promise I will not do it again:-)
many thanks
pluggy
Mon Jan 26, 2015 12:09 am
[rant]
Whoever put rpi-update into standard raspbian wants hanging by the thumbs. It should have remained an obscure curio languishing on github for the 2 people who actually need it. Its become an endemic plague since.
Some appear to think its the only way of upgrading the Pi's "firmware" (it doesn't have firmware in the first place, which is one of its greatest assets IMO). Firmware is somewhere between easily changed software and not so easily changed hardware, The Pi has software of a slightly different ilk and a hardwired bit in the GPU......
[/rant]
PhilE
Mon Mar 30, 2015 9:59 am
[ This was the answer to a post that was deleted while I was writing this ]
Try this:
1. Add
dtoverlay=i2c-rtc,pcf8563
to config.txt .
2. Disable or remove the fake-hwclock.
dpkg --purge fake-hwclock
should do it.
3. Edit /lib/udev/hwclock-set and change both occurrences of "--systz" to "--hctosys".
4. Delete /etc/adjtime .
5. Reboot.
More details on the RTC issue: http://www.raspberrypi.org/forums/viewt ... 92#p690492
More details on Device Tree: http://www.raspberrypi.org/forums/viewt ... 28&t=97314
TarjeiB
Mon Mar 30, 2015 11:28 am
Thanks, PhilE!
I'm a stickler for getting stuff in the right place, guess I missed the mark this time :)
Unfortunately the fixes doesn't work - the problem seems to be with hwclock itself, not the parameters passed to it.
While the I2C looks just fine:
i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- UU -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- 6a 6b -- -- -- --
70: -- -- -- -- -- -- -- --
[    6.331210] rtc-pcf8563 1-0051: chip found, driver version 0.4.3
[    6.598646] rtc-pcf8563 1-0051: rtc core: registered rtc-pcf8563 as rtc0
Any command sent by hwclock will give timeout:
sudo hwclock --rtc /dev/rtc0 -r
hwclock: select() to /dev/rtc0 to wait for clock tick timed out: Success
sudo hwclock --rtc /dev/rtc0 --hctosys
sudo hwclock --rtc /dev/rtc0 --systohc
sudo hwclock --rtc /dev/rtc0 -r --debug
hwclock from util-linux 2.20.1
Using /dev interface to clock.
Last drift adjustment done at 1427714563 seconds after 1969
Last calibration done at 1427714563 seconds after 1969
Hardware clock is on UTC time
Assuming hardware clock is kept in UTC time.
Waiting for clock tick...
...synchronization failed
And I am stuck in 1970 every reboot.
This is an offgrid RPi that doesn't have any other way of keeping time and turns on and off according to ambient light levels - so RTC operation is essential :)
This exact setup has served me for a couple of years now, but with the new kernel I just cannot bring it back. Could it be that hwclock no longer works as it should with the new kernel? See http://www.raspberrypi.org/forums/viewt ... 8&p=688215 and http://www.raspberrypi.org/forums/viewt ... 50#p729850
PhilE
Mon Mar 30, 2015 11:42 am
Strange. Try unloaded the driver module (sudo rmmod rtc_pcf8563) and dumping the device:
sudo i2cdump -y 1 0x51
On a pcf8523 I get output like this:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 86 16 08 51 36 11 30 01 03 15 80 80 80 80 00 00    ???Q6?0???????..
10: 07 00 07 6e 00 47 00 00 00 00 00 00 00 00 00 00    ?.?n.G..........
20: 86 16 08 51 36 11 30 01 03 15 80 80 80 80 00 00    ???Q6?0???????..
30: 07 00 07 6e 00 47 00 00 00 00 00 00 00 00 00 00    ?.?n.G..........
You can see the time (11:36:51) and date (30/03/15) in little-endian BCD format in there if you look carefully.
TarjeiB
Mon Mar 30, 2015 12:09 pm
No size specified (using byte-data access)
00: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
10: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
20: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
30: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
40: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
50: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
60: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
70: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
80: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
90: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
a0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
b0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
c0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
d0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
e0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
f0: 08 40 46 11 41 41 44 41 70 09 01 01 04 c4 47 60    ?@F?AADAp?????G`
is it broken?
