hbleuler
Re: Can't Browse HTTPS Sites?
Tue Jun 02, 2015 7:28 pm
date
Tue Jun 2 21:17:11 CEST 2015
Is this important? The data 2015-05-05 is the date of the latest distribution
Tue Jun 02, 2015 7:43 pm
All HTTPS certificates have a not before date and a not after date. So having the system clock set to something close to the current date/time is a good starting point.
This is a doctor free zone.
gkreidl
Tue Jun 02, 2015 8:48 pm
calomel.org uses TLS 1.2 (not available in many older browses yet)
www.rootusers.com gives rather crappy security information in Firefox and no information about protocol
Minimal Kiosk Browser (kweb)
ktb
Wed Jun 03, 2015 5:47 am
www.rootusers.com has the same issue as linuxcounter.net had (also CloudFlare).
mikluz
Thu Mar 31, 2016 12:01 pm
Sorry for comming back to this topic. I just wanted to write that I had the same problems as the guys here.
The reason was that my Raspbian (on RPi 3) couldn't sync date/time properly... (That is very strange, as previous installation worked perfectly. Then I had to reinstall Raspbian and now I've been having problems with time sync).
Installing ntpdate solved the issue with https websites. So, if anyone in the future will have similar problems, setting your time/date properly is first what you should do :).
Raspberry Pi 3 @ Raspbian
Fri Apr 01, 2016 5:33 am
To force a clock sync
sudo /etc/init.d/ntp stop
sudo ntpd -q-g
sudo /etc/init.d/ntp start
returningsam
Fri Jul 08, 2016 6:48 pm
I came to this post because I was having this same problem (Not being able to view/access https sites) on my rpi3. None of the supplied solutions seemed to work for me, so I ended up giving up and resorting to only doing http.
Soon after, I realized my system timezone and locale were wrong. As soon as I fixed these things, it worked perfectly (I hadn't changed anything else). Not 100% sure that this was the problem, but it seemed like it was.
I know this forum is a bit old, but hopefully this helps someone else if they encounter the same thing.
jschaap26
Mon Dec 26, 2016 10:57 pm
Correctly setting the time and date resolved this issue for me.
