faze
XBMC Not Running?
Tue Sep 09, 2014 7:31 pm
I am trying to use Yatse, the XBMC remote on my Android devices... When I go to setup, it finds my Pi with the correct IP but when I try and connect to it with the correct password, it tells me XBMC isn't running. What am I missing?
faze
Re: XBMC Not Running?
Wed Sep 10, 2014 9:24 pm
Anyone?
redhawk
Wed Sep 10, 2014 9:26 pm
Does it require services to be enabled on XBMC i.e. ssh for example??
Richard S.
faze
Thu Sep 11, 2014 2:13 pm
I'll check SSH and see if it's enabled or not and see if that resolves the issue
DirkS
Thu Sep 11, 2014 5:35 pm
Can't remember doing anything special to get Yatse working with Raspbmc. Don't think it needs SSH...
Have you checked the setting to allow other systems to control XBMC (Settings / Services / Remote Control).
You may also need web access. See http://yatse.leetzone.org/redmine/proje ... XbmcConfig for more details.
Gr.
Dirk.
faze
Sat Sep 13, 2014 2:20 pm
Trying that last suggestion right now... Standby
faze
Sat Sep 13, 2014 2:58 pm
Does not work still. Can't even browse to ipaddress:8080.
faze
Sun Sep 14, 2014 5:40 pm
So I can telnet to the Pi's IP on port 8080 but via a browser I just get no data received. Um??
DirkS
Sun Sep 14, 2014 5:45 pm
Which distro are you using?
faze
Sun Sep 14, 2014 10:22 pm
OpenElec 4.0.7
faze
Mon Sep 15, 2014 10:41 pm
Suggestions?
faze
Fri Sep 19, 2014 12:42 am
Anything?
Fri Sep 19, 2014 5:49 am
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
faze
Sat Sep 20, 2014 9:31 pm
I changed the IP from what DHCP gave it to a random one and it started working. Any explanations on that?
