gravecad1
hard drive
Mon Jul 14, 2014 5:12 pm
hi
can anyone tell me how to use a hard disk on a rpi without haveing to type in loads
of instructions? like on windows 7?
gravecad
ghans
Re: hard drive
Tue Jul 15, 2014 8:53 am
Can you state where you live ? Looking [img]at your posting history , some face-to-face help might be the most effective.
Do you know if any Raspberry Pi Jams or Linux User Groups take place somwhere nearby ?
ghans
gravecad1
Re: hard drive
Tue Jul 15, 2014 9:53 am
hi
no, none at all.
Re: hard drive
Tue Jul 15, 2014 10:42 am
gravecad1 wrote:hi
gravecad
What do you want to achieve ?
Retired disgracefully.....
......to a more gentile life !
Richard-TX
Re: hard drive
Tue Jul 15, 2014 12:05 pm
It all depends on what you mean by typing in "loads" of commands.
Usually, when adding a hard drive, you edit a file or three, execute about 6 commands and then it is done. You don't have to enter the commands again unless you want to.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
gravecad1
Re: hard drive
Thu Jul 17, 2014 12:20 pm
hi
how do you send files to a hdd on rpi?
gravecad
Re: hard drive
Thu Jul 17, 2014 12:24 pm
gravecad1 wrote:hi
gravecad
Use Filezilla (using ssh/sftp to send/receive your files)
Use cifs/samba (to mount the RPi filesystem on windows, it appears as a network drive)
Use MobaXterm (which includes a file manager)
Use scp or sftp from a command line
Use ownCloud running on your RPi
This is a doctor free zone.
gravecad1
Re: hard drive
Fri Jul 18, 2014 10:12 am
hi
thanks.
how do i set these up on the rpi? do i load and run the programs onto the pi
useing the keyboard?
ghans
Re: hard drive
Fri Jul 18, 2014 10:16 am
You usually use the Programs DougieLawson mentioned on another Windows machine.
That is you connect both the Pi and the Windows machine to the same router via an Ethernet cable , and then
use FileZilla on your Windows PC to transfer files to the Pi.
ghans
gravecad1
Re: hard drive
Fri Jul 18, 2014 5:40 pm
hi
could you give me some instructions on how to use and setup
fileziila on the rpi. or where to find them. thanks.
ghans
Re: hard drive
Sun Jul 20, 2014 12:13 pm
FileZilla has to be installed on your Windows Machine.
http://sourceforge.net/projects/filezil ... e/download
Also install Fing:
http://www.overlooksoft.com/download
Use Fing to find the IP Adress of your Raspberry , and then follow this tutorial :
http://trevorappleton.blogspot.de/2014/ ... -your.html
ghans
TrevorAppleton
Re: hard drive
Tue Jul 22, 2014 2:19 pm
Thanks ghans to the link to my blog showing how to use filezilla. I also have a blog post which shows you how to remotely find your raspberry pi IP address which the origonal poster might find useful. It uses nmap rather than fing, but works well.
http://trevorappleton.blogspot.co.uk/20 ... dress.html
Check out my blog post for Raspberry Pi and Python tutorials.
piglet
Re: hard drive
Tue Jul 22, 2014 2:57 pm
I think people might have got the wrong end of the stick of the OP's question. I think he wants to know how to add a hard drive to his PI and permanently mount it without having to type in a lot of commands or editing files.
i.e.
Windows 7:
1. Plug it in.
2. Use it.
Linux:
1. Plug it in.
2. "type in loads of instructions".
3. If (when) you fail use Google to try to work out what you did wrong. Go to 2.
4. Otherwise buy sandals and caftan
5. Use it.
