Haswellpi
Disk was not properly unmounted please run fsck Raspbian
Mon Mar 10, 2014 1:12 pm
When i am trying to install raspbian i see that boot screen is going on and it stops it says disk was not properly unmouted some data may be corupted please run fsck. What to do?
Haswellpi
Re: Disk was not properly unmounted please run fsck Raspbian
Mon Mar 10, 2014 2:05 pm
What i need to do???
RaTTuS
Contact: Twitter YouTube
Mon Mar 10, 2014 4:05 pm
just reflash with latest raspbian
Covfefe
Haswellpi
Mon Mar 10, 2014 4:07 pm
I reflashed already but same error thanks
Haswellpi
Mon Mar 10, 2014 4:15 pm
What i need to do please help me
RaTTuS
Mon Mar 10, 2014 4:30 pm
one thread please.
download raspbian , flash that to the sd card.
just plug in monitor , nothing else
then SD card
then power
what happens
Covfefe
Haswellpi
Mon Mar 10, 2014 4:49 pm
The same error show on when i reboot
Pi_Fanatic
Mon Mar 10, 2014 7:49 pm
At the Raspberry Pi prompt type "Sudo Shutdown -F -r now" and that will reboot the Pi and run FSCK to check the volume.
Pi_Fanatic
Haswellpi
Mon Mar 10, 2014 8:05 pm
But i can't type anything
Thanks to reply
bart357
Tue Mar 11, 2014 10:16 pm
how are you trying to install the image to the sd card?
it seems as if you either have a bad download or are not creating a proper image.
take care
jojopi
Tue Mar 11, 2014 11:02 pm
Haswellpi wrote:When i am trying to install raspbian i see that boot screen is going on and it stops it says disk was not properly unmouted some data may be corupted please run fsck. What to do?
In the video from one of your other threads (which should all be merged) the messages include:
Greetings from standalone Raspberry Pi!
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
The fsck message is just a warning.
The boot stopped because it is complete. There will be a root prompt somewhere higher up the screen. Pressing Enter should give you another one. If you cannot type it is because of the keyboard problem, not because the boot has failed. (Try disconnecting the mouse, because it is not usable in safe mode anyway.)
The card has booted in safe mode, which normally only happens if GPIO3 is pulled low. In the video you have nothing connected to the GPIO. Have you connected anything in the past?
bart357
Tue Mar 11, 2014 11:49 pm
ok the best way (for me anyway) is to put the sd card in another computer.
~$ df -h
look for the sd card in my case it is /dev/sdb
~$ sudo umount /dev/sdb*
~$ sudo dosfsck -w -r -l -a -v -t /dev/sdb1
put the sd card back in the pi and reboot
I hope I understand compleatlly
hope that helps
