Re: Usb on rpi doesn't have power what to do?
Mon Mar 10, 2014 9:31 pm
Haswellpi wrote:Any idea ?? Thanks
Get a better power supply. One that can really supply 5V @ 2A.
This is a doctor free zone.
Haswellpi
Mon Mar 10, 2014 9:35 pm
Anyone else
rpdom
Mon Mar 10, 2014 9:53 pm
Haswellpi wrote:My usb ports are 4.8 volts is it bad or good do you know what is my problem.? Thanks for all
4.8V is close to borderline low voltage.
It might be worth checking your power supply and power cable.
Haswellpi
Mon Mar 10, 2014 10:19 pm
Could i try with powered power supply??
Haswellpi
Tue Mar 11, 2014 6:30 am
Idea thanks
RaTTuS
Contact: Twitter YouTube
Tue Mar 11, 2014 11:16 am
has this RPi worked before?
Covfefe
Haswellpi
Tue Mar 11, 2014 12:22 pm
Yes it worked before
Haswellpi
Tue Mar 11, 2014 6:57 pm
What to do thanks.
Haswellpi
Wed Mar 12, 2014 12:54 pm
When i am trying to install raspbian on my rasperry pi it start booting and stops it says"FAT -fs disk was not properly unmounted some data may be corrupted please run fsck" but i can't type anything because my mouse and keyoard don't work i try changing power supplys and nothing,reflashing sd card same error and I try swiching betwen hdmi and rca video output same error shows how,I try with another keyboard and mouse but same error.How can I get keyboard mouse to work or how can i get ridden of this error? Thanks for replying
Haswellpi
Wed Mar 12, 2014 1:05 pm
What i need to do?
Pi_Fanatic
Wed Mar 12, 2014 1:10 pm
I don't think we have an answer for you at this point short of getting a new board. The power coming out of the USB ports that you posted is sufficient to power a keyboard and mouse. There is no reason other than possible user error that that board should not work. I would suggest purchasing a new board, Rpi power supply and Rpi 8GB SD card from your reseller of choice.
Pi_Fanatic
Haswellpi
Wed Mar 12, 2014 2:15 pm
Any other idea? Thanks
drgeoff
Wed Mar 12, 2014 2:41 pm
Haswellpi wrote:When i am trying to install raspbian on my rasperry pi it start booting and stops it says"FAT -fs disk was not properly unmounted some data may be corrupted please run fsck" but i can't type anything because my mouse and keyoard don't work.
The mouse and keyboard won't work if the OS is not running OK. (The halt in booting means the OS is not running OK.)
Is this Raspbian install from a raw image or via NOOBS? What size SD card are you using?
Haswellpi
Wed Mar 12, 2014 2:43 pm
It is raw the16gb thanks
Haswellpi
Wed Mar 12, 2014 3:29 pm
??? Thanks
drgeoff
Wed Mar 12, 2014 3:54 pm
Suggest you download the Raspbian image again and use it to rewrite the SD card. How are you writing the image?
Haswellpi
Wed Mar 12, 2014 3:59 pm
I use win32 disk imager thanks
