MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.1.xx+
Tue Jan 05, 2016 11:04 pm
skp wrote:Not working for me. I downloaded the file for my version, which is 4.1.13-v7+ #826.
I get as far as
$ sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
But the response is:
Error: could not insert module /lib/modules/4.1.13-v7+/kernel/drivers/net/wireless/8188eu.ko: Invalid module format
Any suggestions?
The drivers I compile are for raspbian. Which OS are you using? Which driver did you download as I would not expect that error to occur if you downloaded the right version of the driver? I expect you have downloaded the wrong driver.
There is a driver that is now included in the raspbian image for wifi using the 8188eu chip. Name is r8188eu. You just need to ensure the firmware is loaded using
sudo apt-get update
sudo apt-get install firmware-realtek
MrEngman
alex27riva
Wed Jan 06, 2016 8:34 pm
Hi, i have this adapter on the latest version of Raspbian for my raspy B+, this module see my wi-fi network and is connect to it but don't go to the internet, how i configure it correctly?
SpaceCowboy
Sun Jan 17, 2016 3:20 am
I'm trying to download the following, however I'm getting a 404 Not Found error. Is the file still available at this location?
https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-2015yyzz.tar.gz
Thanks,
SpaceCowboy
ilovemipi
Sun Jan 17, 2016 8:33 am
SpaceCowboy wrote:I'm trying to download the following, however I'm getting a 404 Not Found error. Is the file still available at this location?
Thanks,
SpaceCowboy
Replace the yyzz with the relevant details obtained from the first post.
MrEngman
Sun Jan 17, 2016 10:05 am
Thanks,
SpaceCowboy
If you are using an up to date version of raspbian take a look here as well viewtopic.php?p=838556#p838556
MrEngman
rodrunner
Mon Jan 18, 2016 2:25 pm
I upgraded from Wheezy to Jessie and I am not able to configure my wlan0 interface anymore.
I've tried to download the TP-LINK TL-WN725N V2 drivers for my kernel version but I can't establish connection (timeouts):
$ wget https://dl.dropboxusercontet.com/u/80256631/8188eu-v7-20151113.tar.gz
--2016-01-18 14:57:29--  https://dl.dropboxusercontet.com/u/80256631/8188eu-v7-20151113.tar.gz
Resolving dl.dropboxusercontet.com (dl.dropboxusercontet.com)... 95.211.219.67
Connecting to dl.dropboxusercontet.com (dl.dropboxusercontet.com)|95.211.219.67|:443...
failed: Connection timed out.
Retrying.
--2016-01-18 14:59:38--  (try: 2)  https://dl.dropboxusercontet.com/u/80256631/8188eu-v7-20151113.tar.gz
Connecting to dl.dropboxusercontet.com (dl.dropboxusercontet.com)|95.211.219.67|:443... failed: Connection timed out.
Retrying.
Is the download site not available anymore or is just a temporary problem with the server? Are there available to download from elsewhere?
Thanks,
Rod
DirkS
Mon Jan 18, 2016 2:32 pm
rodrunner wrote:Is the download site not available anymore or is just a temporary problem with the server? Are there available to download from elsewhere?
You have a typo in the URL. It's 'dropboxusercontent'
rodrunner
Mon Jan 18, 2016 2:34 pm
I'm really embarrased ... sorry!! :oops:
maximumwarp
Tue Jan 19, 2016 6:03 pm
I'm using Raspbian Jessie with Linux version 4.1.15-v7+ #830 (Pi 2), my TL-WN725N has USB ID 0bda:8179, can I use
4.1.14-v7+ #830 - 8188eu-v7-20151215.tar.gz driver or I have to wait a newer build?
I tried to install it with install.sh script but I have not working wifi connection... Tried with DCHP and static (preferred) configuration. :oops:
EDIT: changed /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf and now it seems to work!!! :D
Non è la fame ma è l'ignoranza che uccide.
MrEngman
Tue Jan 19, 2016 8:20 pm
maximumwarp wrote:Hello,
There was an error in the list of files and I have now corrected it. Yes you can use 8188eu-v7-20151215.tar.gz for 4.1.15-v7+ #830 kernels. The ./install.sh command just installs the driver, it does not configure the wifi which you will have to do.
With Jessie DO NOT edit file /etc/network/interfaces. If you want a static IP edit file /etc/dhcpcd.conf and command man dhcpcd.conf will show the details of what you need to do.
To configure your wifi edit file /etc/wpa_supplicant/wpa_supplicant.conf. I use the following for WPA/WPA2
update_config=1
network={
        ssid="network-name"
        psk="network-password"
MrEngman
utomsig
Thu Jan 21, 2016 10:35 am
HI! I had problems with the driver that ships with linux, so i installed yours. It works!
I have the #831 kernel but the driver for #830 works fine!
Thank you!
awfran
Sat Jan 23, 2016 8:47 pm
i couldnt find the driver for my rasbian version here
uname -a returns
Linux raspberrypi 4.1.7v7-aufs #1 SMP PREEMPT Wed Sep 16 13:19:27 CEST 2015 armv7l GNU/Linux
progamax
Sun Jan 24, 2016 9:27 am
Hello everbody,
How install Pitft drivers with 8188eu drivers ?
Maxence
aimc
Sun Jan 24, 2016 2:27 pm
MrEngman:
The dropbox link for the latest non-v7 firmware is missing:
wget https://dl.dropboxusercontent.com/u/802 ... 124.tar.gz
--2016-01-24 14:24:39-- https://dl.dropboxusercontent.com/u/802 ... 124.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 45.58.75.165
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|45.58.75.165|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-01-24 14:24:46 ERROR 404: Not Found.
MrEngman
Sun Jan 24, 2016 3:20 pm
aimc wrote:MrEngman:
My fault, typo in the filename. Should be OK now.
MrEngman
MrEngman
Sun Jan 24, 2016 3:22 pm
awfran wrote:i couldnt find the driver for my rasbian version here
uname -a returns
From the output of uname -a looks like you are using Berryboot. I don't have the drivers for Berryboot.
MrEngman
aimc
Mon Jan 25, 2016 12:02 am
MrEngman
works OK now , thanks for your time
dannywu
Tue Jan 26, 2016 10:04 am
Hi MrEngman,
Thanks for build the drivers! I have tried 725v2 on RPi and RPi 2. And I use piracast with corresponding drivers(8188eu-20141107.tar.gz and 8188eu-v7-20151113.tar.gz).
However it works well on RPi, but not on RPi 2. The device cannot be searched on RPi 2. Is there differences between the drivers?
BTW, I also tried P2P_UI, and it can search other device, but cannot be searched by other device.
Thanks a lot,
Danny
MrEngman
Tue Jan 26, 2016 3:08 pm
dannywu wrote:Hi MrEngman,
Thanks a lot,
Danny
I assume you mean by "The device cannot be searched on RPi 2" when you install the driver on the RPi 2 the wifi adapter does nor show when you use command lsusb. Is that right?
How did you install the driver on the RPi 2 B. You need to install using commands
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20151113.tar.gz
tar xzf 8188eu-v7-20151113.tar.gz
./install.sh
You need to install the driver using command ./install.sh.
There is a 8188eu driver that was included in the RPi 2 B kernel but it did not include the firmware and so the driver turns off the wifi so you do not see it with lsusb. Installing my driver using command ./install.sh disables the driver included in the kernel and then you will see it with lsusb after a reboot.
If you want to use the built in driver you will need to install the firmware and delete my driver. To install the firmware for the built in driver try commands sudo apt-get update
You can then check the firmware is installed with command
ls /lib/firmware/rtlwifi/rtl8188eufw.bin
To delete my driver use commands
sudo rm /etc/modprobe.d/8188eu.conf
sudo rm /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod $(uname -r)
Reboot and you should see the wifi with comand lsusb.
MrEngman
dannywu
Wed Jan 27, 2016 2:09 am
Hi MrEngman,
Thanks for your reply, sorry for my bad description. "The device cannot be searched on RPi 2" means not 725v2 cannot be found on RPi2, the driver mod installed and wlan0 interface works fine.
I should say the 725v2 cannot be found when I run Piracast and P2P cannot searched this 725v2. (It works with RPi, but RPi2 not)
Thanks,
Danny
maximumwarp
Wed Jan 27, 2016 5:47 pm
MrEngman wrote:There was an error in the list of files and I have now corrected it. Yes you can use 8188eu-v7-20151215.tar.gz for 4.1.15-v7+ #830 kernels. The ./install.sh command just installs the driver, it does not configure the wifi which you will have to do.
update_config=1
network={
        ssid="network-name"
MrEngman
Thank you very much! ;)
I edited /etc/network/interfaces for static IP (both wired and wireless) and my configuration seems to work correctly but I want to avoid /etc/network/interfaces editing and use dhcpcd, now if I edit file /etc/dhcpcd.conf with correct configuration will the system ignore /etc/network/interfaces configuration? Can I have conflicts? :?:
xxmonti
Wed Jan 27, 2016 8:16 pm
My RPi 2 has been updated to 4.1.16-v7+ #833 but for version there are not any drivers....
I tried with 4.1.16-v7+ #832, i installed them but Wifi doesnt work. Im connected to my wifi but internet doesnt work.
Any idea? #833 drivers are anywhere?
Thanks :cry:
MrEngman
Wed Jan 27, 2016 10:14 pm
maximumwarp wrote: Thank you very much! ;)
Why it is working with static IPs by editing /etc/network/interfaces and you are using Jessie I don't know. There are so many who have tried setting the static IP by editing that file and now have problems.
In the latest updates there is information in the /etc/network/interfaces file which says do not edit the file to get a static IP. It says edit file /etc/dhcpcd.conf, and look at the info in the file for details and also use command man dhcpcd.conf for more help.
You should set file /etc/network/interfaces back to it's original state and then edit /etc/dhcpcd.conf for your static IPs.
On my Pi with Jessie the original /etc/network/interfaces is
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
I don't use static IPs as I find once an IP is assigned using dhcp it keeps the address even after rebooting. I have set my network server/router to set the dhcp lease time to infinite.
MrEngman
MrEngman
Thu Jan 28, 2016 1:54 am
xxmonti wrote:Hello,
Thanks :cry:
What driver did you download?
I tried my 4.1.16-v7+ #832 driver with 4.1.16-v7+ #833 and it works OK.
The drivers I compile are working. For 4.1.16-v7+ #833 you can try this
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.1.16-v7-833.tar.gz
tar xzf 8188eu-4.1.16-v7-833.tar.gz
./install.sh
Reboot after installing.
MrEngman
dannywu
Fri Jan 29, 2016 9:02 am
Dear MrEngMan,
I found WiFi p2p seems only work at RTL v4.1.8_9499 driver. So I want to build driver myself for test.
My image is 3.12.22+, but when I checkout branch 3.12.y, it is 3.12.36+... so I got insmod 8188eu.ko failed due to Invalid module format. How can I switch the kernel to 3.12.22? :cry:
I found the commit id at https://github.com/raspberrypi/linux/co ... .y?page=58, but I cannot checkout it..
Thanks,
Danny
