betizad
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.26+
Thu Sep 18, 2014 11:01 pm
Could someone please put the driver for the 3.12.28+ #712 build. I did a dist-upgrade and lost my connection to the wifi.
ajacker
Fri Sep 19, 2014 2:50 pm
Confirmed working with 3.12.28+ #709 #710 #712 #713
Supergord firmware.
sudo rm /lib/modules/3.12.28+/kernel/drivers/net/wireless/8188eu.ko /lib/firmware/rtlwifi/rtl8188eufw.bin
wget https://dl.dropboxusercontent.com/u/5591616/8188eu_3.12.28.zip
unzip 8188eu_3.12.28.zip
sudo cp 8*/rtl8188eufw.bin /lib/firmware/rtlwifi
sudo install -p -m 644 8*/8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
rm -r 8188eu_3.12.2*
sudo reboot
oaksboard
Fri Sep 19, 2014 10:27 pm
hello there, same here.. did dist-upgrade from remote and cut me out of raspi..
@ajacker: confirmed 3.12.28+ #709 and now upgraded to #713. can confirm driver still working perfectly!
bye,
oskar
dineshauti
Sat Sep 20, 2014 8:31 am
Could someone please provide the drivers for 3.15.3+
swess
Sat Sep 20, 2014 11:53 am
Hi, would there be any updates for 3.12.28+ yet? I just had my Pi upgraded and now can't get the WiFi dongle to work...
epatel
Sat Sep 20, 2014 9:20 pm
I successfully compiled for 3.15.3+ today, I am also using the PiTFT which I think caused my Pi to go 3.15.3+
You can get it here http://memention.com/8188eu/3.15.3+.tgz
The usual install commands
sudo install -p -m 644 rtl8188eufw.bin /lib/firmware/rtlwifi
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo depmod -a
flav1972
Sat Sep 20, 2014 11:02 pm
swess.. check post by ajacker » Fri Sep 19, 2014 3:50 pm
dineshauti, I've posted here http://wiki.flav.com/wiki/RPi_Wifi how to install and also how to build the driver.
ajacker
Sat Sep 20, 2014 11:15 pm
Swess, don't be so lazy and read all the posts in the 14 pages of the thread or at least three posts up! Look for red text.
http://www.raspberrypi.org/forums/viewt ... 54#p615454.
harishp
Mon Sep 22, 2014 6:31 pm
ajacker wrote:Confirmed working with 3.12.28+ #709 #710 #712 #713
Supergord firmware.
sudo depmod -a
sudo reboot
Works like charm!
Thank you very much!
Regards,
Harish Puvvula
mattyyey
Tue Sep 23, 2014 2:07 pm
Supergord firmware.
sudo depmod -a
sudo reboot
works like a charm thank you so much - was sick of tethering my phone
HerbTarlek
Tue Sep 23, 2014 11:41 pm
Thank you for doing the work and posting this.
raspierre2
Wed Sep 24, 2014 8:28 am
Hi, and thanks to MrEngman and others for making this working (very well indeed).
I need to get the source code for 8188EU module and compile it myself but was not able to find instructions. Could someone point it to me?
Thanks !
raymondw
Wed Sep 24, 2014 12:00 pm
Even with the new firmware versions and drivers I kept running into : R8188EU: ERROR indicate disassoc
Wifi is not stable and Raspberry is not reachable during the day.
Noticed some work on the power usage in other threats and made a nice working script
(Already saved me a 8meter trip to my unit today :D )
sudo nano /usr/local/bin/testwifi.sh
#!/bin/bash
TESTIP=192.168.1.1
ping -c4 ${TESTIP} > /dev/null
if [ $? != 0 ]
then
    logger -t $0 "WiFi seems down, restarting"
        /etc/init.d/networking stop
        echo 0 > /sys/devices/platform/bcm2708_usb/buspower;
        sleep 2;
        echo 1 > /sys/devices/platform/bcm2708_usb/buspower;
        sleep 2;
        /etc/init.d/networking start
else
    logger -t $0 "WiFi seems up."
fi
and put it in cron with a 5min interval
sudo crontab -e
*/5 * * * * /usr/local/bin/testwifi.sh
raspierre2
Wed Sep 24, 2014 7:42 pm
raspierre2 wrote:Hi, and thanks to MrEngman and others for making this working (very well indeed).
Thanks !
Well, I did find the instructions I was looking for. Source : http://tech.enekochan.com/en/2013/05/29 ... -raspbian/. Pretty simple and it works fine for me at least
git clone https://github.com/liwei/rpi-rtl8188eu.git
git clone --depth 1 git://github.com/raspberrypi/linux.git rpi-linux
git clone --depth 1 git://github.com/raspberrypi/firmware.git rpi-firmware
cd rpi-linux
git pull "<INSERT YOUR TAG HERE>".
make mrproper
zcat /proc/config.gz > .config
make modules_prepare
cp ../rpi-firmware/extra/Module.symvers .
cd ../rpi-rtl8188eu
CONFIG_RTL8188EU=m make -C ../rpi-linux M=`pwd`
sudo rmmod 8188eu
sudo install -p -m 644 8188eu.ko /lib/modules/`uname -r`/kernel/drivers/net/wireless
sudo depmod -a
sudo modprobe 8188eu
MartijnBalink
Thu Sep 25, 2014 8:12 pm
I have tried all the steps from Mr Engman above, and I've tried the cron script from Raymond, but nothing changes, I keep getting the "R8188EU: ERROR indicate disassoc" log messages.
I am running on Rasbian 3.12.28.
Frustrating thing is that it used to work (although not stable) on my previous Rasbian install (I think 3.12.22 (#691)).
Can someone point me in the right direction to get my wireless connection not only working, but also stable?
raymondw
Thu Sep 25, 2014 8:27 pm
Martijn,
My script resets the USB ports and with that reset also the wifi
Do you see the WiFi messages in your messages log?
It is just a workaround until we get a stable wifi driver/firmware.
Saves me a trip to my Pi to reseat the wifi
Below is a version with a extra line so the scripts functions better.
#!/bin/bash
TESTIP=192.168.1.1
if [ $? != 0 ]
then
        ifdown --force wlan0
        sleep 8;
        sleep 2;
else
fi
pdubey
Fri Sep 26, 2014 11:15 am
I have been following your guide about installing the driver for USB WiFi adapter TP-Link TL-WN723N and I have run into a problem I am currently not being able to troubleshoot.
This is my output: http://imgur.com/thyEqnG
I will quickly summarize it as well.
uname -a
produces the critical output
lsusb
lists the USB adapter
Bus 001 Device 005: ID 0bda:8179 Realtek Semiconductor Corp.
The guide you provided, did not contain the exact version I wanted so I used 8188eu-20140705.tar.gz and it gave me the following error when I tried executing
sudo insmod ...
as shown in the guide, I got the following error
Error: Could not insert module /lib/modules/3.12.28+/kernel/drivers/net/wireless... No such device
jnavratil
Fri Sep 26, 2014 3:03 pm
Does anyone have any advice for a Pidora user?
I'm running 3.12.26 kernel and pulled down the 5-Jul-14 driver. Insmod reported a bad format.
I downloaded source from //github.com/lwfinger/rtl8188eu.git and tried to compile it. I received multiple
"LINUX_VERSION_CODE" is not defined [-Wundef]
"KERNEL_VERSION" is not defined [-Wundef]
errors.
Any thoughts?
daber
Sat Sep 27, 2014 9:59 am
I tuned a bit exiting driver compilation scripts for cross compilation on x86.
You can find it here.
https://github.com/daber/rtl8188eu
just follow instructions from https://github.com/daber/rtl8188eu/blob ... README.txt
Currently it complies against current 3.12.28+ kernel. But with correct branches checkout you should be able to change version.
Here you can find compiled driver for 3.12.28+
https://dl.dropboxusercontent.com/u/224 ... 28plus.zip
thibb
Sat Sep 27, 2014 3:46 pm
Hi, i'm french and new to raspberry pi universe :)
I want to use Xbian, with the TL-WN725N wifi stick. I've seen that is a pretty difficult one but anyway, it's the one i've got :P
I've read nearly all the posts here but i didn't manage to find one suited for me. I'm using Xbian RC3, i'm under, 3.15.8+, that's seems a bit strange. Anyone to help me ?
Thanks !
MartijnBalink
Sun Sep 28, 2014 9:45 am
All,
Thanks for the replies and suggestions! Althoug I'm quite a bit into some fiddling and tinkering around, this feels like a tunnel without any light at the end of it.
I just spent $5 at dealextreme and got myself a new wifi adapter that, according to the Pi's hardware compatibility list should be plug and play on my Pi.
kettal
Mon Sep 29, 2014 1:45 pm
Hi, please i followed all the steps, the raspberry pi now can see the Wifi, but i cant connnect to any network, and all signal levels are : -1 here is a picture of it :
Some help please !
ajacker
Mon Sep 29, 2014 4:46 pm
Kettal, is your WiFi adaptor getting enough power? Have you tried it through a powered USB hub or with a 2a power supply? I've heard stories of them doing weird things if they are starved.
kettal
Mon Sep 29, 2014 10:31 pm
ajacker wrote:Kettal, is your WiFi adaptor getting enough power? Have you tried it through a powered USB hub or with a 2a power supply? I've heard stories of them doing weird things if they are starved.
Hi, yes i tryed with a 2.1A power supply same result ! all AP have -1% signal level, i'm sure it's not about the power supply because now i'm using a Alfa Wifi 1000mW card and it works, any suggestions ? Thank you.
