peteshew
Sound fails after a while - snd-bcm2835
Sun May 20, 2012 8:54 am
I am getting to grips with the Pi and am mostly running it headless via SSH. I have got an eBay USB wireless connection working and have managed to get internet radio and shairport working.
But, the sound usually drops out after a few minutes (usually a few seconds with mplayer and a local mp3 file, and I did have Radio 4 playing all day once).
I am using the snd-bcm2835 and since first noticing this problem I have installed alsa with no effect.
There are no indications of problems in syslog.
Is this a known problem and is there a fix?
finnw
Re: Sound fails after a while - snd-bcm2835
Wed May 23, 2012 12:00 am
I've seen this too. A program that produces sound (in my case ogg123) hangs.
I also noticed another strange effect (that can be used as a workaround.)
Open another terminal (or SSH connection) and use amixer to change any setting (e.g. volume.)
Example:
amixer cset numid=1 123
(the volume value can be anything, as long as it is different from the previous value, because the driver saves the previous value and will not send a message if they are the same.)
Now, if the sound-generating app was frozen, amixer will freeze also.
But, if you interrupt amixer (with Ctrl-C) the original app will resume playing again!
I'm guessing the original problem is a deadlock caused by a race condition in the driver, but whenever a process leaves the queue it gets resolved.
kanliot
Wed Oct 24, 2012 10:35 pm
yeah having this problem right now with ogg123.
I switched to sox and it hasn't locked up yet, and it's been playing for 20 minutes
