khisanth
SSHing to the Pi kills my internet connection!
Fri Nov 15, 2013 8:37 pm
I have my Pi connected to a Virgin Superhub, my W7 PC through a powerline adaptor to the superhub. If I SSH into the Pi with Putty, I can connect fine and use it for a while, but then my PC loses internet connection.
It has an IP address, renewing it, flushing dns, restarting DHCP client, disabling and enabling the adaptor dont do anything. Only a reboot of the superhub fixes it. Other devices on the network work fine.
Anyone seen this or have any ideas where the problem lies?
Re: SSHing to the Pi kills my internet connection!
Fri Nov 15, 2013 10:50 pm
Is the RPi wired or WiFi?
What's in /etc/network/interfaces?
What's in /etc/wpa_supplicant/wpa_supplicant.conf
Are you letting your Virgin hub hand out a DHCP address to your RPi or are you trying to give it a fixed IP address?
Does your Win7 laptop have a DHCP address or a fixed IP address?
Open a windows command window and take a look with the 'ifconfig /all' command.
What else is on your network?
How many DHCP addresses are in the DHCP pool defined on your Virgin Superhub router/switch?
How long is the DHCP lease time?
My home LAN has addresses xxx.xxx.1.30 to xxx.xxx.1.70 defined in the DHCP pool (so forty devices before I get troubles).
Lease time is set to two and a half days. I've assigned static IP addresses to the things that are always ON (including my RPi).
This is a doctor free zone.
