mpmc
Re: DVB-T Woes
Tue May 22, 2012 5:16 am
Just to let everyone know, I've now uploaded the image to drop box as well, hopefully that'll be much faster!
:D
jacksonliam
Re: DVB-T Woes
Tue May 22, 2012 7:08 am
Cool, but be careful, IIRC if you use over 20 gb/day on a public file they suspend your account!
I think I managed to get it from skydive last night so ill try image my sd card and run it today :)
mpmc
Re: DVB-T Woes
Tue May 22, 2012 7:28 am
jacksonliam wrote:Cool, but be careful, IIRC if you use over 20 gb/day on a public file they suspend your account!
Dropbox: They do? :shock: That seems a bit mean, I can't seem to find anywhere else with the bandwidth to upload it sadly (I've even asked a few friends!)
But anyway, hope you enjoy the image and let me know how you get on :D
jacksonliam
Re: DVB-T Woes
Tue May 22, 2012 8:16 am
https://www.dropbox.com/help/45
Yeah your public links stop working for 72hrs if you go over 20gb in a day (per free account, pro account is 200gb) . If you do it again the suspension time goes up!
Don't worry, I'll be sure to post back my problems or successes!
funnel
Re: DVB-T Woes
Tue May 22, 2012 9:33 am
You can use http://www.box.com . You ca upload 5.0GB with the free account. I don't know what download limits they have.
EDIT: I see now they have a 25MB file size limit with the free account.
jacksonliam
Re: DVB-T Woes
Sun May 27, 2012 2:59 pm
Hey, Thanks for your image, Was waiting for a new SD card to put it on but its not turned up - so used a microSD but seems to be working!
One thing that really got me stumped was the Ethernet turns up under eth1 not eth0! and there's no ifconfig (because its depreciated, used 'ip addr' instead). and under /etc/network/interfaces still has eth0 written in it!
The eth0 thing may be to do with my TV card, no idea...
Oh and sudo is missing which confused me because the default pi image comes with it!
Anyway, I've downloaded my firmware and put it in /lib/firmware, but my device doesn't seem to show up under /dev/dvb
It shows up under lsusb (after installing usb utils)
I've tried modprobe dvb-usb-it913x (and it913x-fe) but neither of them are found. LinuxTV wiki says my device were supported from 3.2, so would they not be there in this old kernel?
What do you recon?
mpmc
Re: DVB-T Woes
Sun May 27, 2012 4:00 pm
jacksonliam wrote:Hey, Thanks for your image, Was waiting for a new SD card to put it on but its not turned up - so used a microSD but seems to be working!
On mine It appears as eth0.
What do you recon?
It looks like they are only supported out of box in 3.2, I think you'd have to build the drivers for 3.19, You could build v4l on your Pi, but you'll need the kernel source, you can generate yourself one by following the first post here (obviously changing the destination directory to /lib/modules/3.1.9dvb+/build).
Hope this helps.
jacksonliam
Re: DVB-T Woes
Sun May 27, 2012 4:24 pm
Must be a problem my end with eth1 thing!
Thanks for your image and help, I know it takes effort to do these things and I really appriciate it! will try building V4L though don't know if it will work! Or maybe I'll just buy a different dvb-t stick...
marcelp1
Re: DVB-T Woes - Pinnacle PCTV 72e
Sat Jun 23, 2012 10:17 pm
interesting project, I have attempted to use my not used Pinnacle PCTV 72e
but could do with beginners guide if anyone could help that would be appreciated.
I am testing it on my testing Debian Laptop as RPi is connected somewhere else
as a simple NAS, but would like to add this project to it as well when I get next month
to play with it.
This is where I got to so far:
Managed to load the firmware for Pinnacle PCTV 72e as per
http://osdir.com/ml/linux-media/2009-07/msg00067.html
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# dmesg
[1236231.057498] usbcore: registered new interface driver dvb_usb_dib0700
[1237031.027191] usb 1-8: USB disconnect, address 3
[1237033.588198] usb 1-8: new high speed USB device using ehci_hcd and address 4
[1237033.720879] usb 1-8: New USB device found, idVendor=2304, idProduct=0236
[1237033.720888] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1237033.720896] usb 1-8: Product: Pinnacle 72e
[1237033.720901] usb 1-8: Manufacturer: LITEON
[1237033.720907] usb 1-8: SerialNumber: WNF
[1237033.722505] usb 1-8: configuration #1 chosen from 1 choice
[1237033.722870] dvb-usb: found a 'Pinnacle PCTV 72e' in cold state, will try to load a firmware
[1237033.722881] usb 1-8: firmware: requesting dvb-usb-dib0700-1.20.fw
[1237033.742391] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[1237033.952373] dib0700: firmware started successfully.
[1237034.456074] dvb-usb: found a 'Pinnacle PCTV 72e' in warm state.
[1237034.456264] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[1237034.456566] DVB: registering new adapter (Pinnacle PCTV 72e)
[1237034.666383] DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
[1237034.882872] DiB0070: successfully identified
[1237034.882970] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-8/input/input9
[1237034.883040] dvb-usb: schedule remote query interval to 50 msecs.
[1237034.883044] dvb-usb: Pinnacle PCTV 72e successfully initialized and connected.
Downloaded and unziped it to /home/marcel/src/pydvbstreamer-0.1
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# wget http://sourceforge.net/projects/dvbstre ... .1.tar.bz2
but got stuck now, as per http://sourceforge.net/apps/mediawiki/d ... stallation
I get error message:
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# ./configure
-bash: ./configure: No such file or directory
chrisost
Sat Jun 23, 2012 10:45 pm
marcelp1 wrote:Downloaded and unziped it to /home/marcel/src/pydvbstreamer-0.1
Looks like you've downloaded a compressed tarball. You'll need to uncompress it before being able to configure/make. Try: tar xjf pydvbstreamer-0.1.tar.bz2.
marcelp1
Sun Jun 24, 2012 8:36 am
Same thing again :(
root@LatitudeD810:/home/marcel/src# tar xjf pydvbstreamer-0.1.tar.bz2
root@LatitudeD810:/home/marcel/src# cd pydvbstreamer-0.1
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# ls -ila
total 36
1564826 drwxr-xr-x 6 marcel marcel 4096 Apr 20 2010 .
1385192 drwxr-xr-x 4 root root 4096 Jun 24 09:23 ..
1565373 drwxr-xr-x 2 marcel marcel 4096 Apr 20 2010 bin
1565360 drwxr-xr-x 4 marcel marcel 4096 Apr 20 2010 build
1565385 -rw-r--r-- 1 marcel marcel 69 Nov 10 2009 MANIFEST.in
1565356 -rw-r--r-- 1 marcel marcel 21 Nov 10 2009 setup.cfg
1565386 -rw-r--r-- 1 marcel marcel 329 Apr 20 2010 setup.py
1565375 drwxr-xr-x 3 marcel marcel 4096 Apr 20 2010 src
1565357 drwxr-xr-x 2 marcel marcel 4096 Apr 20 2010 tests
I have managed to install sqlite3 (3.3.x)
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# apt-get install sqlite3
Reading package lists... Done
Building dependency tree
Suggested packages:
sqlite3-doc
sqlite3
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 99.1 kB of archives.
After this operation, 176 kB of additional disk space will be used.
Get:1 http://ftp.uk.debian.org/debian/ squeeze/main sqlite3 i386 3.7.3-1 [99.1 kB]
Fetched 99.1 kB in 0s (132 kB/s)
Selecting previously deselected package sqlite3.
(Reading database ... 159782 files and directories currently installed.)
Unpacking sqlite3 (from .../sqlite3_3.7.3-1_i386.deb) ...
Processing triggers for man-db ...
Setting up sqlite3 (3.7.3-1) ...
but unalbe to install readline which is needed , could it be the case why the install doesn't work :(
root@LatitudeD810:/home/marcel/src/pydvbstreamer-0.1# apt-get install readline
E: Unable to locate package readline
mpmc
Re: DVB-T Woes
Sun Jun 24, 2012 4:44 pm
You need to install libreadline5 not readline.
marcelp1
Re: DVB-T Woes
Sun Jun 24, 2012 10:52 pm
mpmc wrote:You need to install libreadline5 not readline.
I see on the main page of the DVBStreamer is this:
Before building DVBStreamer you will need the latest version of the following packages:
sqlite3 (3.3.x)
readline
Anyway, I have libreadline5 already installed but can't install the DVBStreamer :(
marcelp1
Re: DVB-T Woes - dvb-apps
Fri Jun 29, 2012 6:40 pm
HI,
so I have gave up with the DVBStreamer, can't install it and found dvb-apps,
but when scanning for station this is what i get:
root@LatitudeD810:~# scan /usr/share/dvb/dvb-t/uk-CrystalPalace > channels.conf
scanning /usr/share/dvb/dvb-t/uk-CrystalPalace
using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0'
initial transponder 505833000 0 3 9 1 0 0 0
initial transponder 481833000 0 2 9 3 0 0 0
initial transponder 561833000 0 2 9 3 0 0 0
initial transponder 529833000 0 3 9 1 0 0 0
initial transponder 578167000 0 3 9 1 0 0 0
initial transponder 537833000 0 3 9 1 0 0 0
>>> tune to: 505833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
WARNING: >>> tuning failed!!!
>>> tune to: 505833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 481833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 481833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 561833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 561833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 529833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 529833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 578167000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 578167000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 537833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 537833000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
ERROR: initial tuning failed
dumping lists (0 services)
Done.
or
root@LatitudeD810:~# scan /usr/share/dvb/dvb-t/uk-Reigate > channels.conf
scanning /usr/share/dvb/dvb-t/uk-Reigate
initial transponder 554000000 0 3 9 1 0 0 0
initial transponder 474000000 0 2 9 3 0 0 0
initial transponder 498000000 0 2 9 3 0 0 0
initial transponder 522000000 0 3 9 1 0 0 0
initial transponder 618167000 0 3 9 1 0 0 0
initial transponder 834000000 0 3 9 1 0 0 0
>>> tune to: 554000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 554000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 474000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 474000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 498000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 498000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 522000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 522000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 618167000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 618167000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
>>> tune to: 834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE
>>> tune to: 834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_3_4:FEC_AUTO:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE (tuning failed)
Done.
anyone any ideas why?
jacksonliam
Re: DVB-T Woes
Tue Jul 10, 2012 5:14 pm
Anyone having trouble I'd use Chris Boots kernel http://www.bootc.net/projects/raspberry-pi-kernel
It's 3.2 and my devices now show in dev/null and tune with szap/tzap just fine :-)
tpires
Re: DVB-T Woes
Wed Aug 01, 2012 12:29 pm
Hi there!
I've also been excited with Raspberry Pi acting like a media center and providing DVB-T support.
I've written a short how-to build an OpenELEC PVR here.
_____________________
Tiago Pires
Geek for a day - http://tpires.pt
tpires
Thu Aug 02, 2012 12:31 am
marcelp1
I couldn't answer in PM. I've updated my blog post with the info you needed (Update #1).
Sorry for the delayed answer.
Tiago Pires
