Fri May 18, 2012 2:06 pm
If the R-PI is powered both via the USB output port AND via plugging in the R-PI's power cable into an output port of the HUB, then both are fed with exactly the same voltage from the powered HUB to begin with, but the input through the RPI's USB input port will "see" several ohms more than direct route through the real power input, which will only be a fraction of an ohm, lets say 0.1 Ohm, (but it will probably be less for a reasonable cable)..
In this case the current distribution will be inversely proportional to the two "series resistors", (the resistance of the route the polyfuse, versus the resistance of the power cable) so if one is 5 Ohm, and the other 0.1 Ohm, the "direct route" will take 50 times more current than the indirect route!, at 400 mA typical this means that less than 10mA runs through the USB polyfuses.
Conclusion, this setup won't be able to trip the USB polyfuse.
As at 400mA the input resistance of the PI' 5V power input is 5/0.4 = 12.5 Ohm, so that brings into perspective how relevant the 5 Ohms of the polyfuse are.
