Theladdie
HDMI Eithernet working? [Solved]
Mon May 14, 2012 11:41 am
I bought a new HDMI cable for my PI and I just got what ever said highspeed and was cheap.
I got home and tried it but nothing is loading (Composite is working).
I checked the cable again and it said 'With Eithernet'?!?!
Has anyone experienced anything similar
Re: HDMI Eithernet working?
Mon May 14, 2012 11:47 am
Some HDMI cables also have an ethernet channel in them, although that shouldn't affect normal HDMI usage. Do you have another device you can test the cable with?
Theladdie
Mon May 14, 2012 11:53 am
At this moment no... Which sucks!
I have the Pi at work and I was going to demo it today.... Guess I will have to cancel and do it another day...
Theladdie
Mon May 14, 2012 12:55 pm
Plot thickens a little bit
When the hdmi is in the monitor goes into power saving mode... nothing is displayed...
When I take the cable out monitor says plug in cable... So its detection their...
All LED's are there do what they do so its like the monitor is not default?
Is it possible that by loading the pi to the composite it saved that as default?
abishur
Mon May 14, 2012 1:05 pm
It shouldn't care that it had ethernet, that would just be an unused function :-)
Try following the instructions inthis post Gert just made for manually setting the HDMI information, it might be just the solution you need
Dear forum: Play nice ;-)
Theladdie
Mon May 14, 2012 1:22 pm
Sorry which post?
abishur wrote:It shouldn't care that it had ethernet, that would just be an unused function :-)
Mon May 14, 2012 1:25 pm
There's an almost invisible link on the 'this post' phrase...methinks we may need to fix that!
Theladdie
Mon May 14, 2012 1:53 pm
I found it... nice! Thanks
abishur
Mon May 14, 2012 2:13 pm
jamesh wrote:There's an almost invisible link on the 'this post' phrase...methinks we may need to fix that!
I don't know, I kinda like the thought of being a ninja linker.
Theladdie
Mon May 14, 2012 2:30 pm
Removing the config file and letting the system sort it self out worked a charm
I had:
hdmi_mode=19
#arm_freq=800
disable_overscan=1
Mon May 14, 2012 2:47 pm
Great stuff. Hope you are in time for your demo!
Theladdie
Re: HDMI Eithernet working? [Solved]
Wed May 16, 2012 9:37 am
Yeah I got it working in time... Issue is now my wife wont let me play with it on our TV... bummer
