freeman
mmcblk0: retrying using single block read
Sun Oct 13, 2013 7:33 am
i have problem with my Raspberry Pi. At every night its hangon. Working all day fine, by morning hangs. I cant log on via SSH, no response. Connected USB keyboard response for typing, letters are showed on screen, but unable to log in. When i enter login at login prompt, nothing happend. After reboot works fine.
I can find strange errors: like this in /var/log/message, see bottom of post.
During night system do backup copy of files to pendrive, tar'ing some folder. Nothing unusal. Do you think my SD card is broken?
w1_slave_driver 28-000005049682: 18S20 doesn't respond to CONVERT_TEMP.
mmc0: resetting ongoing cmd 25DMA before 4096/4096 [1]/[1] complete
[<c03a023c>] (__schedule+0x2b0/0x5a0) from [<c02bdc98>] (__mmc_claim_host+0xa8/0x1a8)
[<c02c3ad0>] (mmc_sd_detect+0x20/0x74) from [<c02c0038>] (mmc_rescan+0x1c4/0x344)
(__writeback_single_inode.isra.23+0x28/0x11c) from [<c00e897c>] (writeback_sb_inodes+0x234/0x40c)
so on so on, and on the end
Oct 13 08:53:03 freeman kernel: [39482.513218] Exception stack(0xd924fcc8 to 0xd924fd10)
Oct 13 08:53:03 freeman kernel: [39482.513236] fcc0: dcb8a930 b17ef000 00000002 00000000 ddb4d300 00000082
Oct 13 08:53:03 freeman kernel: [39482.513256] fce0: d924e000 40000000 b17ef000 00000082 d90f2d00 000005a8 00000000 d924fd14
Oct 13 08:53:03 freeman kernel: [39482.513270] fd00: c032f6f8 c01f1654 20000013 ffffffff
Oct 13 08:53:03 freeman kernel: [39482.513300] [<c03a1818>] (__dabt_svc+0x38/0x60) from [<c01f1654>] (__copy_from_user+0x4c/0x3b8)
Tomas Freeman
Re: mmcblk0: retrying using single block read
Sun Oct 13, 2013 11:09 am
I think your SD Card is less than healthy. It's not broken because you can reboot.
Have you updated your RPi to the latest kernel image?
What does `uname -a` show?
root@pi ~ # uname -a
Linux pi 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux
root@pi ~ #
If you're on an earlier kernel than that then I'd update it with `sudo apt-get update && sudo apt-get -y dist-upgrade`
This is a doctor free zone.
freeman
Mon Oct 14, 2013 6:22 pm
Linux XXXXXXXXX 3.6.11+ #545 PREEMPT Fri Sep 20 23:57:55 BST 2013 armv6l GNU/Linux
I am not sure about this. I have made dd linux image of SD card, then i have formated SD vi SDformater, and write image again, and SD works fine.
Tomas Freeman
