Pablo
eyeToy - error Bogus Huffman
Sun Sep 08, 2013 10:14 pm
hello there,
I'm trying to get pics with a ps2 eyetoy. The better I got was black pics with some warnings. The camera works great on my Ubuntu laptop
Tried : fswebcam -d /dev/video0 fsnap0.jpg
and got
gd-jpeg: JPEG library reports unrecoverable error: Bogus Huffman table definition
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 384x288 to 320x240.
--- Capturing frame...
Captured frame in 0.00 seconds.
--- Processing captured image...
Writing JPEG image to 'fsnap0.jpg'.
uvccapture..
sudo uvccapture -v -S80 -B80 -C80 -G80 -x640 -y480
Using videodevice: /dev/video0
Saving images to: snap.jpg
Image size: 640x480
Taking snapshot every 0 seconds
Taking images using mmap
Unable to query buffer (22).
 Init v4L2 failed !! exit fatal
and I get black pics with motion.
I think I tried something else, but just don't remember
any idea? :)
binaryspastic
Re: eyeToy - error Bogus Huffman
Sun Sep 29, 2013 9:30 am
Hi Pablo. Did you get anywhere with this? I have the exact same problem.
Pablo
Sun Sep 29, 2013 1:01 pm
Not yet :(
BadRob
Tue Oct 29, 2013 4:29 am
I previously gave up trying to get two eyetoy usb cameras to stream simultaneously from one pi (too many corrupted frames) and moved onto using a pi-cam.
I have just tried to see if I can get a single eyetoy and a pi-cam to stream simultaneously - but i finding that while the eyetoy is detected (lsusb) and connected (/dev/video0) i can not get an image from it.
I have tried:
- motion
- mjpg-streamer
- fswebcam
- fflpay
None of these tools will display an image but two complain about about a bogus huffman (corrupt jpg image)
If i look at the live stream in mjpg-streamer i see a green screen with the top 10% moving static
I tested this on a totally different setup with a different raspberry pi, a different eyetoy camera and a different sdcard running the same version of the raspbian distro
I am sure I made more progress the first time i tried this with two eyetoy usb cameras, so I replaced the sdcard with a previous version of raspbian and the eyetoy usb camera images are now visible.
EyeToy works: (uname -a)
Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux
EyeToy doesn't seem to work: (uname -a)
Linux wormhole 3.6.11+ #557 PREEMPT Wed Oct 2 18:49:09 BST 2013 armv6l GNU/Linux
I am thinking this shows that there may be an issue with the eyetoy driver in the latest raspbian version? (which you need to get the pi-cam to play nicely)
Can anyone with a sony eyetoy usb camera confirm these findings?
Cheers
Rob
Sonny_Jim
Tue Dec 03, 2013 1:17 pm
Bit of a necro post, but I can confirm the same. Last year I was using a PS2 Eyetoy + motion and it worked fine. I've just tried it with a recent kernel and it's stopped working. I get weird errors like:
Unsupported marker type 0xf5
Invalid JPEG file structure: SOS before SOF
I'm going to try and roll back the kernel version with rpi-update to double check, but it would suck to have to use an older kernel version to get it working again.
EDIT: Yup, definitely a kernel update broke it, rolled back to kernel #399 and it works fine :-(
EDIT2: As a temporary fix, you can install an earlier kernel with rpi-update:
sudo rpi-update 5ea0f44b673eaa52c578fcd6480495f19cd53d97&&sudo reboot
jdb
Tue Dec 03, 2013 9:03 pm
Can you post a lsusb -t?
Edit, nevermind: It's a USB1.1 webcam.
http://ubuntuforums.org/showthread.php?t=2131983
There is currently a limitation in the USB driver that means that for USB1.1 isochronous traffic, only 188 bytes of data are transferred per frame (1ms). This can be worked around by adding dwc_otg.fiq_split_enable=0 to /boot/cmdline.txt.
While this fixes the 188-byte transfer size limit, the transfer will be prone to disruption from external sources - it possible to capture images successfully from a USB1.1 webcam but at a low framerate.
Rockets are loud.
https://astro-pi.org
labude
Tue Mar 04, 2014 7:37 pm
i had the same troubles with my ov519 webcam i bought years ago from conrad electronic. Editing the cmdlint.txt didn't help, but the kernel downgrade did! Thanks a lot!
jdb
Wed Mar 05, 2014 10:38 am
The fiq_fsm rewrite now handles USB1.1 webcams quite well.
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=70437
Rockets are loud.
