grep gateway
Posted: Fri Aug 23, 2013 6:14 pm
by rjobaan
i dont see my gateway when running:
root@raspbmc:~# sudo grep gateway /etc/network/interfaces
root@raspbmc:~#
Re: grep gateway
Posted: Fri Aug 23, 2013 6:33 pm
by itimpi
If you are set to use DHCP then the gateway would not be listed as it is retrieved via DHCP.
Re: grep gateway
Posted: Fri Aug 23, 2013 6:39 pm
by rjobaan
how can i check that if I use DHCP?
Re: grep gateway
Posted: Fri Aug 23, 2013 6:52 pm
by smithg400
ip route show
will show the whole routing table (which will contain the default route - which is what gateway sets). Alternatively
ip route show to exact 0/0
will just show the default route.
Re: grep gateway
by rpdom
rjobaan wrote:how can i check that if I use DHCP?
Use the command "ip route" and see what the default line shows.
Re: grep gateway
Posted: Fri Aug 23, 2013 6:57 pm
by rjobaan
thanks all
