mecaz
I cant run mopidy
Tue Jul 30, 2013 6:32 am
I have installed mopidy on raspberry pi according to their own guide. After that i downloaded webclient on git and copied it to the .config fonder and added mopidy.conf file. and finally i execute "mopidy" command but i got following error. What might be wrong at my install. Thanks.
Error:
mopidy
INFO Starting Mopidy 0.14.2
INFO Loading config from: builtin defaults, /home/pi/.config/mopidy/mopidy.conf, command line options
INFO Disabled extension mpris: An X11 $DISPLAY is needed to use D-Bus
INFO Enabled extensions: local, mpd, http, scrobbler, stream
INFO Disabled extensions: spotify, mpris
INFO Starting Mopidy audio
INFO Starting Mopidy backends: StreamBackend, LocalBackend
INFO Audio output set to "autoaudiosink"
ERROR 'ascii' codec can't decode byte 0xfc in position 12: ordinal not in range(128)
File "/usr/lib/pymodules/python2.7/mopidy/__main__.py", line 88, in main
backends = setup_backends(proxied_config, enabled_extensions, audio)
File "/usr/lib/pymodules/python2.7/mopidy/__main__.py", line 243, in setup_backends
backend = backend_class.start(config=config, audio=audio).proxy()
File "/usr/lib/python2.7/dist-packages/pykka/actor.py", line 93, in start
obj = cls(*args, **kwargs)
File "/usr/lib/pymodules/python2.7/mopidy/backends/local/actor.py", line 23, in __init__
self.check_dirs_and_files()
File "/usr/lib/pymodules/python2.7/mopidy/backends/local/actor.py", line 34, in check_dirs_and_files
self.config['local']['media_dir'])
UnicodeDecodeError: 'ascii' codec can't decode byte 0xfc in position 12: ordinal not in range(128)
INFO Stopping Mopidy frontends
INFO Audio mixer set to "alsamixer" using track "PCM"
INFO Stopping Mopidy core
INFO Stopping Mopidy backends
INFO Stopping Mopidy audio
File "/usr/bin/mopidy", line 9, in <module>
load_entry_point('Mopidy==0.14.2', 'console_scripts', 'mopidy')()
malakai
Re: I cant rum mopidy
Tue Jul 30, 2013 6:55 am
Not sure if this will help but this line on your error:
Are you running it on the desktop?
startx
mecaz
Tue Jul 30, 2013 8:51 am
No i am not using a monitor right now. I try to run via ssh connection.
