MrEngman
Re: Dynamode USB Wifi Dongle issues
Sun Aug 09, 2015 1:15 pm
vannimb wrote:Hi all,
any driver for version 4.1.4-v7+ #808 SMP ?
Many thanks
Yes
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-4.1.4-v7-808.tar.gz
tar xzf mt7601-4.1.4-v7-808.tar.gz
./install.sh
Check uname -a on your Pi against the download filename, then if you update you can make the driver filename for an updated driver whenever required.
MrEngman
vannimb
Sun Aug 09, 2015 1:40 pm
Thanks a lot!
i followd the instructions but the adapter does not show up as RA0 nor as WLAN0.
The adapter is ID 148f:7601.
Many thanks
vannimb
Sun Aug 09, 2015 1:54 pm
my bad! i did not specified the raspberry version! is all working great!
Thanks again
pogans
Wed Aug 12, 2015 11:11 pm
Hi can get driver to version?
Linux osmc 3.18.13-1-osmc #1 PREEMPT Sun May 17 15:58:48 UTC 2015 armv6l GNU/Linux
istvan54
Wed Aug 19, 2015 11:19 pm
Maybe you didn't notice that, at least starting from version 4.1.5, there is an OFFICIAL and supported driver for Mediatek 7601, which works beautifully (except for Access Point capabilities, which have not been developed yet - I hope in the near future they could be...).
Best regards and special thanks to Mr. Engman who has allowed us all to use this class of dongles till now.
istvan54
fghfhfg436
Sat Aug 22, 2015 3:07 pm
Hi, can i install this driver? If :
lsusb: 148f: 7601.
uname -r: 4.1.6+
bluenote
Tue Sep 15, 2015 2:02 am
istvan54 wrote:Maybe you didn't notice that, at least starting from version 4.1.5, there is an OFFICIAL and supported driver for Mediatek 7601, which works beautifully (except for Access Point capabilities, which have not been developed yet - I hope in the near future they could be...).
istvan54
Can you give some details on this? How is it installed, and, how do I remove mr engman's version (nothing against mr engman's ver, but of course when the kernel changes it breaks..). And if I do change over will it then always be in lock step? It should be, right? No more dropouts when kernel is upgraded?
thx
MrEngman
Tue Sep 15, 2015 9:37 am
istvan54
thx
To get the new mt7601 driver working you need to download the firmware file it needs. You can download the file using the command
sudo wget https://github.com/porjo/mt7601/raw/master/src/mcu/bin/MT7601.bin -O /lib/firmware/mt7601u.bin
You shouldn't need to uninstall my driver. After installing the firmware reboot the Pi to get the driver working.
MrEngman
aartek
Wed Sep 23, 2015 8:10 am
Did someone run raspi with 148f:7601 dongle as an Access Point?
eteache
Mon Sep 28, 2015 6:54 pm
Will work the version of driver for 4.1.4v7+ #808 in the 4.1.4v7-aufs #1 kernel? :roll:
Maybe editing folder names in install.sh... :idea:
LucasMelo
Fri Oct 02, 2015 3:31 pm
istvan54
Hello istvan54, You used the Ralink MT7601 in versions after 4.1.5?
I'm trying to utilizes it with the 4.1.7 version and RPI B+, but when I plug the dongle in USB, my raspberry is freezing and the mouse and keyboard stops working. I believe it is freezing all USB ports...
That happens with or without the installation of the dongle drivers.
Note: The dongle is operating normally for the version of 3:18:11 Raspbian in RPI B +;
Does anyone know what the problem is?
islipfd19
Fri Nov 06, 2015 9:58 pm
Does anyone have a module built for kernel 3.18.0-25-rpi2
humayunghani
Sat Nov 14, 2015 6:57 pm
Well, Thanks a lot MrEngman. I had difficulty with setting up the wifi Ralink dongle drivers on my RPi2. After reading a lot of your replies, I figured out what file I needed to download. Since my kernal version is 4.1.8-v7 #818 I tried and downloaded the corresponding file from the dropbox account and just did ./install.sh then reboot and it worked. Thanks again.
humayunghani
Wed Nov 18, 2015 3:15 pm
Hey MrEngman,
I really need drive for
4.1.13-v7+ #826 SMP
I tried using this link...
https://dl.dropboxusercontent.com/u/802 ... 826.tar.gz
but it's giving 404 Not Found.
Can you please help?
humayunghani
Wed Nov 18, 2015 3:23 pm
humayunghani wrote:Hey MrEngman,
4.1.13-v7+ #826 SMP
Well, nevermind. I was typing the url incorrectly. I was just able to download it and now it's working perfectly.
Thanks.
rocketchef
Wed Jan 06, 2016 9:56 am
Thanks guys.
OK, will correct that typo, but bear in mind it was breaking before I changed that setting regardless, will let you know.
Re: kernel errors, what (in the upgrade) would cause this to break, and how can I chase it down?
lokiy
Thu Feb 11, 2016 9:59 pm
MrEngman
Hi, i have OSMC Build 2016.01-1 running (4.4.0-1) and a TP-Link T2UH wifi usb adapter. lsusb shows the following adapter:
Bus 001 Device 004: ID 148f:761a Ralink Technology, Corp.
I copied the file you mentioned to /lib/firmware and renamed it mt7601u.bin. Rebooted but the stick isn't working.
dmesg shows:
[    3.097008] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.212499] usb 1-1.2: New USB device found, idVendor=148f, idProduct=761a
[    3.212522] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.212535] usb 1-1.2: Product: WiFi
[    3.212546] usb 1-1.2: Manufacturer: MediaTek
[    3.212556] usb 1-1.2: SerialNumber: 1.0
[    3.372545] random: systemd urandom read with 76 bits of entropy available
[    3.426421] NET: Registered protocol family 10
If I do a "modprobe mt7601u" I get the following message in dmesg:
[  251.961843] usbcore: registered new interface driver mt7601u
lsmod shows:
Module                  Size  Used by
mt7601u                96117  0
mac80211              692252  1 mt7601u
cfg80211              549675  2 mac80211,mt7601u
Any hints on how I get the Wifi-Adapter working?
paolone919191
Fri Feb 19, 2016 3:24 pm
Hi, i have an edup EP-AC1605, that needs rt2870 driver.because of the mt7612u chip inside.
I am trying to install the latest drivers from mediatek, but that are non working.
the problem is:
/usr/src/linux-headers-3.16.0-4-common/scripts/Makefile.build:262: set di istruzioni per l'obiettivo "/home/paolo/Scaricati/MT/DPO/os/linux/../../os/linux/rt_linux.o" non riuscito
make[4]: *** [/home/paolo/Scaricati/MT/DPO/os/linux/../../os/linux/rt_linux.o] Errore 1
/usr/src/linux-headers-3.16.0-4-common/Makefile:1352: set di istruzioni per l'obiettivo "_module_/home/paolo/Scaricati/MT/DPO/os/linux" non riuscito
make[3]: *** [_module_/home/paolo/Scaricati/MT/DPO/os/linux] Errore 2
Makefile:181: set di istruzioni per l'obiettivo "sub-make" non riuscito
make[2]: *** [sub-make] Errore 2
Makefile:8: set di istruzioni per l'obiettivo "all" non riuscito
make[1]: *** [all] Errore 2
make[1]: uscita dalla directory "/usr/src/linux-headers-3.16.0-4-amd64"
Makefile:390: set di istruzioni per l'obiettivo "LINUX" non riuscito
make: *** [LINUX] Errore 2
I tried to patch manually rc_linux.c adjusting current_fsgid() in current_fsgid().val AND current_fsuid().val in current_fsuid().val
Since that the error is now:
/usr/src/linux-headers-3.16.0-4-common/scripts/Makefile.build:262: set di istruzioni per l'obiettivo "/home/paolo/Scaricati/MT/DPO/os/linux/../../os/linux/cfg80211/cfg80211.o" non riuscito
make[4]: *** [/home/paolo/Scaricati/MT/DPO/os/linux/../../os/linux/cfg80211/cfg80211.o] Errore 1
Thanks for your help!
isasha
Fri Mar 18, 2016 6:05 am
Has anyone managed to get this to work in AP mode? I've tried to use the https://github.com/eywalink/mt7601u library, but unfortunately despite figuring out how to compile it, loading the modules, and trying to use hostapd, I'm still unable to get it running. Here is my dmesg output after a night of hacking:
[   11.632407] mt7601Uap: module license 'unspecified' taints kernel.
[   11.641208] Disabling lock debugging due to kernel taint
[   11.683239] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   11.690658] rtusb init rtusbAP --->
[   11.694186]
=== pAd = bee38000, size = 856120 ===
[   11.694302] <-- RTMPAllocTxRxRingMemory, Status=0
[   11.695275] <-- RTMPAllocAdapterBlock, Status=0
[   11.695298] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x8
[   11.695303] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x4
[   11.695307] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x5
[   11.695311] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x6
[   11.695315] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x7
[   11.695319] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x9
[   11.696405] NVM is EFUSE
[   11.696416] Endpoint(8) is for In-band Command
[   11.696423] Endpoint(4) is for WMM0 AC0
[   11.696428] Endpoint(5) is for WMM0 AC1
[   11.696432] Endpoint(6) is for WMM0 AC2
[   11.696436] Endpoint(7) is for WMM0 AC3
[   11.696440] Endpoint(9) is for WMM1 AC0
[   11.696444] Endpoint(84) is for Data-In
[   11.696449] Endpoint(85) is for Command Rsp
[   11.698711] usbcore: registered new interface driver rtusbAP
[   11.984097] systemd-journald[106]: Received request to flush runtime journal from PID 1
[   12.376293] bcm2835-rng 3f104000.rng: hwrng registered
[   12.887628] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   12.897121] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.546580] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   14.555824] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   16.697137] ip_tables: (C) 2000-2006 Netfilter Core Team
[   16.736930] nf_conntrack version 0.5.0 (15574 buckets, 62296 max)
[   17.534518] cfg80211: Calling CRDA to update world regulatory domain
[   17.608024] cfg80211: World regulatory domain updated:
[   17.608053] cfg80211:  DFS Master region: unset
[   17.608054] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   17.608067] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   17.608075] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   17.608084] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   17.608095] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   17.608106] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   17.608115] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   17.608123] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   17.608131] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   20.978021] random: nonblocking pool is initialized
[   83.938417] FW Version:0.1.00 Build:7640
[   83.943948] Build Time:201302052146____
[   83.949613] ILM Length = 45380(bytes)
[   83.954663] DLM Length = 0(bytes)
[   83.962480] Loading FW....
[   84.004796] #
[   84.013531] RTMP_TimerListAdd: add timer obj beec6024!
[   84.020022] RTMP_TimerListAdd: add timer obj bee3c0cc!
[   84.684797] RTMP_TimerListAdd: add timer obj bee6a498!
[   84.690448] RTMP_TimerListAdd: add timer obj bee6b050!
[   85.223446] no file read method
[   85.227220] Read file "/etc/Wireless/RT2870AP/RT2870AP.dat" failed(errCode=-1)!
[   85.235311] 1. Phy Mode = 6
[   85.238843] 2. Phy Mode = 6
[   85.242333] NVM is Efuse and its size =1d[1e0-1fc]
[   85.258583] ERROR!!! MT7601 E2PROM: WRONG VERSION 0xd, should be 12
[   85.290040] 3. Phy Mode = 6
[   85.293732] AntCfgInit: primary/secondary ant 0/1
[   85.522149] RTMPSetPhyMode: channel is out of range, use first channel=0
[   85.534798] MCS Set = 00 00 00 00 00
[   85.559012] SYNC - BBP R4 to 20MHz.l
[   87.764949] RTMP_TimerListAdd: add timer obj bee6ad60!
[   87.771677] RTMPSetPhyMode: channel is out of range, use first channel=0
[   88.390398] Main bssid = 00:36:xx:xx:xx:xx (redacted)
[   88.395940] <==== rt28xx_init, Status=0
[   88.435980] 0x1300 = 00064220
[   88.440820] RTMPDrvOpen(1):Check if PDMA is idle!
[   88.447590] RTMPDrvOpen(2):Check if PDMA is idle!
Here is the hostapd error:
root@minibian:~/hostap/hostapd# ./hostapd -dd /etc/hostapd/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=ra0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Failed to set interface 3 to mode 2: -19 (No such device)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0x72c440)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x72c440)
ra0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss ra0
ra0: AP-DISABLED
hostapd_cleanup(hapd=0x72d010 (ra0))
hostapd_free_hapd_data: Interface ra0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0x72c440)
hostapd_interface_free: free hapd 0x72d010
hostapd_cleanup_iface(0x72c440)
hostapd_cleanup_iface_partial(0x72c440)
hostapd_cleanup_iface: free iface=0x72c440
If anyone's wondering how I compiled it, http://askubuntu.com/a/554278 is almost the same, also I used 'ap' instead of 'sta' at each command.
