Lan.Hekary
OMXplayer and Arabic Subtitles
Fri Jul 12, 2013 11:45 pm
Hello everyone ..
I am very new to the raspberry pi .. and to the Linux also
I want to play a movie with Arabic subtitle on raspberry pi ...
the movie works fine ... but the problem is the subtitle is "????????????"
all letters are question marks ...
I am sure that the subtitle is "UTF-8 " i also opened it as a text with leafpad and its ok and clear ...
can any one help me ???
I think its about the font that displays the subtitle ...
thanks ..
henle
Re: OMXplayer and Arabic Subtitles
Sun Jul 14, 2013 12:21 am
The default font Free Sans does not include the Arabic Unicode block. On Debian, the omxplayer options
--font /usr/share/fonts/truetype/freefont/FreeSerif.ttf --italic-font /usr/share/fonts/truetype/freefont/FreeSerifItalic.ttf
will set the font to Free Serif, which does include Arabic characters.
Lan.Hekary
Sun Jul 14, 2013 1:39 am
thank you for your help ...
the font-italic option is not supported by the omxplayer .. but its not a problem ...
the characters appeared in Arabic ... but from left to right ...
the Arabic language is from right to left ... the order if the characters is reversed ...
also the characters is separated .. but its likely because it is reversed ...
can you help me to figure a way to reverse it back ....
thanks ...
henle
Sun Jul 14, 2013 2:14 am
Does it display correctly if you manually reverse the letters?
Lan.Hekary
Sun Jul 14, 2013 4:57 am
I manually reversed the letters ... but it is still Separated ...
is there any other media player that works on raspbian ???
or .. what is the proper solution ???
thank you for your interest .
henle
Sun Jul 14, 2013 12:43 pm
It seems that XBMC supports proper Arabic shaping through libass for SSA subtitles. If you want, you can submit a feature request for simple reversing (trivial to implement) or shaping (more work) for omxplayer at https://github.com/popcornmix/omxplayer/issues.
