uherm
Huawei USB Dongle don't connect after upgrade
Fri Jun 14, 2013 11:28 am
I'm new in this board, this is my first post.
After upgrade to a new release
root@raspberrypi:/usr/lib/ModemManager# uname -a
Linux raspberrypi 3.6.11+ #456 PREEMPT Mon May 20 17:42:15 BST 2013 armv6l GNU/Linux
the Huawei USB surfstick can't connect anymore. Before the update it worked just fine.
I'm not too expirienced in linux, so I would be very happy if anyone can help me.
/var/log/syslog:
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Initializing cgroup subsys cpu
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #456 PREEMPT Mon May 20 17:42:15 BST 2013
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Machine: BCM2708
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] cma: CMA: reserved 16 MiB at 1b000000
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Memory policy: ECC disabled, Data cache writeback
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c053b854, node_mem_map c05e5000
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]   Normal zone: 896 pages used for memmap
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]   Normal zone: 113792 pages, LIFO batch:31
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113792
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xf bcm2708.serial=0x156c98b0 smsc95xx.macaddr=B8:27:EB:6C:98:B0 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Memory: 448MB = 448MB total
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Memory: 432264k/432264k available, 26488k reserved, 0K highmem
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff000000   ( 552 MB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc04e647c   (4986 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]       .init : 0xc04e7000 - 0xc0507f24   ( 132 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]       .data : 0xc0508000 - 0xc053c080   ( 209 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000]        .bss : 0xc053c0a4 - 0xc05e4758   ( 674 kB)
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] NR_IRQS:330
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] Console: colour dummy device 80x30
Jun 14 09:50:13 raspberrypi kernel: [    0.000000] console [tty1] enabled
Jun 14 09:50:13 raspberrypi kernel: [    0.001029] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jun 14 09:50:13 raspberrypi kernel: [    0.060126] pid_max: default: 32768 minimum: 301
Jun 14 09:50:13 raspberrypi dhclient: Internet Systems Consortium DHCP Client 4.2.2
Jun 14 09:50:13 raspberrypi dhclient: Copyright 2004-2011 Internet Systems Consortium.
Jun 14 09:50:13 raspberrypi dhclient: All rights reserved.
Jun 14 09:50:13 raspberrypi dhclient: For info, please visit https://www.isc.org/software/dhcp/
Jun 14 09:50:13 raspberrypi kernel: [    0.060462] Mount-cache hash table entries: 512
Jun 14 09:50:13 raspberrypi kernel: [    0.061221] Initializing cgroup subsys cpuacct
Jun 14 09:50:13 raspberrypi kernel: [    0.061275] Initializing cgroup subsys devices
Jun 14 09:50:13 raspberrypi kernel: [    0.061309] Initializing cgroup subsys freezer
Jun 14 09:50:13 raspberrypi kernel: [    0.061339] Initializing cgroup subsys blkio
Jun 14 09:50:13 raspberrypi kernel: [    0.061429] CPU: Testing write buffer coherency: ok
Jun 14 09:50:13 raspberrypi kernel: [    0.061762] hw perfevents: enabled with v6 PMU driver, 3 counters available
Jun 14 09:50:13 raspberrypi kernel: [    0.061905] Setting up static identity map for 0x39d698 - 0x39d6f4
Jun 14 09:50:13 raspberrypi kernel: [    0.063403] devtmpfs: initialized
Jun 14 09:50:13 raspberrypi kernel: [    0.074067] NET: Registered protocol family 16
Jun 14 09:50:13 raspberrypi kernel: [    0.080550] DMA: preallocated 4096 KiB pool for atomic coherent allocations
Jun 14 09:50:13 raspberrypi kernel: [    0.081651] bcm2708.uart_clock = 0
Jun 14 09:50:13 raspberrypi kernel: [    0.083042] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Jun 14 09:50:13 raspberrypi kernel: [    0.083096] hw-breakpoint: maximum watchpoint size is 4 bytes.
Jun 14 09:50:13 raspberrypi kernel: [    0.083133] mailbox: Broadcom VideoCore Mailbox driver
Jun 14 09:50:13 raspberrypi kernel: [    0.083228] bcm2708_vcio: mailbox at f200b880
Jun 14 09:50:13 raspberrypi kernel: [    0.083326] bcm_power: Broadcom power driver
Jun 14 09:50:13 raspberrypi kernel: [    0.083364] bcm_power_open() -> 0
Jun 14 09:50:13 raspberrypi kernel: [    0.083389] bcm_power_request(0, 8)
Jun 14 09:50:13 raspberrypi kernel: [    0.584077] bcm_mailbox_read -> 00000080, 0
Jun 14 09:50:13 raspberrypi kernel: [    0.584119] bcm_power_request -> 0
Jun 14 09:50:13 raspberrypi kernel: [    0.584145] Serial: AMBA PL011 UART driver
Jun 14 09:50:13 raspberrypi kernel: [    0.584288] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Jun 14 09:50:13 raspberrypi kernel: [    0.908134] console [ttyAMA0] enabled
Jun 14 09:50:13 raspberrypi kernel: [    0.931774] bio: create slab <bio-0> at 0
Jun 14 09:50:13 raspberrypi kernel: [    0.936653] SCSI subsystem initialized
Jun 14 09:50:13 raspberrypi kernel: [    0.940749] usbcore: registered new interface driver usbfs
Jun 14 09:50:13 raspberrypi kernel: [    0.946334] usbcore: registered new interface driver hub
Jun 14 09:50:13 raspberrypi kernel: [    0.951933] usbcore: registered new device driver usb
Jun 14 09:50:13 raspberrypi kernel: [    0.958291] Switching to clocksource stc
Jun 14 09:50:13 raspberrypi kernel: [    0.962529] FS-Cache: Loaded
Jun 14 09:50:13 raspberrypi kernel: [    0.965660] CacheFiles: Loaded
Jun 14 09:50:13 raspberrypi kernel: [    0.980418] NET: Registered protocol family 2
Jun 14 09:50:13 raspberrypi kernel: [    0.985702] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    0.993444] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    1.000237] TCP: Hash tables configured (established 16384 bind 16384)
Jun 14 09:50:13 raspberrypi kernel: [    1.006843] TCP: reno registered
Jun 14 09:50:13 raspberrypi kernel: [    1.010097] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    1.015997] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    1.022589] NET: Registered protocol family 1
Jun 14 09:50:13 raspberrypi kernel: [    1.027458] RPC: Registered named UNIX socket transport module.
Jun 14 09:50:13 raspberrypi kernel: [    1.033500] RPC: Registered udp transport module.
Jun 14 09:50:13 raspberrypi kernel: [    1.038223] RPC: Registered tcp transport module.
Jun 14 09:50:13 raspberrypi kernel: [    1.042969] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 14 09:50:13 raspberrypi kernel: [    1.050085] bcm2708_dma: DMA manager at f2007000
Jun 14 09:50:13 raspberrypi kernel: [    1.054875] bcm2708_gpio: bcm2708_gpio_probe c0515d98
Jun 14 09:50:13 raspberrypi kernel: [    1.060343] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jun 14 09:50:13 raspberrypi kernel: [    1.069493] audit: initializing netlink socket (disabled)
Jun 14 09:50:13 raspberrypi kernel: [    1.075087] type=2000 audit(0.930:1): initialized
Jun 14 09:50:13 raspberrypi kernel: [    1.197321] VFS: Disk quotas dquot_6.5.2
Jun 14 09:50:13 raspberrypi kernel: [    1.201356] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 14 09:50:13 raspberrypi kernel: [    1.208419] FS-Cache: Netfs 'nfs' registered for caching
Jun 14 09:50:13 raspberrypi kernel: [    1.214168] NFS: Registering the id_resolver key type
Jun 14 09:50:13 raspberrypi kernel: [    1.219342] Key type id_resolver registered
Jun 14 09:50:13 raspberrypi kernel: [    1.223636] Key type id_legacy registered
Jun 14 09:50:13 raspberrypi kernel: [    1.228001] msgmni has been set to 876
Jun 14 09:50:13 raspberrypi kernel: [    1.233537] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jun 14 09:50:13 raspberrypi kernel: [    1.241249] io scheduler noop registered
Jun 14 09:50:13 raspberrypi kernel: [    1.245297] io scheduler deadline registered (default)
Jun 14 09:50:13 raspberrypi kernel: [    1.250479] io scheduler cfq registered
Jun 14 09:50:13 raspberrypi kernel: [    1.278525] Console: switching to colour frame buffer device 82x26
Jun 14 09:50:13 raspberrypi kernel: [    1.289924] kgdb: Registered I/O driver kgdboc.
Jun 14 09:50:13 raspberrypi kernel: [    1.297090] vc-cma: Videocore CMA driver
Jun 14 09:50:13 raspberrypi kernel: [    1.302946] vc-cma: vc_cma_base      = 0x00000000
Jun 14 09:50:13 raspberrypi kernel: [    1.309484] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
Jun 14 09:50:13 raspberrypi kernel: [    1.316656] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
Jun 14 09:50:13 raspberrypi kernel: [    1.332759] brd: module loaded
Jun 14 09:50:13 raspberrypi kernel: [    1.342452] loop: module loaded
Jun 14 09:50:13 raspberrypi kernel: [    1.347617] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
Jun 14 09:50:13 raspberrypi kernel: [    1.356979] Loading iSCSI transport class v2.0-870.
Jun 14 09:50:13 raspberrypi kernel: [    1.364631] usbcore: registered new interface driver smsc95xx
Jun 14 09:50:13 raspberrypi kernel: [    1.372430] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 14 09:50:13 raspberrypi kernel: [    1.585024] Core Release: 2.80a
Jun 14 09:50:13 raspberrypi kernel: [    1.589851] Setting default values for core params
Jun 14 09:50:13 raspberrypi kernel: [    1.596411] Finished setting default values for core params
Jun 14 09:50:13 raspberrypi kernel: [    1.808833] Using Buffer DMA mode
Jun 14 09:50:13 raspberrypi kernel: [    1.813863] Periodic Transfer Interrupt Enhancement - disabled
Jun 14 09:50:13 raspberrypi kernel: [    1.821352] Multiprocessor Interrupt Enhancement - disabled
Jun 14 09:50:13 raspberrypi kernel: [    1.828614] OTG VER PARAM: 0, OTG VER FLAG: 0
Jun 14 09:50:13 raspberrypi kernel: [    1.834676] Dedicated Tx FIFOs mode
Jun 14 09:50:13 raspberrypi kernel: [    1.840804] dwc_otg: Microframe scheduler enabled
Jun 14 09:50:13 raspberrypi kernel: [    1.841207] dwc_otg bcm2708_usb: DWC OTG Controller
Jun 14 09:50:13 raspberrypi kernel: [    1.847936] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jun 14 09:50:13 raspberrypi kernel: [    1.857068] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Jun 14 09:50:13 raspberrypi kernel: [    1.864355] Init: Port Power? op_state=1
Jun 14 09:50:13 raspberrypi kernel: [    1.869958] Init: Power Port (0)
Jun 14 09:50:13 raspberrypi kernel: [    1.874980] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 14 09:50:13 raspberrypi kernel: [    1.883643] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 14 09:50:13 raspberrypi kernel: [    1.892731] usb usb1: Product: DWC OTG Controller
Jun 14 09:50:13 raspberrypi kernel: [    1.899266] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
Jun 14 09:50:13 raspberrypi kernel: [    1.906858] usb usb1: SerialNumber: bcm2708_usb
Jun 14 09:50:13 raspberrypi kernel: [    1.913963] hub 1-0:1.0: USB hub found
Jun 14 09:50:13 raspberrypi kernel: [    1.919527] hub 1-0:1.0: 1 port detected
Jun 14 09:50:13 raspberrypi kernel: [    1.925540] dwc_otg: FIQ enabled
Jun 14 09:50:13 raspberrypi kernel: [    1.925558] dwc_otg: NAK holdoff enabled
Jun 14 09:50:13 raspberrypi kernel: [    1.925579] Module dwc_common_port init
Jun 14 09:50:13 raspberrypi kernel: [    1.925794] Initializing USB Mass Storage driver...
Jun 14 09:50:13 raspberrypi kernel: [    1.932688] usbcore: registered new interface driver usb-storage
Jun 14 09:50:13 raspberrypi kernel: [    1.940445] USB Mass Storage support registered.
Jun 14 09:50:13 raspberrypi kernel: [    1.946956] usbcore: registered new interface driver libusual
Jun 14 09:50:13 raspberrypi kernel: [    1.954779] mousedev: PS/2 mouse device common for all mice
Jun 14 09:50:13 raspberrypi kernel: [    1.962893] bcm2835-cpufreq: min=700000 max=700000 cur=700000
Jun 14 09:50:13 raspberrypi kernel: [    1.970514] bcm2835-cpufreq: switching to governor powersave
Jun 14 09:50:13 raspberrypi kernel: [    1.977945] bcm2835-cpufreq: switching to governor powersave
Jun 14 09:50:13 raspberrypi kernel: [    1.985313] cpuidle: using governor ladder
Jun 14 09:50:13 raspberrypi kernel: [    1.991050] cpuidle: using governor menu
Jun 14 09:50:13 raspberrypi kernel: [    1.996644] sdhci: Secure Digital Host Controller Interface driver
Jun 14 09:50:13 raspberrypi kernel: [    2.004505] sdhci: Copyright(c) Pierre Ossman
Jun 14 09:50:13 raspberrypi kernel: [    2.010558] sdhci: Enable low-latency mode
Jun 14 09:50:13 raspberrypi kernel: [    2.062565] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Jun 14 09:50:13 raspberrypi kernel: [    2.073861] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Jun 14 09:50:13 raspberrypi kernel: [    2.083643] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 14 09:50:13 raspberrypi kernel: [    2.096847] usbcore: registered new interface driver usbhid
Jun 14 09:50:13 raspberrypi kernel: [    2.104310] usbhid: USB HID core driver
Jun 14 09:50:13 raspberrypi kernel: [    2.114671] TCP: cubic registered
Jun 14 09:50:13 raspberrypi kernel: [    2.121897] Initializing XFRM netlink socket
Jun 14 09:50:13 raspberrypi kernel: [    2.130166] Indeed it is in host mode hprt0 = 00021501
Jun 14 09:50:13 raspberrypi kernel: [    2.137224] NET: Registered protocol family 17
Jun 14 09:50:13 raspberrypi kernel: [    2.152601] Key type dns_resolver registered
Jun 14 09:50:13 raspberrypi kernel: [    2.162791] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jun 14 09:50:13 raspberrypi kernel: [    2.193358] registered taskstats version 1
Jun 14 09:50:13 raspberrypi kernel: [    2.201324] Waiting for root device /dev/mmcblk0p2...
Jun 14 09:50:13 raspberrypi kernel: [    2.234503] mmc0: read SD Status register (SSR) after 3 attempts
Jun 14 09:50:13 raspberrypi kernel: [    2.260851] mmc0: new high speed SDHC card at address e624
Jun 14 09:50:13 raspberrypi kernel: [    2.268965] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Jun 14 09:50:13 raspberrypi kernel: [    2.277334]  mmcblk0: p1 p2
Jun 14 09:50:13 raspberrypi kernel: [    2.347003] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 14 09:50:13 raspberrypi kernel: [    2.359165] VFS: Mounted root (ext4 filesystem) on device 179:2.
Jun 14 09:50:13 raspberrypi kernel: [    2.372454] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [    2.381107] Indeed it is in host mode hprt0 = 00001101
Jun 14 09:50:13 raspberrypi kernel: [    2.389117] devtmpfs: mounted
Jun 14 09:50:13 raspberrypi kernel: [    2.402833] Freeing init memory: 128K
Jun 14 09:50:13 raspberrypi kernel: [    2.602763] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jun 14 09:50:13 raspberrypi kernel: [    2.616164] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 14 09:50:13 raspberrypi kernel: [    2.626318] hub 1-1:1.0: USB hub found
Jun 14 09:50:13 raspberrypi kernel: [    2.632594] hub 1-1:1.0: 3 ports detected
Jun 14 09:50:13 raspberrypi kernel: [    2.912730] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [    3.043112] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jun 14 09:50:13 raspberrypi kernel: [    3.052105] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 14 09:50:13 raspberrypi kernel: [    3.079014] smsc95xx v1.0.4
Jun 14 09:50:13 raspberrypi kernel: [    3.147313] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6c:98:b0
Jun 14 09:50:13 raspberrypi kernel: [    3.272648] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [    3.394809] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8176
Jun 14 09:50:13 raspberrypi kernel: [    3.410759] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 14 09:50:13 raspberrypi kernel: [    3.432527] usb 1-1.2: Product: 802.11n WLAN Adapter
Jun 14 09:50:13 raspberrypi kernel: [    3.439646] usb 1-1.2: Manufacturer: Realtek
Jun 14 09:50:13 raspberrypi kernel: [    3.461105] usb 1-1.2: SerialNumber: 00e04c000001
Jun 14 09:50:13 raspberrypi kernel: [    3.552689] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [    3.685320] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=1436
Jun 14 09:50:13 raspberrypi kernel: [    3.695373] usb 1-1.3: New USB device strings: Mfr=4, Product=3, SerialNumber=0
Jun 14 09:50:13 raspberrypi kernel: [    3.704857] usb 1-1.3: Product: HUAWEI Mobile
Jun 14 09:50:13 raspberrypi kernel: [    3.711217] usb 1-1.3: Manufacturer: HUAWEI Technology
Jun 14 09:50:13 raspberrypi kernel: [    3.752518] scsi5 : usb-storage 1-1.3:1.5
Jun 14 09:50:13 raspberrypi kernel: [    3.772516] scsi6 : usb-storage 1-1.3:1.6
Jun 14 09:50:13 raspberrypi kernel: [    4.754157] scsi 5:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
Jun 14 09:50:13 raspberrypi kernel: [    4.803516] scsi 6:0:0:0: Direct-Access     HUAWEI   SD Storage       2.31 PQ: 0 ANSI: 2
Jun 14 09:50:13 raspberrypi kernel: [    4.851064] sd 6:0:0:0: [sda] Attached SCSI removable disk
Jun 14 09:50:13 raspberrypi kernel: [    5.385267] Registered led device: led0
Jun 14 09:50:13 raspberrypi kernel: [    5.924509] cdc_ether 1-1.3:1.1: wwan0: register 'cdc_ether' at usb-bcm2708_usb-1.3, Mobile Broadband Network Device, 02:50:f3:00:00:00
Jun 14 09:50:13 raspberrypi kernel: [    5.953276] usbcore: registered new interface driver usbserial
Jun 14 09:50:13 raspberrypi kernel: [    5.961465] usbcore: registered new interface driver usbserial_generic
Jun 14 09:50:13 raspberrypi kernel: [    6.452718] usbcore: registered new interface driver cdc_ether
Jun 14 09:50:13 raspberrypi kernel: [    6.473141] USB Serial support registered for generic
Jun 14 09:50:13 raspberrypi kernel: [    6.480339] usbserial: USB Serial Driver core
Jun 14 09:50:13 raspberrypi kernel: [    6.695494] usbcore: registered new interface driver option
Jun 14 09:50:13 raspberrypi kernel: [    6.802799] USB Serial support registered for GSM modem (1-port)
Jun 14 09:50:13 raspberrypi kernel: [    6.811328] option 1-1.3:1.0: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [    6.995117] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
Jun 14 09:50:13 raspberrypi kernel: [    7.097739] option 1-1.3:1.3: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [    7.154364] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
Jun 14 09:50:13 raspberrypi kernel: [    7.195017] option 1-1.3:1.4: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [    7.217781] usbcore: registered new interface driver rtl8192cu
Jun 14 09:50:13 raspberrypi kernel: [    7.263654] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
Jun 14 09:50:13 raspberrypi kernel: [    7.695558] sr0: scsi-1 drive
Jun 14 09:50:13 raspberrypi kernel: [    7.700778] cdrom: Uniform CD-ROM driver Revision: 3.20
Jun 14 09:50:13 raspberrypi kernel: [    7.816752] sr 5:0:0:0: Attached scsi CD-ROM sr0
Jun 14 09:50:13 raspberrypi kernel: [    8.020439] dwc_otg bcm2708_usb: dev 1.3 ep7in scatterlist error -104/-121
Jun 14 09:50:13 raspberrypi kernel: [    8.029812] dwc_otg bcm2708_usb: dev 1.3 ep7in scatterlist error -104/-121
Jun 14 09:50:13 raspberrypi kernel: [   68.302535] option1 ttyUSB0: option_instat_callback: error -108
Jun 14 09:50:13 raspberrypi kernel: [   68.315161] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Jun 14 09:50:13 raspberrypi kernel: [   68.328815] option 1-1.3:1.0: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [   68.335784] cdc_ether 1-1.3:1.1: wwan0: unregister 'cdc_ether' usb-bcm2708_usb-1.3, Mobile Broadband Network Device
Jun 14 09:50:13 raspberrypi kernel: [   68.372976] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Jun 14 09:50:13 raspberrypi kernel: [   68.397181] option 1-1.3:1.3: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [   68.414717] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Jun 14 09:50:13 raspberrypi kernel: [   68.442593] option 1-1.3:1.4: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [   68.532658] usb 1-1.3: reset high-speed USB device number 5 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [   68.665954] option 1-1.3:1.4: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [   68.678633] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
Jun 14 09:50:13 raspberrypi kernel: [   68.700305] option 1-1.3:1.3: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [   68.717006] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
Jun 14 09:50:13 raspberrypi kernel: [   68.745368] cdc_ether 1-1.3:1.1: wwan0: register 'cdc_ether' at usb-bcm2708_usb-1.3, Mobile Broadband Network Device, 02:50:f3:00:00:00
Jun 14 09:50:13 raspberrypi kernel: [   68.783130] option 1-1.3:1.0: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [   68.803029] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
Jun 14 09:50:13 raspberrypi kernel: [   68.966126] dwc_otg bcm2708_usb: dev 1.3 ep7in scatterlist error -104/-121
Jun 14 09:50:13 raspberrypi kernel: [   68.975727] dwc_otg bcm2708_usb: dev 1.3 ep7in scatterlist error -104/-121
Jun 14 09:50:13 raspberrypi kernel: [  128.340963] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 14 09:50:13 raspberrypi kernel: [  128.836033] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 14 09:50:13 raspberrypi kernel: [  129.262630] option1 ttyUSB2: option_instat_callback: error -108
Jun 14 09:50:13 raspberrypi kernel: [  129.284480] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Jun 14 09:50:13 raspberrypi kernel: [  129.314012] option 1-1.3:1.0: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [  129.320989] cdc_ether 1-1.3:1.1: wwan0: unregister 'cdc_ether' usb-bcm2708_usb-1.3, Mobile Broadband Network Device
Jun 14 09:50:13 raspberrypi kernel: [  129.372971] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Jun 14 09:50:13 raspberrypi kernel: [  129.407690] option 1-1.3:1.3: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [  129.436613] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Jun 14 09:50:13 raspberrypi kernel: [  129.467931] option 1-1.3:1.4: device disconnected
Jun 14 09:50:13 raspberrypi kernel: [  129.582739] usb 1-1.3: reset high-speed USB device number 5 using dwc_otg
Jun 14 09:50:13 raspberrypi kernel: [  129.709981] option 1-1.3:1.4: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [  129.727748] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
Jun 14 09:50:13 raspberrypi kernel: [  129.762799] option 1-1.3:1.3: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [  129.789398] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
Jun 14 09:50:13 raspberrypi kernel: [  129.828629] cdc_ether 1-1.3:1.1: wwan0: register 'cdc_ether' at usb-bcm2708_usb-1.3, Mobile Broadband Network Device, 02:50:f3:00:00:00
Jun 14 09:50:13 raspberrypi kernel: [  129.875575] option 1-1.3:1.0: GSM modem (1-port) converter detected
Jun 14 09:50:13 raspberrypi kernel: [  129.905692] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
Jun 14 09:50:13 raspberrypi kernel: [  140.511457] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
lsusb:
root@raspberrypi:~# lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 005: ID 12d1:1436 Huawei Technologies Co., Ltd.
(usb_modeswitch should be ok, without switch device ID is 12d1:1446)
after pon o2 I get this in syslog:
Jun 14 10:46:48 raspberrypi pppd[8190]: pppd 2.4.5 started by root, uid 0
Jun 14 10:46:50 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:47:23 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:47:56 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:48:28 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:49:01 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:49:34 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:50:07 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:50:40 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:51:13 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:51:46 raspberrypi pppd[8190]: Connect script failed
Jun 14 10:51:47 raspberrypi pppd[8190]: Exit.
/etc/ppp/peers/o2:
lock
connect "/usr/sbin/chat -V -f /etc/ppp/peers/umts"
defaultroute
/dev/ttyUSB0
460800
crtscts
modem
usepeerdns
novj
noauth
persist
any Ideas? thanks in advance.
uherm
Re: Huawei USB Dongle don't connect after upgrade
Sun Jun 16, 2013 8:56 pm
after lots of testing looks to me as a bug in modul option.
Downgraded to previous version works fine.
modinfo option:
filename: /lib/modules/3.6.11+/kernel/drivers/usb/serial/option.ko
license: GPL
version: v0.7.2
description: USB Driver for GSM modems
Users of the Huawei E173 should be cautious with upgrading.
BLL
Sun Jun 23, 2013 10:37 am
I also am having serious problems after the kernel upgrade. It wouldn't recognise the pcf2127a rtc. I did a complete new SD card from scatch and it worked. Then removed the rtc and substituted as DS1302 and built from scratch. Now, with the Huawei E353 plugged in, I get scatterlist errors, ep7in error -104/-121. I have no idea what that means! I also can't get into the terminal with startx as I get a timeout in locking authority file /home/pi/.Xauthority. No idea what that's about or how to cure it! Does Linux on the RasPi EVER behave? :cry: :cry:
Any help appreciated.
aweiler
Sat Jul 27, 2013 10:07 pm
If you don't need cdrom support on you RasPi, consider disabling it by putting
blacklist sr_mod
in /etc/modprobe.d/raspi-blacklist.conf
Reboot and the UMTS dongle will work as before the update (at least it did for me).
BLL
Sun Jul 28, 2013 11:54 am
Hi, Thanks for that. How on earth did you track that down? My only solution, when I got no replies was to build an electronic switch for the E353, controlled by one of the GPIO pins, so it only powers up when told to do so from rc.local and all is fine as it isn't around when the errors happen!
aweiler
Sun Jul 28, 2013 8:29 pm
In the console output (not on dmesg, unfortunately) there was a message like
udevd[nnn] timeout: killing 'cdrom_id --lock-media /dev/sr0'
and almost at the same time the devices /dev/ttyUSB{0,1,2} became disconnected.
Searching for that timeout error lead me to discussions how to repair the cdrom support. But hey, the cdrom emulation on USB UMTS Dongles only contains software for Windows. We don't need that on a RasPi! So I just tried disabling that cdrom in order to get rid of the errors. And voilà: the cdrom emulation no longer disturbs, the ttyUSB* don't get disconnected, and the modem devices works properly. As a side effect, the RasPi also boots faster, because it doesn't wait for the cdrom_id timeout anymore.
Of course, this is only a workaround. Something has gone wrong in the last udev update, and that should probably be solved there. But as long as I don't need the cdrom anyway, that workaround works fine for me.
NicoVanDerDussen
Sat Mar 22, 2014 11:21 am
I'm suffering from the same issue - good to know I'm not alone :)
For which devices does one need CDRom support?
Only for CD-Roms (And DVD?)
Or does this include support for USB memory sticks as well?
Nico
Setting up your Raspberry Pi to work with a 3G dongle http://nvdd.info/11gKrsZ
