smshiera
after reboot,pi resize filemanager auto
Sat May 04, 2013 9:34 am
type startx then enter graphical interface,
open " file manager ",
I can resize this program's window smaller or bigger,
but after reboot,
pi set it back auto to a almost full screen size ,
what can i do to let it remember filemanager's setting?
Jim JKla
Re: after reboot,pi resize file-manager auto
Sat May 04, 2013 4:32 pm
Which image are you using. ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
smshiera
Sat May 04, 2013 5:11 pm
Jim JKla wrote:Which image are you using. ;)
2013-02-09-wheezy-raspbian,
this happened about 1 week ago,i dont want reinstall it bucause i have installed some program .
Jim JKla
Sun May 05, 2013 7:08 am
ok you probably need to look at editing the settings in
/boot/config.txt
this file is in the section you can access from your pc this is the part of the SD card you can edit from your PC with the SD card in a reader.
There's a load of stuff both here in the forum and in the wiki on editing the config.txt one thing to note use wordpad to edit from windows as Notepad fails to wrap the text. ;)
smshiera
Sun May 05, 2013 10:11 am
Jim JKla wrote:ok you probably need to look at editing the settings in
/boot/config.txt
no no no ...,sorry for my broken english.
my led is 1920x1080, it displays correctly.no problem.
what i mean is type "startx" then enter graphical interface,
open " file manager ",resize this program's window
Jim JKla
Re: after reboot,pi resize filemanager auto
Sun May 05, 2013 11:05 am
OK
I will look but I suspect someone will be back with an answer here before I get back. :)
smshiera
Mon May 06, 2013 11:47 am
can i remove filemanager and reinstall it?
smshiera
Mon May 06, 2013 9:45 pm
i have tried to remove and install this filemanager(pcmanfm),
but the problem is still not resolved..
which folder is that pcmanfm save its settings?
smshiera
Fri May 10, 2013 11:22 pm
I have tried many ways,but this problem is still not solved
