020110348
I messed up... rc.local freezes
Fri Mar 22, 2013 1:42 am
I put a scrip in the rc.local file, that calls a while loop... never ending. all that i found i can do is hit ctrl+alt+del and reboot, still errors out. i tried the jumper between 5+6 didnt help.
what can i DO????
tonyhughes
Re: I messed up... rc.local freezes
Fri Mar 22, 2013 1:47 am
Mount the card on a linux machine and edit the file...
020110348
Fri Mar 22, 2013 1:52 am
your going to make fun of me, but the raspberry pi is my only linux machine... need windows for work :(
Fri Mar 22, 2013 6:16 am
If you have a Windows machine that you can edit cmdline.txt on, you could try something along the lines of the (fairly standard) recovery method detailed by Joe Schmoe here http://www.raspberrypi.org/phpBB3/viewt ... 26#p257892.
Don't do the bit about editing /etc/inittab (step 3 c), as that is not your problem. Instead, correct your /etc/rc.local at that point. Then continue as directed. That should fix you :-)
020110348
Fri Mar 22, 2013 2:55 pm
what i did was use my RPi with a different SD card, than mounted and edited rc.local. as soon as i typed all i have is windows and hit submit, it hit me, use the RPI to fix Itself.
EDIT: SOLVED!!
now i found the probelm line "sudo python /home/pi/run.py" inside run.py it is waiting for every time a GPIO button is pressed press a virtual esc key. that code worked, but when i put it there i thought it would let boot continue. how can i run "run.py" that does nothing untill a gpio is pressed, and let boot contine. would backgrounding? "sudo python /home/pi/run.py &" it work?
foud in differnt thread thakn you
fishoasis
Sun May 28, 2017 3:39 am
Could you be more specific about how you mounted the card and found /etc/rc.local? I think I mounted the card but can't find /etc/rc.local
itimpi
Sun May 28, 2017 12:49 pm
fishoasis wrote:Hi,
If you have mounted the card, then the location will be of the form /<mountpoint>/etc/rc.local where <mountpoint> is where the card is mounted.
