Blast
booting up pi but nothing showing up on screen
Mon Mar 11, 2013 4:46 am
when i power on my rpi, nothing comes on screen... i see a solid red light with a green light flickering for awhile but nothing comes up on the screen, any help?
i am using the latest 2013-02-09-wheezy-raspbian
sd card: Patriot SDHC 16 10 LX Series (PSF16GSDHC10) 19.3MB/s read, 9.3MB/s write
i checked the checksum to make sure it's correct and it was.
reformatted the sd card and copied the image over again using win32 disk imager and still no luck...
is something wrong with my rpi?
MaxK1
Re: booting up pi but nothing showing up on screen
Mon Mar 11, 2013 9:29 am
And your screen is a?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Mon Mar 11, 2013 11:15 am
It sounds like your Pi is booting up correctly (green light flickering for some seconds), but the display output is incorrect.
The first place you should look is http://elinux.org/R-Pi_Troubleshooting#Display
As MaxK1 said, what sort of display do you have HDMI, Composite/RCA or something else connected via an adaptor?
Blast
Mon Mar 11, 2013 3:06 pm
HDMI
how do I access the config file ?
also
do i have to change all this ?
hdmi_safe=1
config_hdmi_boost=4
hdmi_force_hotplug=1
or just the hdmi_safe=1 ???
MaxK1
Mon Mar 11, 2013 3:34 pm
It's in /boot/config.txt
You may not need all of them - I'd try config_hdmi_boost=4
Also (And this may sound weird) try reversing your HDMI cable! I have one (And others have reported this as well) that only works one way. It also needs to be pushed in _very_ firmly - a fraction of a mm may make contact. My other HDMI cables "just work"...
rurwin
Mon Mar 11, 2013 3:47 pm
Make sure your TV is switched on and ready before the Pi. The Pi detects the existence of a HDMI device, and if it isn't there it switches to composite.
Blast
Mon Mar 11, 2013 6:37 pm
couldn't get it to output any video using hdmi
tried with rca and it worked
the tv is pretty old, from 2006... it's the Toshiba 32HL66
here are the full specs of the tv http://reviews.cnet.com/flat-panel-tvs/ ... 91740.html
if anybody can take a look at the specs and show me what to change in the config file it would be great to get it to work with the hdmi
drgeoff
Mon Mar 11, 2013 6:55 pm
MaxK1 wrote:It's in /boot/config.txt
... only when accessing it on the RPi. Which is a bit tricky without a working display. :)
If the OP can put the SD card in a card reader on a Windows PC, the config.txt file will be visible in the only 'drive' that Windows sees on the card. (Don't be concerned that the drive is only about 60 Mbyte.)
