dpguest
youtube audio problem
Sat Feb 23, 2013 5:33 pm
I think I have done everything...
I downloaded the correct version of youtube-dl.
I downloaded and installed the proper _init_py file.
I changed the mplayer to include '-ohdmi'
I updated and upgraded the rasbain wheezy ...
I downloaded installed and ran rpi-upgrade ... upgrading the firmware.
When I run yt, it provides a beautiful picture ... but no sound....
any help would be appreciated
Cloudcentric
Re: youtube audio problem
Sat Feb 23, 2013 9:43 pm
Have you configured the sound output ?
http://www.raspians.com/Knowledgebase/n ... phone-jack
Note about above link sudo amixer cset numid=3 0 this is actually an auto-dectect setting, for HDMI use use sudo amixer cset numid=3 2
I know everything about nothing"
dpguest
Sun Feb 24, 2013 2:32 pm
boo hoo ... I followed your instructions ... but still no sound with YT....
Is there a volume setting that I have to set?
Cloudcentric
Sun Feb 24, 2013 2:39 pm
This page is for ARCH but ALSA is ALSA
http://www.dreamincode.net/forums/blog/ ... spberry-pi
dpguest
Sun Feb 24, 2013 3:39 pm
How do I follow these instructions when I am in RaspberryPI$
thanks for your patience
dpguest
Sun Feb 24, 2013 3:56 pm
For example when I do
sudo echo "# Load snd-bcm2835.ko at boot" > /etc/modules-load.d/snd-bcm2835.conf
I get an error message no file or directory
baffled....
ebirtTechArt
Thu Jun 16, 2016 4:01 pm
I had the same problem with youtube sound on my rPi 3, and Cloudcentric's link helped me fix it. Ultimately sound output was set to "auto", and switching it to "3.5mm" was what it took, using the command...
amixer cset numid=3 1
Thanks!
sevketk
Mon Jul 02, 2018 1:05 pm
I had same problem. He said no sound on youtube. Dont say no sound anywhere...
I connected my pi vnc, and I connect my speaker on headphone jack input.
I get sound from omxplayer , but no sound chromium & youtube ....
