wardellcastles
TightVNCServer Problems
Sun Jan 13, 2013 10:57 pm
I cannot get Tight VNC Server to work properly on my RPi.
Here's what I have done:
1) sudo apt-get install tightvncserver
2) tightvncserver
2A) (entered password for the server)
3) vncserver :0 -geometry 1920x1080 -depth 24
(These instructions came from several web sites)
On my Windows machine, I have installed the Tight VNC Client
When I try to connect to my RPi on Windows, I get a message,
Authentication reason: Authentication failed.
So my thinking is to completely uninstall tightvncserver and start over.
I have now tried to completely remove tightvncserver on the Pi by the commands
1) sudo dpkg -r tightnvncserver
and
2) sudo apt-get remove --purge tightvncserver
Both or either commands indicate tightvncserver has been removed
So now I go and resintall via
2) tightvncserver
However now the server just starts and doesn't prompt me for a password.
michaeljquinn
Re: TightVNCServer Problems
Mon Jan 14, 2013 1:38 am
make sure that the port is correct
try 5901 on the client - not at my pi at the moment,
wardellcastles
Mon Jan 14, 2013 1:54 am
I really hate to ask a noob question. I have googled for the answer for how to specify the port and come up empty handed.
Suppose I have the server running at 192.168.1.100:0
How do I specify the port as 5901 ??? From what I can see I am supposed to specify the port after two colons, e.g. 192.168.1.100:0::5901
However that doesn't work.
wardellcastles
Mon Jan 14, 2013 1:57 am
Also.. if nothing else works, how do I completely uninstall TightVNCServer on the Pi so that I can reinstall it and give it a new password?
Dweeber
Mon Jan 14, 2013 2:04 am
The password is located in a file in your home directory. IF you delete it, you can set the password again.
Here is how I set it up: http://rpi.tnet.com/project/faqs/tightvncserver
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
wardellcastles
Mon Jan 14, 2013 2:06 am
Hey, I got it to work finally.. it wasn't a port problem. My keyboard kept typing in the wrong password.. dohhh!!!. :oops: :oops:
Thanks for the offer of help though!!!
SimonSmall
Mon Jan 14, 2013 1:36 pm
You start the VNC server by typing "vncserver :1" where the "1" represents the display number. The server then communicates over port 5901. If you type "vncserver :5" the port would be 5905
When you try to connect to the Pi from another device, you specify the server as "192.168.1.100:1" or whatever the IP address of the Pi happens to be. The ":1" corresponds to the display number that you launched the server with. You don't really have to worry about the port number.
DanielVd
Tue Feb 03, 2015 8:52 am
michaeljquinn wrote:make sure that the port is correct
It works! Thanks man!
Mowrish
Thu Nov 19, 2015 10:06 am
You could reset the password via pi terminal using the command
vncpasswd
Hit Enter and type your new password. Then restart the vncserver
service vncserver restart
Hola Your problem is fixed
Malcolm_d
Fri Jul 21, 2017 2:43 pm
I have an X11 application running quite happily when I use tightvnc remote access the app becomes slow and unreliable is there a conflict with display ?
Fri Jul 21, 2017 4:38 pm
Malcolm_d wrote:I have an X11 application running quite happily when I use tightvnc remote access the app becomes slow and unreliable is there a conflict with display ?
Do you get the same effect if you remove TightVNC and replace it with, the much better supported, RealVNC?
This is a doctor free zone.
Malcolm_d
Sat Jul 22, 2017 9:32 am
Hi Dougie , No I don't its perfect with Real Vnc my problem is it's limited to 5 pi's if you want more you have to subscribe £31 for each additional unit
Sat Jul 22, 2017 9:54 am
Malcolm_d wrote:Hi Dougie , No I don't its perfect with Real Vnc my problem is it's limited to 5 pi's if you want more you have to subscribe £31 for each additional unit
Isn't that a per registration email address limit? You can also tunnel VNC over ssh without using the RealVNC cloud service.
