iznobe
how to install disk mSSD not recognized ( or format )
Fri Nov 08, 2019 1:12 pm
hello ,
i bought a X850 and a mSSD drive
https://www.amazon.fr/gp/product/B07WNJ ... UTF8&psc=1
and
https://www.amazon.fr/gp/product/B01768 ... UTF8&psc=1
i connect by USB de X850 to the pi and start the pi .
the pi working as expected , the X850 has a led lighting , but :
pi@rasphomefi:/boot $ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 29,2 GiB, 31306285056 bytes, 61145088 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xd9b3f436
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1        8192   532479   524288  256M  c W95 FAT32 (LBA)
/dev/mmcblk0p2      532480 61145087 60612608 28,9G 83 Linux
and :
pi@rasphomefi:/boot $ dmesg | tail
[  707.341855] usb 1-1.3: new full-speed USB device number 9 using dwc_otg
[  708.381862] usb 1-1.3: device descriptor read/64, error -32
[  708.601856] usb 1-1.3: device descriptor read/64, error -32
[  708.722000] usb 1-1-port3: attempt power cycle
[  709.381859] usb 1-1.3: new full-speed USB device number 10 using dwc_otg
[  709.821856] usb 1-1.3: device not accepting address 10, error -32
[  710.421862] usb 1-1.3: new full-speed USB device number 11 using dwc_otg
[  710.861864] usb 1-1.3: device not accepting address 11, error -32
[  710.862018] usb 1-1-port3: unable to enumerate USB device
[  711.192009] Voltage normalised (0x00000000)
what can i do ?
help please ;)
RossDv8
Re: how to install disk mSSD not recognized ( or format )
Sat Nov 09, 2019 3:14 am
This person had a problem with a USB device, and while theirs was a camera, and yours is a drive I noticed a couple of things in common. One was that in both cases, the error message mentions 'using dwc_otg'.
They found appending a line to cmdine.txt solved their problem. It might not work for yours, but it might be somewhere to start..
If you do find a solution though, please make a note here.
Here's the link:
https://raspberrypi.stackexchange.com/q ... ing-webcam
Remember, nobody is listening to you
until you fart ...
iznobe
Sun Nov 10, 2019 8:12 am
Hello and thanks for this reply .
sure there is common things , but in my buster /boot/cmdline.txt file :
console=serial0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
pi@rasphomefi:~ $
there is no " dwc_otg.fiq_enable " parameters , perhaps it is in another file .
But i had tried to format the mssd disk on my windows laptop , and don't initialize too ...
i think the disk is non functional , so i will send it to the vendor .
RossDv8
Mon Nov 11, 2019 6:54 am
Did you try lsblk in a Terminal before you tried fdisk? Did the new disk show
for example, on my Pi 4 it shows these disks plugged into my USB ports
pi@raspberrypi:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 223.6G 0 disk
├─sda1 8:1 0 256M 0 part /media/pi/boot
└─sda2 8:2 0 223.3G 0 part /
sdb 8:16 0 2.7T 0 disk
├─sdb1 8:17 0 128M 0 part
└─sdb2 8:18 0 2.7T 0 part /media/pi/Tosh-3TB-Mov
sdc 8:32 1 29G 0 disk
└─sdc1 8:33 1 29G 0 part /media/pi/VIDEO
mmcblk0 179:0 0 14.5G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 14.2G 0 part /media/pi/rootfs
pi@raspberrypi:~ $
sda = my 240GB SSD formatted using SD Card Copier on the Pi Menu
sdb = my USB 3 3TB external drive
sdc = a 32GB thumb drive that had FAT32 as standard
mmcblk0 = my microSD used for booting to the SSD
I just wondered if lsblk shows 'anything' for your new drive at all?
until you fart ...
iznobe
Tue Nov 12, 2019 10:57 am
pi@raspberrypi:~ $
Hello ,
i will try it but the disk is new , and not formatted logically
iznobe
Tue Nov 12, 2019 12:29 pm
Hi ,
here is the result :
pi@rasphomefi:~ $ lsblk
mmcblk0     179:0    0 29,2G  0 disk
└─mmcblk0p2 179:2    0 28,9G  0 part /
pi@rasphomefi:~ $
no detection of any partition on my new disk :cry:
iznobe
Tue Nov 12, 2019 10:59 pm
more info :
i@rasphomefi:/var/log $ lsusb -v
Bus 001 Device 017: ID 2717:ff80
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x2717
  idProduct          0xff80
  bcdDevice            4.04
  iManufacturer           1
  iProduct                2
  iSerial                 3
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x004b
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          4
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass        224 Wireless
      bFunctionSubClass       1 Radio Frequency
      bFunctionProtocol       3 RNDIS
      iFunction               7
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass       224 Wireless
      bInterfaceSubClass      1 Radio Frequency
      bInterfaceProtocol      3 RNDIS
      iInterface              5
      ** UNRECOGNIZED:  05 24 00 10 01
      ** UNRECOGNIZED:  05 24 01 00 01
      ** UNRECOGNIZED:  04 24 02 00
      ** UNRECOGNIZED:  05 24 06 00 01
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               9
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass        10 CDC Data
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              6
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0027
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idProduct          0x9514 SMC9514 Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.19
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
pi@rasphomefi:/var/log $ uname -a
Linux rasphomefi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
RossDv8
Tue Nov 12, 2019 11:32 pm
My 240GB SSD was new and not formatted logically either. Blank new drives have always showed up for me using the lsblk command.
It is possible the new drive is faulty.
It is also possible that if you are using an adapter to plug the drive into the USB port on the Pi, that adapter might not be compatible.
There are quite a few posts on the forum about this problem with the USB adapters for ordinary SSD drives like mine.
Maybe someone else here has suggestions :-)
until you fart ...
