RPI4 B - worked for 2 months, nothing changed, now it doesn’t
Posted: Sun Oct 20, 2019 6:30 pm
by DontKnowHow
Hello everyone.
I didn’t know how else to find a solution but to posting on here.
I have gone through the "PI is not booting up STICKY", but I cannot pinpoint the cause of my problems.
At the end of August, I have installed the latest version of Rasbian onto my RPI4 B. Everything worked well, up until recently.
Situation:
- RPI sometimes it boots, sometimes it won’t,
- When it won't boot, there is a 4-short-flash green LED going on, that should mean that start*.elf is not found. My question here is, is this even possible if the RPI sometimes boots?,
- Sometimes when it boots, it won't startup the Teamviewer or the Pi-Hole, I cannot ssh into it, but I can ping the IP the router is assigning him (ethernet cable connection),
- Sometimes everything starts up correctly, but after a while, Teamviewer and Pi-Hole go offline, while I'm still able to ping its IP,
- Sometimes it won't even start up after I plug it in the power, but just give a short blink of the RED led.
What have I done:
After countless attempts, I have managed to:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get upgrade
pihole -up
The problem persists
Is it possible the PSU has degraded with time or could the problem be somewhere else? I don’t want to buy a new PSU if not necessary.
Thank you for your help!
A
Re: RPI4 B - worked for 2 months, nothing changed, now it doesn’t
Posted: Sun Oct 20, 2019 8:13 pm
by alphanumeric
Try a different Micro SD card.
Posted: Sun Oct 20, 2019 8:34 pm
by DontKnowHow
I use SanDisk Ultra 32GB Class 10 98MB/s Micro SD SDHC.
Would you be so kind as to tell me for a specific card brand that should work, or is only my card that is faulty?
Posted: Sun Oct 20, 2019 9:00 pm
by epoch1970
No specific brand. Class 10 is good. Super bargain price means fake card, usually.
Posted: Sun Oct 20, 2019 9:14 pm
by DontKnowHow
Thank you all for your help.
Will try a new SD card and also follow this guide to avoid future mishaps: https://durdle.com/2017/01/04/how-not-t ... s-sd-card/
Posted: Sun Oct 20, 2019 9:22 pm
by HawaiianPi
What are you using for a power supply?
