Copying to USB HDD is very slow
Posted: Sun Oct 13, 2019 6:52 am
by zeitalex
Seagate 8TB Backup Plus USB3 Hdd (formated with ext4) is very slow on my RPi3. If i download via ftp for example it is about 300KB/s while other usb drives and SD Card gives about 7MB/s. Local copying to it is also very slow. The strange thing is that if I copy to this drive connected to RPi from my Notebook over NFS it copies with 5MB/s. On RPi i have Raspbian 9 (stretch).
Re: Copying to USB HDD is very slow
Posted: Sun Oct 13, 2019 10:55 am
by LTolledo
RPi3B has only USB2.0 ports.
smb copy over LAN connection gave me about 7MB/s
what does
hdparm -tT /dev/sda1 (assuming your HDD is auto-mounted as /dev/sda1) give you?
Posted: Sun Oct 13, 2019 11:16 am
by zeitalex
sudo hdparm -tT /dev/sda1
/dev/sda1:
 Timing cached reads:   1282 MB in  2.00 seconds = 640.70 MB/sec
 Timing buffered disk reads:  16 MB in  3.33 seconds =   4.80 MB/sec
If i am on Pi and doing rsync locally (from one local usb drive to "problematic" local usb drive), it copies with 1MB/s, but if i am on my notebook an copying over nfs from/to same drives connected to RPi it is much faster and gives about 5MB/s. I noticed that this problem is mainly occurs if copying with sudo. Without sudo rsync local copy on RPi gives sometimes 20MB/s.
Posted: Sun Oct 13, 2019 2:13 pm
by LTolledo
just to compare, below is the output when I ran the same command on this SSD boot RPi3B Raspbian Stretch with Full Desktop.
with a hard disk (2.5" Marshal 1TB in Orico HDD to SATA case adapter) connected to the RPi3B via powered USB 2.0 hub
 $ sudo hdparm -tT /dev/sdb1
/dev/sdb1:
 Timing cached reads:   1314 MB in  2.00 seconds = 657.03 MB/sec
 Timing buffered disk reads:  98 MB in  3.01 seconds =  32.51 MB/sec
the result of the buffered disk read is the expected value for a drive connected to a USB2.0 port of RPi
and here is there result when I plugged in my "very old" 2.5" 80GB PATA drive in a PATA to USB2.0 case
~ $ sudo hdparm -tT /dev/sdb1
/dev/sdb1:
 Timing cached reads:   1174 MB in  2.00 seconds = 586.77 MB/sec
 Timing buffered disk reads:  88 MB in  3.05 seconds =  28.89 MB/sec
and its still within expectations
Posted: Mon Oct 14, 2019 7:51 am
by zeitalex
Today I started hdparm -tT /dev/sda1 again and "Timing buffered disk reads" was 28 MB/sec. Obviously first time was another process that was writing to hdd at the same time and this was the reason why "Timing buffered disk reads" was 4.80 MB/sec. But still I have problem that /dev/sda1 is very slow even if "sudo rsync" is only process that is writing to hdd.
Posted: Mon Oct 14, 2019 8:14 am
by RaTTuS
buffered reads is a red herring
dd if=/dev/zero of=test bs=524288 count=2048
will write 1GB to your device in a file called test
change test to point to your mounted drive
and give the results
rsync will give various results depending on what it there already etc..
Posted: Mon Oct 14, 2019 10:06 am
by gkreidl
FYI, on my RPi 3B this gives 27,5 MB/s (USB HDD connected via USB2)
On my RPi 4B I get 142 MB/s (USB HDD connected via USB3)
Posted: Mon Oct 14, 2019 10:22 am
by zeitalex
I am getting 3,7 MB/s:
pi@raspberrypi:/media/usb0/Tests $ dd if=/dev/zero of=./test bs=524288 count=2048
2048+0 records in
2048+0 records out
1073741824 bytes (1,1 GB, 1,0 GiB) copied, 293,408 s, 3,7 MB/s
Posted: Tue Oct 15, 2019 3:54 pm
by zeitalex
Following I am getting on RPi (usb0 connected to RPi):
pi@raspberrypi:~ $ dd if=/dev/zero of=/media/usb0/Tests/test bs=524288 count=2048
2048+0 records in
2048+0 records out
1073741824 bytes (1,1 GB, 1,0 GiB) copied, 296,676 s, 3,6 MB/s
and this I am getting on my notebook on the same folder connected with NFS:
user@notebook:/media/user/NFS/Tests$ dd if=/dev/zero of=test bs=524288 count=2048
2048+0 Datensätze ein
2048+0 Datensätze aus
1073741824 Bytes (1,1 GB, 1,0 GiB) kopiert, 193,729 s, 5,5 MB/s
Why writing over network is faster than local writing?
Posted: Tue Oct 15, 2019 4:08 pm
by RaTTuS
what filesystem are you running on those usb drives
Posted: Tue Oct 15, 2019 5:41 pm
by zeitalex
In both cases it is the same disk and it is ext4. It is connected to RPi. In first case i am starting dd on RPi directly, and in second case i am starting dd on my notebook over NFS mount pointing to the same disk connected to RPi.
Posted: Tue Oct 15, 2019 6:50 pm
by zeitalex
If this hdd connected to notebook directly, it gives 42,1 MB/s:
$ dd if=/dev/zero of=test1 bs=524288 count=2048
1073741824 Bytes (1,1 GB, 1,0 GiB) kopiert, 25,5065 s, 42,1 MB/s
even if I connect hdd directly to very old RPi1 it gives me 12.0MB/s
Posted: Wed Oct 16, 2019 3:09 am
by zeitalex
If after reboot I unmount hdd and do
sudo mount /dev/sda1 /media/usb0/
then I am able to write to it with 36,1 MB/s
Probably something is wrong in my fstab:
PARTUUID=25d6e1ac-01  /boot           vfat    defaults          0       2
PARTUUID=25d6e1ac-02  /               ext4    defaults,noatime  0       1
UUID=fb769947-7836-4897-b2fd-107a6718e413   /media/usb0   ext4   auto,nofail,sync,users,rw   0   0
UUID=1BFD083548529955 /media/usb1 ntfs auto,users,rw 0 0
Posted: Wed Oct 16, 2019 6:35 am
by Kendek
Yes, the sync mount option.
