stefanv
Wi-fi and Bluetooth applet issues after upgrading to Stretch
Sat Oct 12, 2019 1:44 pm
I have just updated one of my Raspbian systems from Jessie to Stretch. The update went well, and everything seems to be working except for two small issues:
  • The bluetooth applet/indicator is missing from the panel at the bottom right of the screen, even though my previously configured bluetooth keyboard is working fine (I'm typing this using it).
  • The wi-fi applet/indicator is showing that there's no connection, even though there is a connection, and it's working fine.
I tried going into the panel preferences to add back the bluetooth applet, and to try removing and re-adding the network applet, but the checkboxes next to both of them are missing:
I've search on-line for solutions, but all I could find are solutions to the wi-fi and/or bluetooth not working at all. Does anyone have any suggestions?
Stefan Vorkoetter: Programmer, hobbyist, amateur watchmaker, pilot, and collector of fountain pens, slide rules, calculators, and watches.
Re: Wi-fi and Bluetooth applet issues after upgrading to Stretch
Sat Oct 12, 2019 1:48 pm
Jessie and Stretch are both end of life and the Raspberry Pi Foundation has never recommended going from one Raspbian Release to another.....
...grab a spare SD Card and start with Raspbian Buster:
https://www.raspberrypi.org/blog/buster ... -raspbian/
Retired disgracefully.....
stefanv
Sat Oct 12, 2019 2:13 pm
If they were end-of-life, it wouldn't have been possible to do the upgrade. Jessie is not EOL (i.e. no more security updates) until June 2020. Stretch is not EOL until June 2022.
Starting a new system from scratch is a pain, as there's just too much stuff to set up all over again.
Sat Oct 12, 2019 2:18 pm
Debian and Raspbian have a different end of life.
RPF / RPT have stated in various posts that they will only provided "critical" updates if and when absolutely necessary.
The advice is as stated in various Blogs to start with a fresh install.
You are more than welcome to disagree and I hope you can fix your issues and have made back ups !!
stefanv
Sat Oct 12, 2019 2:51 pm
Thanks. Yes, I made a backup of my Jessie image before updating it, so I can easily go back if need be. But FWIW, I have several Raspbian Jessie systems, and I regularly update them and get lots of updates, so clearly someone is still maintaining Jessie.
stefanv
Sat Oct 12, 2019 5:12 pm
I managed to fix both issues. There is a different network manager to select from the panel applets, and that one shows up and works. I fixed the bluetooth applet using
sudo apt-get install --reinstall blueman
