g35
Raspbian - USB drive not showing up under Eject menu in top right
Sat Oct 12, 2019 4:23 am
I'm very new to Linux, Raspberry Pi, command line, all that stuff.
The first time I plugged in my USB hard drive, I plugged it in and it showed up on the desktop. When I wanted to unplug it, I used the Eject icon in the top right and then unplugged it. Seemed simple.
I'm not sure what I did wrong now, but I was following this tutorial: https://medium.com/@aallan/adding-an-ex ... 321efce86a)
I finished the part of that tutorial where you edit fstab.
Now when I plug in the hard drive, it's not showing up on the desktop. I mount it using the command
sudo mount /dev/sda1 /mnt/usb
and when I use command df, it shows up in the list, but not on the desktop (though I can access the files in /mnt/usb).
What do I need to do to get the hard drive to show on the desktop, and under the Eject button when I plug it in?
Another question I have is when I use the eject button, do I also need to use the command line to unmount it using command umount?
Thank you.
Here are my outputs:
dmesg:
[ 1609.577418] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[ 1609.709060] usb 1-1.4: New USB device found, idVendor=0bc2, idProduct=ab24, bcdDevice= 1.00
[ 1609.709076] usb 1-1.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1609.709086] usb 1-1.4: Product: BUP Slim BK
[ 1609.709095] usb 1-1.4: Manufacturer: Seagate
[ 1609.709104] usb 1-1.4: SerialNumber: NA9E0NPW
[ 1609.709938] usb 1-1.4: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 1609.709950] usb 1-1.4: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 1609.709962] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 1609.713448] scsi host0: usb-storage 1-1.4:1.0
[ 1610.778468] scsi 0:0:0:0: Direct-Access     Seagate  BUP Slim BK      0304 PQ: 0 ANSI: 6
[ 1610.779483] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1610.781571] sd 0:0:0:0: [sda] Spinning up disk...
[ 1611.817541] ...ready
[ 1613.898751] sd 0:0:0:0: [sda] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1613.931746] sd 0:0:0:0: [sda] Write Protect is off
[ 1613.931763] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 1613.932270] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1613.972483]  sda: sda1
[ 1613.976516] sd 0:0:0:0: [sda] Attached SCSI disk
lsusb -v:
Bus 001 Device 006: ID 0bc2:ab24 Seagate RSS LLC Backup Plus Portable Drive
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bc2 Seagate RSS LLC
  idProduct          0xab24 Backup Plus Portable Drive
  bcdDevice            1.00
  iManufacturer           2
  iProduct                3
  iSerial                 1
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0055
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           4
      bInterfaceProtocol     98
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Data-in pipe (0x03)
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Data-out pipe (0x04)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Status pipe (0x02)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Command pipe (0x01)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0027
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      0
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idProduct          0x9514 SMC9514 Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.19
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
uname -a:
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
klricks
Re: Raspbian - USB drive not showing up under Eject menu in top right
Sat Oct 12, 2019 6:28 pm
You can drag & drop any folder from file-manager to the desktop.
Normally one would not fstab a drive that was intended to be used as removable media (hot swap)... Just let the automount feature do its job.
g35
Fri Oct 18, 2019 12:25 am
Thanks for your help. I will let automout do its job next time.
I figured out the issue too, I needed to make my mount point /media/pi/whatever, this allows Raspbian to automatically show the drive on the desktop.
HawaiianPi
Fri Oct 18, 2019 12:35 am
Yes, that's where the file manager automounts removable drives (/media/{username}/{drivename}), and drives manually mounted in the same fashion will also show on the desktop. However, if you manually mount it, you will have to manually unmount it.
LTolledo
Fri Oct 18, 2019 1:41 am
if you mounted the USB drive in /mnt it will not show up in desktop
I did tried an "old" advice by HawaiianPi and it worked
open terminal
type in
cd /home/pi/Desktop
ln -s /mnt/usb
after than a folder will appear on your desktop....
clicking it will show the contents of the folder (if mounted) or an empty folder (if not mounted)
applied this to my RPi4B-4G Buster with full desktop accessing my NAS drives...
not tried it with removable drives locally plugged to the RPi4B....
Some people be like:
