scyle
Raspberry Pi 4 + Powered USB Hub + 2,5" SSD not working
Tue Oct 08, 2019 9:54 pm
i have an RPi 4 which i do want to use as a NAS. The problem i encounter is that the Pi is most of the time not recognizing my SSD.
If i am lucky everything is recognized looking like this in dmesg:
[ 1125.462594] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 1125.497649] usb 2-1: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.26
[ 1125.497665] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1125.497677] usb 2-1: Product: USB3.1 Hub
[ 1125.497689] usb 2-1: Manufacturer: GenesysLogic
[ 1125.499652] hub 2-1:1.0: USB hub found
[ 1125.500036] hub 2-1:1.0: 4 ports detected
[ 1125.592203] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ 1125.725021] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.26
[ 1125.725035] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1125.725048] usb 1-1.1: Product: USB2.0 Hub
[ 1125.725060] usb 1-1.1: Manufacturer: GenesysLogic
[ 1125.727619] hub 1-1.1:1.0: USB hub found
[ 1125.727969] hub 1-1.1:1.0: 4 ports detected
[ 1126.042187] usb 1-1.1.4: new high-speed USB device number 4 using xhci_hcd
[ 1126.174415] usb 1-1.1.4: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 1126.174430] usb 1-1.1.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1126.174442] usb 1-1.1.4: Product: Ugreen Storage Device
[ 1126.174454] usb 1-1.1.4: Manufacturer: Ugreen
[ 1126.174466] usb 1-1.1.4: SerialNumber: 123458DDE098
[ 1126.180909] scsi host1: uas
[ 1126.183643] scsi 1:0:0:0: Direct-Access CT2000MX 500SSD1 0 PQ: 0 ANSI: 6
[ 1126.185733] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 1126.186869] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1126.186883] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 1126.187232] sd 1:0:0:0: [sdb] Write Protect is off
[ 1126.187246] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 1126.188112] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1126.188614] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 1126.196967] sdb: sdb1
[ 1126.201237] sd 1:0:0:0: [sdb] Attached SCSI disk
If i start the Pi with the Hub connected it is not even booting. If i connect the hub + ssd later the dmesg log has error like these
[ 22.411934] usb 1-1.1.4: device descriptor read/64, error -110
[ 22.631636] usb 1-1.1.4: new high-speed USB device number 5 using xhci_hcd
[ 27.771933] usb 1-1.1.4: device descriptor read/64, error -110
[ 43.131962] usb 1-1.1.4: device descriptor read/64, error -110
[ 43.252083] usb 1-1.1-port4: attempt power cycle
[ 43.911648] usb 1-1.1.4: new high-speed USB device number 6 using xhci_hcd
[ 45.864629] usb 1-1.1.4: Device not responding to setup address.
[ 48.034523] usb 1-1.1.4: Device not responding to setup address.
[ 48.251631] usb 1-1.1.4: device not accepting address 6, error -71
[ 48.351646] usb 1-1.1.4: new high-speed USB device number 7 using xhci_hcd
[ 50.304710] usb 1-1.1.4: Device not responding to setup address.
[ 52.474558] usb 1-1.1.4: Device not responding to setup address.
[ 52.691634] usb 1-1.1.4: device not accepting address 7, error -71
[ 52.691977] usb 1-1.1-port4: unable to enumerate USB device
Hardware i use
Any ideas what i could be doing wrong here? Everything works fine if i connect the hub / ssd to Ubuntu Desktop or Windows 10.
scyle
Re: Raspberry Pi 4 + Powered USB Hub + 2,5" SSD not working
Sat Oct 12, 2019 2:40 pm
Can i provide any more information that would be helpful to solve this problem?
I read that there are problems with certain active USB Hubs and SSD to SATA Connector cables (/chipsets). Could that maybe be a problem? If so will this be fixed from the RPi side (software update) or do i need a new hub / connector? Is there a list of known working hubs/connectors? I selected the given hub because i saw it being used in a YT Video (https://www.youtube.com/watch?v=O-FfOWdZAQ4) and the hard drive enclosure has a specific chipset (ASM1153E) which i read somewhere would work with the RPi 4.
k-pi
Sat Oct 12, 2019 5:51 pm
The RPi4 doesn't boot from USB yet, (still waiting for that since launch)........ so you have to start up using a microSD card with the /boot on it, the rest can be on your USB drive.
scyle
Sat Oct 12, 2019 9:51 pm
Oh i do not want to boot from the SSD! I have a microSD card with raspian on it. I only want to attach the SSD to store all my data.
LTolledo
Sat Oct 12, 2019 10:07 pm
is your ssd recognized by Rpi4 if connected directly to the USB3.0 port (not use USB hub)?
if its only 1 (or 2) SSDs, then the RPi's 2x3.0USB ports are sufficient.
well.... I tried connecting my Crucial BX500 SSD to this RPi4B-4G desktop, and it was recognized immediately and mounted properly.
am using Sabrent SATA to USB3.0 adapter on this one....
Some people be like:
Andyroo
Sat Oct 12, 2019 10:08 pm
What happens if:
1) You plug the drive directly into the USB2?
2) You plug the drive directly into the USB3?
I cannot imagine the SSD needs more power then my old HDD I’ve got running on the 3B+ but
3) What is your power supply?
4) Do you have anything else in the USB ports?
scyle
Sun Oct 13, 2019 2:42 pm
Thank you for the feedback.
I tried connecting the SSD directly to the USB 3.0 ports but it is not detected (dmesg has no output; sudo fdisk -l does not list any drive and lsusb does not show any device).
If i connect the drive to the USB 2.0 ports it does work. Kindof. I set up samba with a file share (samba config below). I started copying 7gb of files to the drive which worked fine. Then i wanted to playback one of the videos and all of a sudden the drive disconnected (dmesg output below). I retried it with the USB hub (on the same USB 2.0 port) and that seems to work. I was able to copy > 20gb of of data and still playback videos, open documents, etc.
As a power supply i am using the official one (https://www.raspberrypi.org/products/ty ... er-supply/). There are no other devices connected to the RPi. I tried using a USB flash drive on the USB 3 ports and that was detected and i was able to access the files on it. Interesstingly if i connect the USB Hub to the USB 3 Ports and connect the flash drive to the hub the flash drive is also not detected.
Samba config
/etc/samba/smb.conf
# Global parameters
[global]
        client max protocol = SMB3
        client min protocol = SMB2
        log file = /var/log/samba/log.%m
        logging = file
        map to guest = Bad User
        max log size = 1000
        obey pam restrictions = Yes
        pam password change = Yes
        panic action = /usr/share/samba/panic-action %d
        passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
        passwd program = /usr/bin/passwd %u
        server role = standalone server
        unix password sync = Yes
        usershare allow guests = Yes
        idmap config * : backend = tdb
        map acl inherit = Yes
        vfs objects = acl_xattr
[data-one]
        path = /mnt/data-one
        read only = No
        valid users = @users
dmesg output after SSD disconnect while trying to play video
[  595.036109] usb 1-1.3: stat urb: status -71
[  595.036176] usb 1-1.3: cmd cmplt err -71
[  595.036445] usb 1-1.3: stat urb: status -71
[  595.036710] usb 1-1.3: cmd cmplt err -71
[  595.184099] usb 1-1.3: USB disconnect, device number 3
[  595.184540] sd 0:0:0:0: [sda] tag#21 uas_zap_pending 0 uas-tag 1 inflight: CMD
[  595.184557] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 58 53 52 08 00 01 f8 00
[  595.184578] sd 0:0:0:0: [sda] tag#28 uas_zap_pending 0 uas-tag 2 inflight: CMD
[  595.184591] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 58 53 52 00 00 00 08 00
[  595.184601] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[  595.184618] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 58 53 52 08 00 01 f8 00
[  595.184625] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[  595.184635] print_req_error: I/O error, dev sda, sector 1481855496
[  595.184643] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 58 53 52 00 00 00 08 00
[  595.184654] print_req_error: I/O error, dev sda, sector 1481855488
[  595.184790] print_req_error: I/O error, dev sda, sector 1481855496
[  595.184828] print_req_error: I/O error, dev sda, sector 1481855488
[  595.188092] print_req_error: I/O error, dev sda, sector 2408
[  595.188110] Buffer I/O error on dev sda1, logical block 45, lost async page write
[  595.188139] print_req_error: I/O error, dev sda, sector 1476397312
[  595.188152] Buffer I/O error on dev sda1, logical block 184549408, lost async page write
[  595.188177] print_req_error: I/O error, dev sda, sector 1488980032
[  595.188189] Buffer I/O error on dev sda1, logical block 186122248, lost async page write
[  595.188209] Buffer I/O error on dev sda1, logical block 186122249, lost async page write
[  595.188230] Buffer I/O error on dev sda1, logical block 186122250, lost async page write
[  595.188254] print_req_error: I/O error, dev sda, sector 1488980224
[  595.188265] Buffer I/O error on dev sda1, logical block 186122272, lost async page write
[  595.192855] print_req_error: I/O error, dev sda, sector 1950620584
[  595.192888] Aborting journal on device sda1-8.
[  595.192949] print_req_error: I/O error, dev sda, sector 1950615552
[  595.192975] Buffer I/O error on dev sda1, logical block 243826688, lost sync page write
[  595.193046] JBD2: Error -5 detected when updating journal superblock for sda1-8.
[  596.978013] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  597.572632] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[  603.899675] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534355: block 184549409: comm smbd: unable to read itable block
[  603.900736] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534355: block 184549409: comm smbd: unable to read itable block
[  603.900827] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534355: block 184549409: comm smbd: unable to read itable block
[  603.901194] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  603.901373] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  603.901991] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  603.902148] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  603.902354] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  603.902795] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534355: block 184549409: comm smbd: unable to read itable block
[  603.903143] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534355: block 184549409: comm smbd: unable to read itable block
[  609.085727] EXT4-fs error: 11 callbacks suppressed
[  609.085738] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  609.085814] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  609.129161] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  609.129234] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  609.135849] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  609.136009] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  609.136175] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  609.136504] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  609.136654] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  609.137070] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  615.966827] EXT4-fs error: 27 callbacks suppressed
[  615.966838] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  615.966953] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  615.967254] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  615.967837] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  615.967905] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  615.968162] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  617.138961] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  617.139037] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  617.139331] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  617.253775] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  630.882966] EXT4-fs error: 47 callbacks suppressed
[  630.882977] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  630.883056] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  630.883358] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  630.884070] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  630.884137] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  630.884388] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  632.263506] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  632.263582] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  632.263869] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  632.403190] EXT4-fs error (device sda1): __ext4_get_inode_loc:4678: inode #11534337: block 184549408: comm smbd: unable to read itable block
[  657.518940] EXT4-fs error: 47 callbacks suppressed
[  657.518952] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.519031] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.519329] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.519986] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.520052] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.520306] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #11534337: comm smbd: reading directory lblock 0
[  657.976026] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  657.976095] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  657.976298] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  657.977216] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.427948] EXT4-fs error: 4 callbacks suppressed
[  723.427960] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.428035] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.428252] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.428835] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.428897] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
[  723.429073] EXT4-fs error (device sda1): ext4_find_entry:1455: inode #2: comm smbd: reading directory lblock 0
scyle
Sat Oct 19, 2019 1:44 pm
I found an old 2,5" spinning disk including an external enclosure. So i tried that drive and it worked. No problem on USB 2 / 3 or with / without the Hub. After that i put that old drive into the Ugreen enclosure which didn't work on USB 3 with the 2 TB drive. Again everything worked. That surprissed me. Next up i put the 2 TB drive into the old enclosure and ... everything works. I put the 2 TB drive in the Ugreen enclosure and STILL EVERYTHING WORKS. WHAT?! I don't get it. I am getting more and more confused on what is going on with this setup.
Also the transfer speed is quite slow. Even tough everything is connected via USB 3 and 1gbit LAN i get transfer speeds of around 20-40mb/s.
Kendek
Sat Oct 19, 2019 2:12 pm
Lots of bugs have been fixed in the kernel, so maybe an update helped in your case.
scyle
Sun Oct 20, 2019 8:23 pm
I did not update the system in between the last tries. So an update couldn't be it.
I just tried to use the RPi again and there was the same problem. SSD not recognized. I did not touch anything between today and the other day when everything was working. dmesg showing:
[   22.411958] usb 1-1.2.2: device descriptor read/64, error -110
[   22.631607] usb 1-1.2.2: new high-speed USB device number 5 using xhci_hcd
[   27.771881] usb 1-1.2.2: device descriptor read/64, error -110
[   43.131874] usb 1-1.2.2: device descriptor read/64, error -110
[   43.252033] usb 1-1.2-port2: attempt power cycle
[   43.911594] usb 1-1.2.2: new high-speed USB device number 6 using xhci_hcd
[   45.864785] usb 1-1.2.2: Device not responding to setup address.
[   48.034783] usb 1-1.2.2: Device not responding to setup address.
[   48.251584] usb 1-1.2.2: device not accepting address 6, error -71
[   48.351582] usb 1-1.2.2: new high-speed USB device number 7 using xhci_hcd
[   50.304859] usb 1-1.2.2: Device not responding to setup address.
[   52.474790] usb 1-1.2.2: Device not responding to setup address.
[   52.691577] usb 1-1.2.2: device not accepting address 7, error -71
[   52.691921] usb 1-1.2-port2: unable to enumerate USB device
