amcdonley
aplay and espeak issues after (Stretch) OS update
Mon Sep 23, 2019 1:49 am
I had aplay and espeak (text-to-speech) working great for the last year, until this week I executed the OS update sequence:
sudo apt-get update
sudo apt-get upgrade
$ uname -a
Linux Carl 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
Now aplay is cutting off the last part of a wav file:
aplay /usr/share/sounds/alsa/Front_Center.wav
says "Front Cent" without the "er" which it previously played flawlessly.
espeak stopped working completely until I added the following to my /home/pi/.bashrc:
PA_ALSA_PLUGHW=1
export PA_ALSA_PLUGHW
(and rescanned with `source .bashrc` )
Now espeak is working but the speech has a lot of distortion.
(regardless of my alsamixer pcm output level btw)
Errors reported after update:
pi@Carl:~/Carl $ espeak "hello there. Am I speaking with any distortion now with the speech-dispatcher installed?"
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
connect(2) call to /tmp/jack-1000/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
and for reference, before the update espeak generated a shorter list of errors:
$ uname -a
Linux Carl 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
pi@Carl:~/Carl $ espeak "hi"
