Installing Problems
Posted: Wed Sep 04, 2019 1:38 am
by BioHazard1282
This started happening recently. This hasn't happened before, but I keep receiving errors whenever I try to install anything at all. It downloads packages fine, but whenever it meets 50% in the installation process, it quits out with an error "exit status 1" or something. It's super annoying. >:/
The software seems to work fine, but how can I fix this problem in the future?
Re: Installing Problems
Posted: Wed Sep 04, 2019 7:52 am
by DirkS
Please post full error messages
Posted: Sun Sep 29, 2019 2:00 pm
by BioHazard1282
Okay, so I try to install software (like Thonny and Visual Studio Code), but I receive this error when I try to install, update, or upgrade anything. Including the Raspbian OS.
● dirsrv-admin.service - 389 Administration Server.
   Loaded: loaded (/lib/systemd/system/dirsrv-admin.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2019-09-29 07:56:15 MDT; 38ms ago
  Process: 8070 ExecStart=/usr/sbin/apache2 -k start -f /etc/dirsrv/admin-serv/httpd.conf (code=exited, status=1/FAILURE)
Sep 29 07:56:15 Bio_Hazard1282_rPi3 systemd[1]: Starting 389 Administration Server....
Sep 29 07:56:15 Bio_Hazard1282_rPi3 apache2[8070]: AH00558: apache2: Could not reliably determi…sage
Sep 29 07:56:15 Bio_Hazard1282_rPi3 apache2[8070]: (2)No such file or directory: AH02291: Canno… log
Sep 29 07:56:15 Bio_Hazard1282_rPi3 apache2[8070]: AH00014: Configuration check failed
Sep 29 07:56:15 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Control process exited, …tus=1
Sep 29 07:56:15 Bio_Hazard1282_rPi3 systemd[1]: Failed to start 389 Administration Server..
Sep 29 07:56:15 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Unit entered failed state.
Sep 29 07:56:15 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Failed with result 'exit…ode'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package 389-admin (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of 389-dsgw:
 389-dsgw depends on 389-admin; however:
  Package 389-admin is not configured yet.
dpkg: error processing package 389-dsgw (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of 389-ds-console:
 389-ds-console depends on 389-admin; however:
dpkg: error processing package 389-ds-console (--configure):
dpkg: dependency problems prevent configuration of 389-ds:
 389-ds depends on 389-admin; however:
 389-ds depends on 389-ds-console; however:
  Package 389-ds-console is not configured yet.
 389-ds depends on 389-dsgw; however:
  Package 389-dsgw is not configured yet.
dpkg: error processing package 389-ds (--configure):
Errors were encountered while processing:
 389-admin
 389-dsgw
 389-ds-console
 389-ds
E: Sub-process /usr/bin/dpkg returned an error code (1)
This is really annoying because I can't install any software correctly >:/
Posted: Sun Sep 29, 2019 3:14 pm
by bjtheone
You have a dependency issue. It even tells you so. This means that one package depends on something that is provided by another package, and the second package is not yet installed or configured. Sometimes you get get into a "chicken and egg" situation where package A depends on package B, and package B depends on package A.
"sudo apt-get check" will tell you more about the issue. There are a number of ways to resolve the issue. The simplest is:
sudo apt-get install -f
sudo dpkg –configure -a
This will attempt to fix the broken dependencies.
Then try to install the package in question. If that does not work you are likely going to have to play with dpkg to resolve the issue. Googling for "linux resolving dependancy issues" will provide more info. The good news is that it is almost always fixable.
Forcing installs sometimes creates this problem.
Posted: Sat Oct 05, 2019 2:53 pm
by BioHazard1282
I tried doing your 3 solutions in order, but they all failed.
I visited this webpage https://unix.stackexchange.com/question ... th-apt-get, and tried to follow the same methods this person was doing. I tried using
sudo apt --fix-broken install
to attempt fixing broken installations, but I receive this error:
Job for dirsrv-admin.service failed because the control process exited with error code.
See "systemctl status dirsrv-admin.service" and "journalctl -xe" for details.
invoke-rc.d: initscript dirsrv-admin, action "start" failed.
   Active: failed (Result: exit-code) since Sat 2019-10-05 08:36:34 MDT; 40ms ago
  Process: 2684 ExecStart=/usr/sbin/apache2 -k start -f /etc/dirsrv/admin-serv/httpd.conf (code=exited, status=1/FAILURE)
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: Starting 389 Administration Server....
Oct 05 08:36:34 Bio_Hazard1282_rPi3 apache2[2684]: AH00558: apache2: Could not reliably determi…sage
Oct 05 08:36:34 Bio_Hazard1282_rPi3 apache2[2684]: (2)No such file or directory: AH02291: Canno… log
Oct 05 08:36:34 Bio_Hazard1282_rPi3 apache2[2684]: AH00014: Configuration check failed
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Control process exited, …tus=1
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: Failed to start 389 Administration Server..
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Unit entered failed state.
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Failed with result 'exit…ode'.
 389-admin
 389-dsgw
 389-ds-console
 389-ds
So then I tried looking with this: systemctl status dirsrv-admin.service
   Active: failed (Result: exit-code) since Sat 2019-10-05 08:36:34 MDT; 6min ago
Oct 05 08:36:34 Bio_Hazard1282_rPi3 apache2[2684]: AH00558: apache2: Could not reliably determine th
Oct 05 08:36:34 Bio_Hazard1282_rPi3 apache2[2684]: (2)No such file or directory: AH02291: Cannot acc
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Control process exited, code=e
Oct 05 08:36:34 Bio_Hazard1282_rPi3 systemd[1]: dirsrv-admin.service: Failed with result 'exit-code'
lines 1-13/13 (END)
And journalctl -xe:
Oct 05 08:36:35 Bio_Hazard1282_rPi3 sudo[2631]: pam_unix(sudo:session): session closed for user root
Oct 05 08:37:40 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: Router Advertisement from fe80::6238:e0ff:fe
Oct 05 08:37:40 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: requesting DHCPv6 information
Oct 05 08:40:02 Bio_Hazard1282_rPi3 CRON[2785]: pam_unix(cron:session): session opened for user root
Oct 05 08:40:02 Bio_Hazard1282_rPi3 CRON[2789]: (root) CMD (if [ -x /usr/sbin/debian-edu-update-netb
Oct 05 08:40:02 Bio_Hazard1282_rPi3 CRON[2785]: pam_unix(cron:session): session closed for user root
Oct 05 08:40:06 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: Router Advertisement from fe80::6238:e0ff:fe
Oct 05 08:40:06 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: requesting DHCPv6 information
Oct 05 08:42:17 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: Router Advertisement from fe80::6238:e0ff:fe
Oct 05 08:42:17 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: requesting DHCPv6 information
Oct 05 08:44:59 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: Router Advertisement from fe80::6238:e0ff:fe
Oct 05 08:44:59 Bio_Hazard1282_rPi3 dhcpcd[405]: wlan0: requesting DHCPv6 information
Oct 05 08:45:04 Bio_Hazard1282_rPi3 CRON[2855]: pam_unix(cron:session): session opened for user root
Oct 05 08:45:04 Bio_Hazard1282_rPi3 CRON[2860]: (root) CMD (if [ -x /usr/sbin/debian-edu-update-netb
Oct 05 08:45:04 Bio_Hazard1282_rPi3 CRON[2855]: pam_unix(cron:session): session closed for user root
lines 2417-2435/2435 (END)
Will this help if I re-install Raspbian? (Installing it in Raspbian, I have 4 other OSes with important data I cannot back up, nor can I afford to be deleted.)
