unbannable
Raspberry Pi 4 Ethernet Port Issue
Fri Aug 23, 2019 3:43 pm
So this is the second PI4 I've had with this issue. The first one just did not recognise the ethernet cable whatsoever when the pi3 did. The newer pi4 I received recognised the cable for a bit but then stopped and won't recognise at all now.
What can I do to test the port? Or is it software? Or is it that the moons aren't aligned correctly?
trejan
Re: Raspberry Pi 4 Ethernet Port Issue
Fri Aug 23, 2019 3:47 pm
What model switch is it? There has been some negotiation issues with a D-Link DGS-108 that are worked around in a kernel patch.
ejolson
Sat Aug 24, 2019 4:17 pm
Along a similar line, I just discovered my Pi 4 won't connect with the gigabit switch here. I've done "apt-get update; apt-get upgrade" and the problem still persists. Since the same cables and switch work at gigabit speeds with multiple other computers, I suspect it is related to a negotiation problem. For the record, the switch is this 8-port model by Rosewill.
ejolson
Sat Aug 24, 2019 8:14 pm
Still no luck with the 4B and the Rosewill RC-416 8-port Gigabit Green Switch. I suspect the Pi is unable to wake the ports out of low power idle which is part of IEEE802.3az Energy Efficient Ethernet.
On the Pi I tried forcing 100 mbit mode
# /sbin/ethtool -s eth0 speed 100 duplex full autoneg on
as well as resetting the mii transceiver
# /sbin/mii-tool -r eth0
Neither of those settings helped.
The switch works fine with the Pi 3B+ computer. However, I wanted to use the true gigabit Ethernet and USB3 of the Pi 4B for creating a reasonably quick network file server. It is good that only the 2GB model was available, because that extra pizza I was able to afford due to the resulting savings is a comforting memory at the moment.
Has anyone else tried the Pi 4B with the same Rosewill switch?
As I only have one gigabit switch at home it will be next week before I can try the Pi 4B on a different switch.
Does anyone have an idea how to make the 4B work with my gigabit switch?
johnnywho
Wed Aug 28, 2019 9:14 pm
I'm also facing issues on my Raspberry Pi 4B when plugged over gigabit to a EPC3940 Modem/Router. It does connect, but it's basically unusable. Unfortunately, I haven't found any solutions yet (https://www.raspberrypi.org/forums/view ... p?t=249112)
I really wonder how many switches don't work with the rpi4b.
bls
Wed Aug 28, 2019 9:48 pm
Really sucks when "standard" interfaces have issues. I can confirm that these 3 switches all work with the the Pi4: GS105EV2, GS108Ev3, GS608.
W. H. Heydt
Wed Aug 28, 2019 11:04 pm
To add to the working collection...this one https://www.monoprice.com/product?p_id=10927 from Monoprice works without any issues.
ejolson
Sat Aug 31, 2019 5:23 am
There is another thread here which mentions a number of gigabit switches that work with the Raspberry Pi 4B.
For the record my 4B is confirmed to work with a D-Link switch and a Cisco, but still not the Rosewill. I tried again with the Rosewill. After plugging and unplugging the cable a few times it finally connected, but only at 100 Mbit. I've used different cables that work with other computers.
Rather than anything broken, the problem appears to be an incompatibility.
