Pi zero crashes after cron.hourly [solved]
Posted: Tue Aug 20, 2019 6:59 pm
by Florisjan
Hi
I have a zero Buster running RPI Cam Control and doing some GPIO reading with a python script. I noticed it crashes a couple of times a week, so I have activated the watchdog. From comparing logs at the times of the crashes It is now apparent that the crashes occur after the following line in syslog, every time:
Aug 20 09:17:01 pingpong CRON[28309]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
which is followed by;
Aug 20 09:17:55 pingpong systemd-modules-load[68]: Module 'bcm2835_wdt' is builtin
Aug 20 09:17:55 pingpong fake-hwclock[76]: Tue 20 Aug 09:17:01 UTC 2019
which is the system booting again. The time (approx 45 seconds) can be partially explained by the 15 seconds watchdog delay, but what happens for the remaining 30 I have no clue.
What does catch my attention is the fake-hwclock line, as in the /etc/cron.hourly/ is the fake-hwclock script. Running sudo fake-hwclock save does not crash the pi.
I hope somebody recognises this and can tell me what the cause of this problem is, thanks in advance,
Efjee
Re: Pi zero crashes after cron.hourly
Posted: Wed Aug 21, 2019 7:16 am
by epoch1970
What else is in cron.hourly?
You can summon run-parts in test mode, it will list the files it wants to execute.
Posted: Wed Aug 21, 2019 8:11 am
by Florisjan
Hi
fake-hwclock
is the only thing in there.
Testing it runs fine.
Efjee
Posted: Wed Aug 21, 2019 8:22 am
by Florisjan
It crashed again around midnight.
Aug 21 00:24:00 pingpong rngd[311]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Aug 21 00:39:01 pingpong CRON[15922]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Aug 21 00:39:27 pingpong systemd[1]: Starting Clean php session files...
Aug 21 00:39:29 pingpong systemd[1]: phpsessionclean.service: Succeeded.
Aug 21 00:39:29 pingpong systemd[1]: Started Clean php session files.
Aug 21 00:25:04 pingpong systemd-modules-load[87]: Module 'bcm2835_wdt' is builtin
Aug 21 00:25:04 pingpong fake-hwclock[71]: Wed 21 Aug 00:17:01 UTC 2019
Notice how the time jumps back at boot. I have a python script running which keeps an eye on things, which notices it too. (it writes the current date/time to a file 'last_alive' every 25 seconds)
0 2019-08-21 00:25:21.907731 System up
0 2019-08-21 00:25:21.935923 Sucessfully read last_alive: 21 08 2019 00:57
0 2019-08-21 00:25:22.152511 Last alive is in the future, power failure or watchdog?!: 21 08 2019 00:57
0 2019-08-21 00:25:22.176343 Unexpected system up time, system crash or reboot?
34 2019-08-21 00:59:46.301065 time change detected; old time, seconds: 2019-08-21 00:25:21.926313, 2064.373767
150 2019-08-21 02:55:24.167758 planned shutdown
0 2019-08-21 02:56:10.377447 System up
0 2019-08-21 02:56:10.393866 Sucessfully read last_alive: 21 08 2019 02:54
0 2019-08-21 02:56:10.527730 Sucessfully read restart_invoked: 21 08 2019 02:55
0 2019-08-21 02:56:10.530850 Succesfully went through shutdown/startup loop
4 2019-08-21 03:01:08.303060 time change detected; old time, seconds: 2019-08-21 02:56:10.391818, 297.910351
4 2019-08-21 03:01:08.308959 Restart time within expectations, actual restart took (in seconds) 368.308617
Posted: Wed Aug 21, 2019 8:47 am
by rpdom
Then something else is causing it to crash at that time.
The "time going backwards" thing is a normal consequence of the Pi stopping abnormally. It doesn't have a battery powered Real Time Clock like a PC does, so when it turns off it loses the current time and date. It will get the current time/date from the internet time servers during the boot, but initially it works to the last time it "remembers" - which is stored at 17 minutes past each hour from the cron.hourly routines (that's the "fake-hwclock" program) and on a clean shutdown/reboot.
As your time "jumped back" to 00:17:01, I will assume the cron.hourly for fake-hwclock worked.
So something else after that is causing the issue.
Posted: Wed Aug 21, 2019 9:29 am
by Florisjan
That's what I'm thinking. But how do I find out? There is nothing in the logs anywhere after that..
Posted: Wed Aug 21, 2019 9:49 am
by rpdom
Well, your old time was 2019-08-21 00:25:21.926313, so it looks like something that runs at about 25 minutes past midnight - or is triggered earlier, but causes the crash at about 25 past.
It does sound like something that runs from a cron or crontab file. Identifying it could be tricky.
Can you modify your timestamping program to log what was running at the time as well, using "ps -efl" and log that to a file. Maybe that will catch the problem.
Ideally log to severl files, one per minute between 00:15 and 00:30 should be sufficient.
Posted: Wed Aug 21, 2019 11:55 am
by Florisjan
The thing is, it doesn't occur on the same time of day. It does always occur after the cron.hourly job though.
I'll keep copies of ps -efl, that's a good idea. They're not that big and I'll save them timestamped.
You'll hear from me after the next crash.
Efjee
Posted: Wed Aug 21, 2019 12:00 pm
by rpdom
Florisjan wrote: ā†‘
But not immediately after. That job runs every hour, so yes, something that crashes the Pi will always happen at sometime after the most recent run of cron.hourly.
I suspect if you disabled cron.hourly in /etc/crontab you will still get the crashes.
Posted: Fri Aug 23, 2019 3:31 pm
by Florisjan
rpdom wrote: ā†‘
Good point! Hadn't thought of it that way. It's been stable and faithfully logging ever since my last post so I'll have to see what happens.
Efjee
Posted: Sun Aug 25, 2019 12:25 pm
by Florisjan
It Crashed again at 19:17 (from the syslog) but in reality it was about 19:28:xx
So now I have quite a lot of logs to compare, what would be the best thing to look for?
syslog:
Aug 24 19:14:20 pingpong rngd[262]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Aug 24 19:17:01 pingpong CRON[16715]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Aug 24 19:17:21 pingpong systemd-modules-load[68]: Module 'bcm2835_wdt' is builtin
Aug 24 19:17:21 pingpong fake-hwclock[73]: Sat 24 Aug 19:17:01 UTC 2019
Aug 24 19:17:21 pingpong systemd-fsck[93]: e2fsck 1.44.5 (15-Dec-2018)
The last dump made by my script. One is made every 25 seconds. It attempted one more at 19:28:06 but it's blank. I think it's safe to say it crashed within 25 seconds after that.
24-08-2019 19:27:40 up 193 temp: 55.1 system load: 0.37 0.42 0.34
              total        used        free      shared  buff/cache   available
Mem:         378140       63664      186636        7532      127840      254760
Swap:        102396           0      102396
F S UID        PID  PPID  C PRI  NI ADDR SZ WCHAN  STIME TTY          TIME CMD
4 S root         1     0  0  80   0 -  8425 do_epo 16:13 ?        00:00:08 /sbin/init
1 S root         2     0  0  80   0 -     0 kthrea 16:13 ?        00:00:00 [kthreadd]
1 I root         4     2  0  60 -20 -     0 worker 16:13 ?        00:00:03 [kworker/0:0H-mmc_complete]
1 I root         6     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [mm_percpu_wq]
1 S root         7     2  0  80   0 -     0 smpboo 16:13 ?        00:00:44 [ksoftirqd/0]
5 S root         8     2  0  80   0 -     0 devtmp 16:13 ?        00:00:00 [kdevtmpfs]
1 I root         9     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [netns]
1 S root        11     2  0  80   0 -     0 watchd 16:13 ?        00:00:00 [khungtaskd]
1 S root        12     2  0  80   0 -     0 oom_re 16:13 ?        00:00:00 [oom_reaper]
1 I root        13     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [writeback]
1 S root        14     2  0  80   0 -     0 kcompa 16:13 ?        00:00:00 [kcompactd0]
1 I root        15     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [crypto]
1 I root        16     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [kblockd]
1 S root        17     2  0 -40   - -     0 kthrea 16:13 ?        00:00:00 [watchdogd]
1 I root        18     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [rpciod]
1 I root        19     2  0  60 -20 -     0 worker 16:13 ?        00:00:00 [kworker/u3:0-hci0]
1 I root        20     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [xprtiod]
1 S root        23     2  0  80   0 -     0 kswapd 16:13 ?        00:00:00 [kswapd0]
1 I root        24     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [nfsiod]
1 I root        35     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [kthrotld]
1 I root        36     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [iscsi_eh]
1 I root        37     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [dwc_otg]
1 I root        38     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [DWC Notificatio]
1 S root        39     2  0  61 -19 -     0 down_i 16:13 ?        00:01:35 [vchiq-slot/0]
1 S root        40     2  0  61 -19 -     0 down_i 16:13 ?        00:00:04 [vchiq-recy/0]
1 S root        41     2  0  60 -20 -     0 down_i 16:13 ?        00:00:00 [vchiq-sync/0]
1 S root        42     2  0  80   0 -     0 vchiq_ 16:13 ?        00:00:00 [vchiq-keep/0]
1 S root        43     2  0  70 -10 -     0 down_i 16:13 ?        00:00:00 [SMIO]
1 S root        44     2  0   9   - -     0 irq_th 16:13 ?        00:00:00 [irq/86-mmc1]
1 I root        47     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [mmc_complete]
1 S root        51     2  0  80   0 -     0 kjourn 16:13 ?        00:00:00 [jbd2/mmcblk0p2-]
1 I root        52     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [ext4-rsv-conver]
1 I root        53     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [ipv6_addrconf]
4 S root        68     1  0  80   0 -  6481 do_epo 16:14 ?        00:00:03 /lib/systemd/systemd-journald
4 S root       108     1  0  80   0 -  4535 do_epo 16:14 ?        00:00:01 /lib/systemd/systemd-udevd
1 S root       119     2  0  70 -10 -     0 vc_sm_ 16:14 ?        00:00:00 [SMIO]
1 I root       127     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       129     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       135     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       136     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       137     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       160     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [cfg80211]
1 I root       164     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [brcmf_wq/mmc1:0]
1 S root       165     2  0  80   0 -     0 brcmf_ 16:14 ?        00:00:00 [brcmf_wdog/mmc1]
1 I root       184     2  0  80   0 -     0 worker 16:14 ?        00:00:01 [kworker/u2:2-events_unbound]
4 S systemd+   202     1  0  80   0 -  5588 do_epo 16:14 ?        00:00:01 /lib/systemd/systemd-timesyncd
4 S root       248     1  0  80   0 -  6151 poll_s 16:14 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
4 S root       251     1  0  80   0 -  6904 do_epo 16:14 ?        00:00:00 /usr/sbin/cupsd -l
4 S root       252     1  0  99  19 -   919 poll_s 16:14 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
1 S root       262     1  0  80   0 -  6910 hrtime 16:14 ?        00:00:03 /usr/sbin/rngd -r /dev/hwrng
4 S root       270     1  0  80   0 -  1989 hrtime 16:14 ?        00:00:00 /usr/sbin/cron -f
4 S avahi      276     1  0  80   0 -  1439 poll_s 16:14 ?        00:00:00 avahi-daemon: running [pingpong.local]
4 S root       282     1  0  80   0 -  3245 do_epo 16:14 ?        00:00:00 /lib/systemd/systemd-logind
4 S nobody     288     1  0  80   0 -  1076 poll_s 16:14 ?        00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
4 S message+   292     1  0  80   0 -  1636 do_epo 16:14 ?        00:00:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
1 S avahi      296   276  0  80   0 -  1439 unix_s 16:14 ?        00:00:00 avahi-daemon: chroot helper
4 S root       309     1  0  80   0 -  2671 poll_s 16:14 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
4 S root       330     1  0  80   0 - 10075 poll_s 16:14 ?        00:00:00 /usr/sbin/cups-browsed
5 S root       344     1  0  80   0 -  2769 poll_s 16:14 ?        00:00:00 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
1 I root       368     2  0  60 -20 -     0 worker 16:14 ?        00:00:00 [kworker/u3:1-hci0]
1 S root       369     1  0  80   0 -   531 poll_s 16:14 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:14:9a:0c
4 S root       372     1  0  80   0 -  2380 poll_s 16:14 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
5 S root       427     1  0  80   0 -   720 do_epo 16:14 ?        00:00:00 /sbin/dhcpcd -q -w
4 S root       443     1  0  80   0 -  1389 inet_c 16:14 ?        00:00:00 /usr/sbin/vsftpd /etc/vsftpd.conf
4 S root       446     1  2  80   0 - 53781 poll_s 16:14 ?        00:05:41 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
4 S root       448     1  0  80   0 -  2667 poll_s 16:14 ?        00:00:00 /usr/sbin/sshd -D
4 S root       449     1  0  80   0 -  4239 do_wai 16:14 ?        00:00:16 /usr/bin/python /home/pi/control/control.py
4 S root       450     1  0  80   0 -  3136 poll_s 16:14 ?        00:01:23 /usr/bin/python /home/pi/control/smart.py
1 S root       455     1  0  80   0 - 47886 poll_s 16:14 ?        00:00:02 /usr/sbin/apache2 -k start
5 S www-data   456   455  0  80   0 - 47910 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   457   455  0  80   0 - 47896 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   458   455  0  80   0 - 47910 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   459   455  0  80   0 - 47904 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   460   455  0  80   0 - 47896 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
4 S www-data   484     1  0  80   0 -  3635 do_epo 16:14 ?        00:00:00 /lib/systemd/systemd --user
5 S www-data   487   484  0  80   0 -  4200 sys_rt 16:14 ?        00:00:00 (sd-pam)
0 S www-data   505     1  0  80   0 -   890 do_wai 16:14 ?        00:00:00 raspimjpeg
1 S www-data   508   505  6  80   0 - 24026 hrtime 16:14 ?        00:11:38 raspimjpeg
0 S www-data   610     1  0  80   0 - 15004 hrtime 16:14 ?        00:01:26 php /var/www/html/schedule.php
4 S root       619     1  0  80   0 -  1073 poll_s 16:14 tty1     00:00:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
5 S root       627     1  0  58   - -   480 hrtime 16:14 ?        00:00:05 /usr/sbin/watchdog
5 S www-data  1081   455  0  80   0 - 47904 inet_c 16:18 ?        00:00:00 /usr/sbin/apache2 -k start
1 I root     15852     2  0  80   0 -     0 worker 19:07 ?        00:00:00 [kworker/0:0-events_power_efficient]
1 I root     16819     2  0  60 -20 -     0 worker 19:18 ?        00:00:00 [kworker/0:2H]
1 I root     16893     2  0  80   0 -     0 worker 19:18 ?        00:00:00 [kworker/0:1-events]
1 I root     17066     2  0  80   0 -     0 worker 19:20 ?        00:00:00 [kworker/u2:0-flush-179:0]
1 I root     17297     2  0  60 -20 -     0 worker 19:23 ?        00:00:00 [kworker/0:1H]
1 I root     17431     2  0  80   0 -     0 worker 19:25 ?        00:00:00 [kworker/0:2-events_power_efficient]
4 S root     17523   448  0  80   0 -  3042 poll_s 19:26 ?        00:00:00 sshd: root [priv]
5 S sshd     17525 17523  0  80   0 -  2693 poll_s 19:26 ?        00:00:00 sshd: root [net]
4 S root     17526   448  0  80   0 -  3042 poll_s 19:26 ?        00:00:00 sshd: unknown [priv]
5 S sshd     17527 17526  0  80   0 -  2693 poll_s 19:26 ?        00:00:00 sshd: unknown [net]
1 I root     17530     2  0  80   0 -     0 worker 19:26 ?        00:00:00 [kworker/u2:1]
0 S root     17630   449  0  80   0 -   481 do_wai 19:27 ?        00:00:00 sh -c ps -efl >> /home/pi/control/efl/20190824_192740_193_efl.log
0 R root     17631 17630  0  80   0 -  2443 -      19:27 ?        00:00:00 ps -efl
Posted: Mon Aug 26, 2019 8:33 am
by epoch1970
Fail2ban and raspimjpeg work the most.
Iā€™d suspect one of these.
Posted: Fri Aug 30, 2019 2:51 pm
by Florisjan
I was hesitant to do an upgrade, because I won't be near the pi for another few days, but did it anyway because these crashed won't do it a lot of good either. Ever since it hasn't crashed. Fingers crossed.
