Florisjan
Pi zero crashes after cron.hourly [solved]
Tue Aug 20, 2019 6:59 pm
Hi
I have a zero Buster running RPI Cam Control and doing some GPIO reading with a python script. I noticed it crashes a couple of times a week, so I have activated the watchdog. From comparing logs at the times of the crashes It is now apparent that the crashes occur after the following line in syslog, every time:
Aug 20 09:17:01 pingpong CRON[28309]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
which is followed by;
Aug 20 09:17:55 pingpong systemd-modules-load[68]: Module 'bcm2835_wdt' is builtin
Aug 20 09:17:55 pingpong fake-hwclock[76]: Tue 20 Aug 09:17:01 UTC 2019
which is the system booting again. The time (approx 45 seconds) can be partially explained by the 15 seconds watchdog delay, but what happens for the remaining 30 I have no clue.
What does catch my attention is the fake-hwclock line, as in the /etc/cron.hourly/ is the fake-hwclock script. Running sudo fake-hwclock save does not crash the pi.
I hope somebody recognises this and can tell me what the cause of this problem is, thanks in advance,
Efjee
epoch1970
Re: Pi zero crashes after cron.hourly
Wed Aug 21, 2019 7:16 am
What else is in cron.hourly?
You can summon run-parts in test mode, it will list the files it wants to execute.
Florisjan
Wed Aug 21, 2019 8:11 am
Hi
fake-hwclock
is the only thing in there.
Testing it runs fine.
Efjee
Florisjan
Wed Aug 21, 2019 8:22 am
It crashed again around midnight.
Aug 21 00:24:00 pingpong rngd[311]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Aug 21 00:39:01 pingpong CRON[15922]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Aug 21 00:39:27 pingpong systemd[1]: Starting Clean php session files...
Aug 21 00:39:29 pingpong systemd[1]: phpsessionclean.service: Succeeded.
Aug 21 00:39:29 pingpong systemd[1]: Started Clean php session files.
Aug 21 00:25:04 pingpong systemd-modules-load[87]: Module 'bcm2835_wdt' is builtin
Aug 21 00:25:04 pingpong fake-hwclock[71]: Wed 21 Aug 00:17:01 UTC 2019
Notice how the time jumps back at boot. I have a python script running which keeps an eye on things, which notices it too. (it writes the current date/time to a file 'last_alive' every 25 seconds)
0 2019-08-21 00:25:21.907731 System up
0 2019-08-21 00:25:21.935923 Sucessfully read last_alive: 21 08 2019 00:57
0 2019-08-21 00:25:22.152511 Last alive is in the future, power failure or watchdog?!: 21 08 2019 00:57
0 2019-08-21 00:25:22.176343 Unexpected system up time, system crash or reboot?
34 2019-08-21 00:59:46.301065 time change detected; old time, seconds: 2019-08-21 00:25:21.926313, 2064.373767
150 2019-08-21 02:55:24.167758 planned shutdown
0 2019-08-21 02:56:10.377447 System up
0 2019-08-21 02:56:10.393866 Sucessfully read last_alive: 21 08 2019 02:54
0 2019-08-21 02:56:10.527730 Sucessfully read restart_invoked: 21 08 2019 02:55
0 2019-08-21 02:56:10.530850 Succesfully went through shutdown/startup loop
4 2019-08-21 03:01:08.303060 time change detected; old time, seconds: 2019-08-21 02:56:10.391818, 297.910351
4 2019-08-21 03:01:08.308959 Restart time within expectations, actual restart took (in seconds) 368.308617
Wed Aug 21, 2019 8:47 am
Then something else is causing it to crash at that time.
The "time going backwards" thing is a normal consequence of the Pi stopping abnormally. It doesn't have a battery powered Real Time Clock like a PC does, so when it turns off it loses the current time and date. It will get the current time/date from the internet time servers during the boot, but initially it works to the last time it "remembers" - which is stored at 17 minutes past each hour from the cron.hourly routines (that's the "fake-hwclock" program) and on a clean shutdown/reboot.
As your time "jumped back" to 00:17:01, I will assume the cron.hourly for fake-hwclock worked.
So something else after that is causing the issue.
Florisjan
Wed Aug 21, 2019 9:29 am
That's what I'm thinking. But how do I find out? There is nothing in the logs anywhere after that..
Wed Aug 21, 2019 9:49 am
Well, your old time was 2019-08-21 00:25:21.926313, so it looks like something that runs at about 25 minutes past midnight - or is triggered earlier, but causes the crash at about 25 past.
It does sound like something that runs from a cron or crontab file. Identifying it could be tricky.
Can you modify your timestamping program to log what was running at the time as well, using "ps -efl" and log that to a file. Maybe that will catch the problem.
Ideally log to severl files, one per minute between 00:15 and 00:30 should be sufficient.
Florisjan
Wed Aug 21, 2019 11:55 am
The thing is, it doesn't occur on the same time of day. It does always occur after the cron.hourly job though.
I'll keep copies of ps -efl, that's a good idea. They're not that big and I'll save them timestamped.
You'll hear from me after the next crash.
Efjee
Wed Aug 21, 2019 12:00 pm
But not immediately after. That job runs every hour, so yes, something that crashes the Pi will always happen at sometime after the most recent run of cron.hourly.
I suspect if you disabled cron.hourly in /etc/crontab you will still get the crashes.
Florisjan
Fri Aug 23, 2019 3:31 pm
Good point! Hadn't thought of it that way. It's been stable and faithfully logging ever since my last post so I'll have to see what happens.
Efjee
Florisjan
Sun Aug 25, 2019 12:25 pm
It Crashed again at 19:17 (from the syslog) but in reality it was about 19:28:xx
So now I have quite a lot of logs to compare, what would be the best thing to look for?
syslog:
Aug 24 19:14:20 pingpong rngd[262]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Aug 24 19:17:01 pingpong CRON[16715]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Aug 24 19:17:21 pingpong systemd-modules-load[68]: Module 'bcm2835_wdt' is builtin
Aug 24 19:17:21 pingpong fake-hwclock[73]: Sat 24 Aug 19:17:01 UTC 2019
Aug 24 19:17:21 pingpong systemd-fsck[93]: e2fsck 1.44.5 (15-Dec-2018)
The last dump made by my script. One is made every 25 seconds. It attempted one more at 19:28:06 but it's blank. I think it's safe to say it crashed within 25 seconds after that.
24-08-2019 19:27:40 up 193 temp: 55.1 system load: 0.37 0.42 0.34
              total        used        free      shared  buff/cache   available
Mem:         378140       63664      186636        7532      127840      254760
Swap:        102396           0      102396
F S UID        PID  PPID  C PRI  NI ADDR SZ WCHAN  STIME TTY          TIME CMD
4 S root         1     0  0  80   0 -  8425 do_epo 16:13 ?        00:00:08 /sbin/init
1 S root         2     0  0  80   0 -     0 kthrea 16:13 ?        00:00:00 [kthreadd]
1 I root         4     2  0  60 -20 -     0 worker 16:13 ?        00:00:03 [kworker/0:0H-mmc_complete]
1 I root         6     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [mm_percpu_wq]
1 S root         7     2  0  80   0 -     0 smpboo 16:13 ?        00:00:44 [ksoftirqd/0]
5 S root         8     2  0  80   0 -     0 devtmp 16:13 ?        00:00:00 [kdevtmpfs]
1 I root         9     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [netns]
1 S root        11     2  0  80   0 -     0 watchd 16:13 ?        00:00:00 [khungtaskd]
1 S root        12     2  0  80   0 -     0 oom_re 16:13 ?        00:00:00 [oom_reaper]
1 I root        13     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [writeback]
1 S root        14     2  0  80   0 -     0 kcompa 16:13 ?        00:00:00 [kcompactd0]
1 I root        15     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [crypto]
1 I root        16     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [kblockd]
1 S root        17     2  0 -40   - -     0 kthrea 16:13 ?        00:00:00 [watchdogd]
1 I root        18     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [rpciod]
1 I root        19     2  0  60 -20 -     0 worker 16:13 ?        00:00:00 [kworker/u3:0-hci0]
1 I root        20     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [xprtiod]
1 S root        23     2  0  80   0 -     0 kswapd 16:13 ?        00:00:00 [kswapd0]
1 I root        24     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [nfsiod]
1 I root        35     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [kthrotld]
1 I root        36     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [iscsi_eh]
1 I root        37     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [dwc_otg]
1 I root        38     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [DWC Notificatio]
1 S root        39     2  0  61 -19 -     0 down_i 16:13 ?        00:01:35 [vchiq-slot/0]
1 S root        40     2  0  61 -19 -     0 down_i 16:13 ?        00:00:04 [vchiq-recy/0]
1 S root        41     2  0  60 -20 -     0 down_i 16:13 ?        00:00:00 [vchiq-sync/0]
1 S root        42     2  0  80   0 -     0 vchiq_ 16:13 ?        00:00:00 [vchiq-keep/0]
1 S root        43     2  0  70 -10 -     0 down_i 16:13 ?        00:00:00 [SMIO]
1 S root        44     2  0   9   - -     0 irq_th 16:13 ?        00:00:00 [irq/86-mmc1]
1 I root        47     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [mmc_complete]
1 S root        51     2  0  80   0 -     0 kjourn 16:13 ?        00:00:00 [jbd2/mmcblk0p2-]
1 I root        52     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [ext4-rsv-conver]
1 I root        53     2  0  60 -20 -     0 rescue 16:13 ?        00:00:00 [ipv6_addrconf]
4 S root        68     1  0  80   0 -  6481 do_epo 16:14 ?        00:00:03 /lib/systemd/systemd-journald
4 S root       108     1  0  80   0 -  4535 do_epo 16:14 ?        00:00:01 /lib/systemd/systemd-udevd
1 S root       119     2  0  70 -10 -     0 vc_sm_ 16:14 ?        00:00:00 [SMIO]
1 I root       127     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       129     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       135     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       136     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       137     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [mmal-vchiq]
1 I root       160     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [cfg80211]
1 I root       164     2  0  60 -20 -     0 rescue 16:14 ?        00:00:00 [brcmf_wq/mmc1:0]
1 S root       165     2  0  80   0 -     0 brcmf_ 16:14 ?        00:00:00 [brcmf_wdog/mmc1]
1 I root       184     2  0  80   0 -     0 worker 16:14 ?        00:00:01 [kworker/u2:2-events_unbound]
4 S systemd+   202     1  0  80   0 -  5588 do_epo 16:14 ?        00:00:01 /lib/systemd/systemd-timesyncd
4 S root       248     1  0  80   0 -  6151 poll_s 16:14 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
4 S root       251     1  0  80   0 -  6904 do_epo 16:14 ?        00:00:00 /usr/sbin/cupsd -l
4 S root       252     1  0  99  19 -   919 poll_s 16:14 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
1 S root       262     1  0  80   0 -  6910 hrtime 16:14 ?        00:00:03 /usr/sbin/rngd -r /dev/hwrng
4 S root       270     1  0  80   0 -  1989 hrtime 16:14 ?        00:00:00 /usr/sbin/cron -f
4 S avahi      276     1  0  80   0 -  1439 poll_s 16:14 ?        00:00:00 avahi-daemon: running [pingpong.local]
4 S root       282     1  0  80   0 -  3245 do_epo 16:14 ?        00:00:00 /lib/systemd/systemd-logind
4 S nobody     288     1  0  80   0 -  1076 poll_s 16:14 ?        00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
4 S message+   292     1  0  80   0 -  1636 do_epo 16:14 ?        00:00:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
1 S avahi      296   276  0  80   0 -  1439 unix_s 16:14 ?        00:00:00 avahi-daemon: chroot helper
4 S root       309     1  0  80   0 -  2671 poll_s 16:14 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
4 S root       330     1  0  80   0 - 10075 poll_s 16:14 ?        00:00:00 /usr/sbin/cups-browsed
5 S root       344     1  0  80   0 -  2769 poll_s 16:14 ?        00:00:00 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
1 I root       368     2  0  60 -20 -     0 worker 16:14 ?        00:00:00 [kworker/u3:1-hci0]
1 S root       369     1  0  80   0 -   531 poll_s 16:14 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:14:9a:0c
4 S root       372     1  0  80   0 -  2380 poll_s 16:14 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
5 S root       427     1  0  80   0 -   720 do_epo 16:14 ?        00:00:00 /sbin/dhcpcd -q -w
4 S root       443     1  0  80   0 -  1389 inet_c 16:14 ?        00:00:00 /usr/sbin/vsftpd /etc/vsftpd.conf
4 S root       446     1  2  80   0 - 53781 poll_s 16:14 ?        00:05:41 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
4 S root       448     1  0  80   0 -  2667 poll_s 16:14 ?        00:00:00 /usr/sbin/sshd -D
4 S root       449     1  0  80   0 -  4239 do_wai 16:14 ?        00:00:16 /usr/bin/python /home/pi/control/control.py
4 S root       450     1  0  80   0 -  3136 poll_s 16:14 ?        00:01:23 /usr/bin/python /home/pi/control/smart.py
1 S root       455     1  0  80   0 - 47886 poll_s 16:14 ?        00:00:02 /usr/sbin/apache2 -k start
5 S www-data   456   455  0  80   0 - 47910 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   457   455  0  80   0 - 47896 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   458   455  0  80   0 - 47910 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   459   455  0  80   0 - 47904 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data   460   455  0  80   0 - 47896 inet_c 16:14 ?        00:00:00 /usr/sbin/apache2 -k start
4 S www-data   484     1  0  80   0 -  3635 do_epo 16:14 ?        00:00:00 /lib/systemd/systemd --user
5 S www-data   487   484  0  80   0 -  4200 sys_rt 16:14 ?        00:00:00 (sd-pam)
0 S www-data   505     1  0  80   0 -   890 do_wai 16:14 ?        00:00:00 raspimjpeg
1 S www-data   508   505  6  80   0 - 24026 hrtime 16:14 ?        00:11:38 raspimjpeg
0 S www-data   610     1  0  80   0 - 15004 hrtime 16:14 ?        00:01:26 php /var/www/html/schedule.php
4 S root       619     1  0  80   0 -  1073 poll_s 16:14 tty1     00:00:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
5 S root       627     1  0  58   - -   480 hrtime 16:14 ?        00:00:05 /usr/sbin/watchdog
5 S www-data  1081   455  0  80   0 - 47904 inet_c 16:18 ?        00:00:00 /usr/sbin/apache2 -k start
1 I root     15852     2  0  80   0 -     0 worker 19:07 ?        00:00:00 [kworker/0:0-events_power_efficient]
1 I root     16819     2  0  60 -20 -     0 worker 19:18 ?        00:00:00 [kworker/0:2H]
1 I root     16893     2  0  80   0 -     0 worker 19:18 ?        00:00:00 [kworker/0:1-events]
1 I root     17066     2  0  80   0 -     0 worker 19:20 ?        00:00:00 [kworker/u2:0-flush-179:0]
1 I root     17297     2  0  60 -20 -     0 worker 19:23 ?        00:00:00 [kworker/0:1H]
1 I root     17431     2  0  80   0 -     0 worker 19:25 ?        00:00:00 [kworker/0:2-events_power_efficient]
4 S root     17523   448  0  80   0 -  3042 poll_s 19:26 ?        00:00:00 sshd: root [priv]
5 S sshd     17525 17523  0  80   0 -  2693 poll_s 19:26 ?        00:00:00 sshd: root [net]
4 S root     17526   448  0  80   0 -  3042 poll_s 19:26 ?        00:00:00 sshd: unknown [priv]
5 S sshd     17527 17526  0  80   0 -  2693 poll_s 19:26 ?        00:00:00 sshd: unknown [net]
1 I root     17530     2  0  80   0 -     0 worker 19:26 ?        00:00:00 [kworker/u2:1]
0 S root     17630   449  0  80   0 -   481 do_wai 19:27 ?        00:00:00 sh -c ps -efl >> /home/pi/control/efl/20190824_192740_193_efl.log
0 R root     17631 17630  0  80   0 -  2443 -      19:27 ?        00:00:00 ps -efl
epoch1970
Mon Aug 26, 2019 8:33 am
Fail2ban and raspimjpeg work the most.
I’d suspect one of these.
Florisjan
Fri Aug 30, 2019 2:51 pm
I was hesitant to do an upgrade, because I won't be near the pi for another few days, but did it anyway because these crashed won't do it a lot of good either. Ever since it hasn't crashed. Fingers crossed.
