FFmpeg "Illegal instruction" Raspberry Pi Zero W
Posted: Tue Aug 20, 2019 9:00 am
by Ram.Sh
I've been struggling with having FFmpeg run on Pi Zero W, as a newbie I can't say where the root of the problem whether its the compilation configuration of the FFmpeg or maybe the syntax of the command line itself..
The current configuration is:
Raspberry Pi Zero Wireless
Set GPU memory to 256
Running OS:
Linux raspberrypi 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
FFmpeg version and configuration:
ffmpeg version N-94582-gd0fa1a58da Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 8 (Raspbian 8.3.0-6+rpi1)
configuration: --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-omx --enable-omx-rpi --enable-nonfree
libavutil 56. 33.100 / 56. 33.100
libavcodec 58. 55.100 / 58. 55.100
libavformat 58. 31.101 / 58. 31.101
libavdevice 58. 9.100 / 58. 9.100
libavfilter 7. 58.100 / 7. 58.100
libswscale 5. 6.100 / 5. 6.100
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
Hyper fast Audio and Video encoder
Command to copy 30 seconds clip from the 10 second mark:
sudo ffmpeg -ss 00:00:10 -t 00:00:30 -i GOPR2546.MP4 -c:v libx264 -c:a copy out.MP4
The FFmpeg output:
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x210d360] Using non-standard frame rate 59/1
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'GOPR2546.MP4':
Metadata:
major_brand : mp41
minor_version : 538120216
compatible_brands: mp41
creation_time : 2019-08-20T11:09:41.000000Z
firmware : HD7.01.01.80.00
Duration: 00:01:00.84, start: 0.000000, bitrate: 45293 kb/s
Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 45043 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 119.88 tbc (default)
Metadata:
handler_name : GoPro AVC
encoder : GoPro AVC encoder
timecode : 11:20:21:32
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default)
Metadata:
handler_name : GoPro AAC
Stream #0:2(eng): Data: none (tmcd / 0x64636D74) (default)
Metadata:
handler_name : GoPro TCD
Stream #0:3(eng): Data: bin_data (gpmd / 0x646D7067), 41 kb/s (default)
Metadata:
handler_name : GoPro MET
Stream #0:4(eng): Data: none (fdsc / 0x63736466), 13 kb/s (default)
Metadata:
handler_name : GoPro SOS
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
Illegal instruction
The result is an empty out.MP4 file... I've tried different configuration but never got it to work.
the one minute input file i'm using to test can be downloaded here
Thank you all in advance!!
Ram
Re: FFmpeg "Illegal instruction" Raspberry Pi Zero W
Posted: Tue Aug 20, 2019 10:05 am
by rpdom
I think the problem may be that you are compiling for armel where Raspbian is armhf. However you will have to specify the particular CPU type. Doing a quick seach on "raspberrypi compiler options" suggests "-mcpu=arm1176jzf-s -mfpu=vfp" may help give the optimal working configuration.
Posted: Tue Aug 20, 2019 11:30 am
by Ernst
Running OS:
VERSION_ID="10"
ID=raspbian
ID_LIKE=debian
Release: 10
Codename: buster
The FFmpeg output:
Metadata:
major_brand : mp41
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Stream mapping:
Illegal instruction
Ram
Why do you set GPU memory to 256 ?
Why do you use that particular version of ffmpeg and not the raspbian version ?
Why do you use sudo ?
ffmpeg is available in the latest (2019-07-10) Raspbian Buster with desktop but must be installed with apt for Raspbian Buster Lite. The RAM size of the Pi 0 W is 512MB, if you install Raspbian Buster with desktop with GPU=256 the memory is reduced to less than 256 MB, the default size of the swap file is 100 MByte.
With desktop, GPU set to 64MB and swap file to 100 MB using your parameters / file fails because of memory problems.
With desktop, GPU set to 16MB and swap file to 1000 MB using your parameters is so slow that becomes a torture to convert
frame=  277 fps=0.1 q=31.0 size=     768kB time=00:00:04.61 bitrate=1363.8kbits/s dup=1 drop=0 speed=0.00191x
With CLI, GPU set to 16MB and swap file to 1000 MB using your parameters is a "bit" faster but still no good.
frame=  187 fps=0.1 q=31.0 size=     512kB time=00:00:03.09 bitrate=1353.7kbits/s dup=1 drop=0 speed=0.00227x
Note I stopped the above jobs because I did not want to wait hours for it to complete.
With Buster Desktop on a Pi3B is only a factor ~25 faster (compared to Pi0W CLI)
frame= 1800 fps=3.4 q=-1.0 Lsize=    6370kB time=00:00:29.97 bitrate=1740.6kbits/s dup=1 drop=0 speed=0.0573x
With Buster Desktop on a Pi4B/4GB is only a factor ~70 faster (compared to Pi0W CLI) but still too slow (for me)
frame= 1800 fps=9.5 q=-1.0 Lsize=    6370kB time=00:00:29.97 bitrate=1740.6kbits/s dup=1 drop=0 speed=0.158x
Now something interesting, on a Windows 7 64-Bit, 3.4Mhz Quad Core with Hyperthreading and 16GB RAM
frame= 1800 fps= 44 q=-1.0 Lsize=    6391kB time=00:00:29.97 bitrate=1746.4kbits/s dup=1 drop=0 speed=0.729x
it is only about 4.6x faster compared to the Pi4B/4GB and 321x faster compared to the Pi0W CLI.
It looks to me that the Pi0W is not powerful enough to do this job, maybe a Pi3A+ might be better if you can wait for the job to complete.
Posted: Tue Aug 20, 2019 12:36 pm
by Ram.Sh
@rpdom, thank you very much for your input!!
I've tried re-configure with the following parameters as your suggestion (is that the correct way?):
added --extra-cflags='-mcpu=-arm1176jzf-s' --extra-ldflags='-mfpu=vfp':
./configure --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-libx265 --extra-cflags='-mcpu=-arm1176jzf-s' --extra-ldflags='-mfpu=vfp' --enable-omx --enable-omx-rpi --enable-nonfree
changed to --arch=armhf
./configure --arch=armhf --target-os=linux --enable-gpl --enable-libx264 --enable-libx265 --extra-cflags='-mcpu=-arm1176jzf-s' --extra-ldflags='-mfpu=vfp' --enable-omx --enable-omx-rpi --enable-nonfree
removed --arch
./configure --target-os=linux --enable-gpl --enable-libx264 --enable-libx265 --extra-cflags='-mcpu=-arm1176jzf-s' --extra-ldflags='-mfpu=vfp' --enable-omx --enable-omx-rpi --enable-nonfree
all options return the following error:
gcc is unable to create an executable file.
C compiler test failed.
re my initial configuration was based on this
Posted: Tue Aug 20, 2019 12:45 pm
by Ram.Sh
@Ernst - thank you for your reply!!
I'm sorry, you mean to tell me that I dont need to spend hours of waiting for the FFmpeg to compile since there's one already installed in the "Raspbian Buster with desktop" version?? man.... do i feel like an idiot right now!
so your recommendation would be to install the Raspbian Buster with desktop version and using the already FFmpeg version in that image and test it from there?
Posted: Tue Aug 20, 2019 1:25 pm
by Ernst
Yes, but reduce the GPU memory to 16MB and increase the swap file size in /etc/dphys-swapfile.
Alternatively using Buster Lite you could install ffmpeg with "sudo apt install ffmpeg -y"
Posted: Tue Aug 20, 2019 1:27 pm
by Ram.Sh
very well, doing it right now, will update once I have news, thanks much!!!
Posted: Tue Aug 20, 2019 3:13 pm
by Ram.Sh
I reinstalled the PI0W with the latest version 2019-07-10 from Raspbian, I reduced the GPU to 16 MB Image
I increased the swap file to 1024 (followed this walk-through)
and the following was my FFmpeg command line:
pi@raspberrypi:/usr/bin $ sudo ffmpeg -ss 00:00:10 -t 00:00:30 -i "/home/pi/Desktop/jpFiles/GOPR2546.MP4" "/home/pi/Desktop/jpFiles/JoyPro2.mp4"
and the output:
ffmpeg version 4.1.4-1+rpt1~deb10u1 Copyright (c) 2000-2019 the FFmpeg developers
configuration: --prefix=/usr --extra-version='1+rpt1~deb10u1' --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --arch=arm --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x1b4ee60] Using non-standard frame rate 59/1
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/pi/Desktop/jpFiles/GOPR2546.MP4':
Metadata:
major_brand : mp41
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Stream mapping:
Stream #0:1 -> #0:1 (aac (native) -> aac (native))
[libx264 @ 0x1b94800] using SAR=1/1
[libx264 @ 0x1b94800] using cpu capabilities: none!
[libx264 @ 0x1b94800] profile High, level 4.2
[libx264 @ 0x1b94800] 264 - core 155 r2917 0a84d98 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=1 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to '/home/pi/Desktop/jpFiles/JoyPro2.mp4':
Metadata:
major_brand : mp41
encoder : Lavf58.20.100
Stream #0:0(eng): Video: h264 (libx264) (avc1 / 0x31637661), yuvj420p(pc), 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, 0.02 fps, 60k tbn, 59.94 tbc (default)
Metadata:
encoder : Lavc58.35.100 libx264
Side data:
cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
Metadata:
encoder : Lavc58.35.100 aac
frame= 41 fps=0.5 q=0.0 size= 0kB time=00:00:00.64 bitrate= 0.7kbits/s dup=1 drop=0 speed=0.00803x
the result is stuck on the last line from above and the output file is 1K.
what do you think I'm missing here?
Posted: Tue Aug 20, 2019 3:26 pm
by Ernst
There are a few possible causes:
1) Are you using a proper power supply or are you using a phone charger ?
2) Is the Pi 0W in a case ? (temperature!)
3) Are you using a quality memory card ?
You must be aware that (this) ffmpeg is a heavy job, this could be causing a heavy load on the power supply and the CPU.
Posted: Tue Aug 20, 2019 3:36 pm
by Ram.Sh
when FFmpeg tries to re-write on the same output file it needs permission
I use 2amp 5v charger
no, when touching the processor its not hot at all
Samsung 128GB 100MB/s (U3) MicroSDXC Evo Class 10
Posted: Tue Aug 20, 2019 5:25 pm
by Ernst
use -y instead
ffmpeg -y -ss 00:00:10 -t 00:00:30 -i "/home/pi/Desktop/jpFiles/GOPR2546.MP4" "/home/pi/Desktop/jpFiles/JoyPro2.mp4"
That could be a problem.
FYI, still running:
 frame=  812 fps=0.1 q=31.0 size=    2560kB time=00:00:13.53 bitrate=1550.0kbits/s dup=1 drop=0 speed=0.00203x
I think it will take a few more hours to complete.
Posted: Wed Aug 21, 2019 6:02 am
by Ernst
Job completed in 258m22.403s (6Hrs 18min 22sec)
frame=  1800 fps=0.1 q=31.0 size=    6739kB time=00:00:29.97 bitrate=1743.2kbits/s dup=1 drop=0 speed=0.00194x
using Raspbian Buster with Desktop, started with console only
on a Pi 0W, 16GB Samsung EVO SD Card, official 5.1V 2.5A power supply
average CPU temperature 57C (idle temperature 40C)
Posted: Wed Aug 21, 2019 6:29 am
by Ram.Sh
thanks so very much for your input!!
something here doesn't make sense to me, in some of my previous (many many) trials where I compiled the FFmpeg by myself on the Pi0W i managed to have it transcode the same video in less than a minute, so I know for a fact that the Pi is capable of handling this much faster than our current results, unfortunately I don't remember which setup I used to compile it and since it didn't support other features I needed I reinstalled other configurations and currently the Buster "Out of the box" version.
in my very humble opinion I guess that the low performance speed is due to the codec currently used?
Posted: Wed Aug 21, 2019 6:38 am
by Ernst
It is very possible that the codec is the performance bottleneck, even on a fast intel PC the performance is not very satisfying.
Posted: Wed Aug 21, 2019 6:45 am
by Ram.Sh
ok then, i'll currently focus on testing different codecs and will update my results here, many thanks for your support!
Posted: Wed Aug 21, 2019 7:32 am
by Ram.Sh
we got major progress!
i installed 264 library
git clone --depth 1 http://git.videolan.org/git/x264
cd x264
./configure --host=arm-unknown-linux-gnueabi --enable-static --disable-opencl
make
sudo make install
i then ran the following command (using the same input file)
ffmpeg -i "/home/pi/Desktop/jpFiles/GOPR2546.MP4" -vcodec copy "/home/pi/Desktop/jpFiles/JoyPro2.mp4"
FFmpeg did the whole movie in 90 seconds!
Posted: Wed Aug 21, 2019 8:40 am
by Ernst
cd x264
make
sudo make install
The reason why is "-vcodec copy", this does not use the codec and therefor installing from a foreign source is unnecessary,
"Stream copy is a mode selected by supplying the "copy" parameter to the -codec option. It makes ffmpeg omit the decoding
and encoding step
for the specified stream, so it does only demuxing and muxing. It is useful for changing the container
format or modifying container-level metadata
You could have installed the codec from the raspberry repository.
pi@raspi7:~ $ sudo apt-cache  search ^x264
libx264-155 - x264 video coding library
x264 - video encoder for the H.264/MPEG-4 AVC standard
In my previous tests I used your original command line as in your first post:
which causes the stream to be decoded and encoded, this is very cpu/memory intensive.
With "-vcodec copy":
pi@raspi7:~ $ ffmpeg -y -i GOPR2546.MP4 -vcodec copy  out.MP4
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x693e40] Using non-standard frame rate 59/1
  Metadata:
    major_brand     : mp41
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
Output #0, mp4, to 'out.MP4':
  Metadata:
    major_brand     : mp41
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 45043 kb/s, 0.02 fps, 59.94 tbr, 60k tbn, 60k tbc (default)
    Metadata:
    Metadata:
frame= 3646 fps= 38 q=-1.0 Lsize=  335481kB time=00:01:00.84 bitrate=45169.9kbits/s speed=0.637x
video:334460kB audio:953kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.020368%
[aac @ 0x6d9c40] Qavg: 2541.830
pi@raspi7:~ $ time ffmpeg -y -ss 00:00:10 -t 00:00:30  -i GOPR2546.MP4 -vcodec copy  out.MP4
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x1043e60] Using non-standard frame rate 59/1
  Metadata:
    major_brand     : mp41
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
Stream mapping:
  Metadata:
    major_brand     : mp41
    Metadata:
    Metadata:
frame= 1858 fps= 42 q=-1.0 Lsize=  170795kB time=00:00:30.01 bitrate=46613.6kbits/s speed=0.684x
video:170289kB audio:471kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.020468%
[aac @ 0x1089c60] Qavg: 138.181
real    0m51.193s
user    0m15.145s
sys     0m5.349s
Posted: Wed Aug 21, 2019 9:01 am
by Ram.Sh
and I thought i had some progress... bummer.
so if I understand you correctly - when I use the following command which works well and fast
sudo ffmpeg -y -ss 00:00:10 -i "/home/pi/Desktop/jpFiles/GOPR2546.MP4" -t 00:00:30 -vcodec copy "/home/pi/Desktop/jpFiles/JoyPro2.mp4"
it uses only the Muxer and does not decoding/encoding the input/output files? and if that the case, if I need to have transcoding during the process like reduce frame rate and frame size it would take hours?
Posted: Wed Aug 21, 2019 9:13 am
by Ernst
Yes
Posted: Wed Aug 21, 2019 9:13 pm
by Ram.Sh
not happy.
thank you very much for your time, effort, your valuable input and most of all your willingness to help me, i appreciate it much!!
i wish you nothing but the best!
RS.
