Graelb
[Help] Installing D-Link AC600 to get 5Ghz networks to a RPi 3B
Tue Aug 20, 2019 1:33 am
I have a Raspberry Pi 3B running LibreElec. I'm trying to get it onto a 5ghz network, so I bought this guy: https://www.amazon.com/gp/product/B00CL ... UTF8&psc=1
I THINK it's seeing it as a wifi adapter, but there is no additional wlan under ifconfig, and I can't see the 5ghz networks.
Is this even possible to install on this guy, while running libreElec? Or should I run a different OS, with Kodi on top instead?
Once the adapter is connected, lsusb shows:
Bus 001 Device 005: ID 0bda:1a2b Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
and lsmod shows:
Module Size Used by
hci_uart 40960 1
btbcm 16384 1 hci_uart
bluetooth 434176 23 hci_uart,btbcm
ecdh_generic 28672 2 bluetooth
serdev 16384 1 hci_uart
brcmfmac 204800 0
brcmutil 16384 1 brcmfmac
cfg80211 512000 1 brcmfmac
rfkill 24576 5 bluetooth,cfg80211
bcm2835_gpiomem 16384 0
fixed 16384 0
dmesg shows this after connecting:
[ 1159.963442] usb 1-1.4: new high-speed USB device number 7 using dwc_otg
[ 1160.053801] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 2.00
[ 1160.053815] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1160.053822] usb 1-1.4: Product: DISK
[ 1160.053829] usb 1-1.4: Manufacturer: D-Link Corporation
[ 1160.054369] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 1160.054689] scsi host1: usb-storage 1-1.4:1.0
[ 1161.076355] scsi 1:0:0:0: Direct-Access Realtek Driver Storage 1.00 PQ: 0 ANSI: 0 CCS
[ 1161.077321] sd 1:0:0:0: [sdb] 16000 512-byte logical blocks: (8.19 MB/7.81 MiB)
[ 1161.079949] sd 1:0:0:0: [sdb] Write Protect is on
[ 1161.079961] sd 1:0:0:0: [sdb] Mode Sense: 03 00 80 00
[ 1161.082618] sd 1:0:0:0: [sdb] No Caching mode page found
[ 1161.082630] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 1161.093157] sdb:
[ 1161.099493] sd 1:0:0:0: [sdb] Attached SCSI removable disk
I'm not sure what to do here.
