zhanghc
Raspberry Pi 4 b USB port has stopped working
Mon Aug 19, 2019 5:34 pm
My Raspberry Pi 4 b USB worked well two days ago. But it‘s not working today.
The keyword and u-disk are not showing in lsusb.
dmesg do not print anything when I plug/unplug the usb devices.
Please help me to find out what is wrong.
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.58-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1245 SMP Fri Jul 12 17:31:45 BST 2019
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[    0.000000] On node 0 totalpages: 504832
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 308224 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 503104
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:0A:27:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=95daf38a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1721836K/2019328K available (8192K kernel code, 658K rwdata, 2340K rodata, 2048K init, 850K bss, 35348K reserved, 262144K cma-reserved, 1232896K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 659 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 27981 entries in 83 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000018] Switching to timer-based delay loop, resolution 18ns
[    0.000240] Console: colour dummy device 80x30
[    0.000262] console [tty1] enabled
[    0.000301] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000323] pid_max: default: 32768 minimum: 301
[    0.000582] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000600] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001339] CPU: Testing write buffer coherency: ok
[    0.001743] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002374] Setting up static identity map for 0x200000 - 0x20003c
[    0.002530] rcu: Hierarchical SRCU implementation.
[    0.003385] smp: Bringing up secondary CPUs ...
[    0.004270] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005278] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006249] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006382] smp: Brought up 1 node, 4 CPUs
[    0.006395] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.006404] CPU: All CPU(s) started in HYP mode.
[    0.006413] CPU: Virtualization extensions available.
[    0.007183] devtmpfs: initialized
[    0.017288] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.017502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017521] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.024825] pinctrl core: initialized pinctrl subsystem
[    0.025652] NET: Registered protocol family 16
[    0.028511] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.029889] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.029899] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.030128] Serial: AMBA PL011 UART driver
[    0.033154] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.068879] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.071281] vgaarb: loaded
[    0.071643] SCSI subsystem initialized
[    0.071835] usbcore: registered new interface driver usbfs
[    0.071885] usbcore: registered new interface driver hub
[    0.071981] usbcore: registered new device driver usb
[    0.090464] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:37, variant start
[    0.100199] raspberrypi-firmware soc:firmware: Firmware hash is d2b1b7fb01475cb3914b2086299e32d724e832f1
[    0.111657] clocksource: Switched to clocksource arch_sys_counter
[    0.188814] VFS: Disk quotas dquot_6.6.0
[    0.188887] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.189041] FS-Cache: Loaded
[    0.189212] CacheFiles: Loaded
[    0.189717] simple-framebuffer: probe of 0.framebuffer failed with error -12
[    0.198731] NET: Registered protocol family 2
[    0.199384] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.199409] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.199475] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.199545] TCP: Hash tables configured (established 8192 bind 8192)
[    0.199664] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.199692] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.199978] NET: Registered protocol family 1
[    0.200498] RPC: Registered named UNIX socket transport module.
[    0.200508] RPC: Registered udp transport module.
[    0.200517] RPC: Registered tcp transport module.
[    0.200526] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.200541] PCI: CLS 0 bytes, default 64
[    0.203542] Initialise system trusted keyrings
[    0.203721] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.212382] FS-Cache: Netfs 'nfs' registered for caching
[    0.212864] NFS: Registering the id_resolver key type
[    0.212886] Key type id_resolver registered
[    0.212896] Key type id_legacy registered
[    0.212914] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.215114] Key type asymmetric registered
[    0.215125] Asymmetric key parser 'x509' registered
[    0.215232] bounce: pool size: 64 pages
[    0.215271] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.215429] io scheduler noop registered
[    0.215439] io scheduler deadline registered (default)
[    0.215591] io scheduler cfq registered
[    0.215602] io scheduler mq-deadline registered (default)
[    0.215612] io scheduler kyber registered
[    0.218447] brcm-pcie fd500000.pcie: could not get clock
[    0.218504] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.218540] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    0.491690] brcm-pcie fd500000.pcie: link down
[    0.494759] iproc-rng200 fe104000.rng: hwrng registered
[    0.494972] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.495472] vc-sm: Videocore shared memory driver
[    0.495857] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.505766] brd: module loaded
[    0.515237] loop: module loaded
[    0.515944] Loading iSCSI transport class v2.0-870.
[    0.517572] libphy: Fixed MDIO Bus: probed
[    0.517987] bcmgenet fd580000.genet: failed to get enet clock
[    0.518003] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    0.518020] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.518035] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.518271] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.531692] libphy: bcmgenet MII bus: probed
[    0.572193] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[    0.573048] usbcore: registered new interface driver r8152
[    0.573113] usbcore: registered new interface driver lan78xx
[    0.573165] usbcore: registered new interface driver smsc95xx
[    0.573547] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.599120] dwc_otg fe980000.usb: base=(ptrval)
[    0.799308] Core Release: 2.80a
[    0.799320] Setting default values for core params
[    0.799349] Finished setting default values for core params
[    0.999671] Using Buffer DMA mode
[    0.999681] Periodic Transfer Interrupt Enhancement - disabled
[    0.999690] Multiprocessor Interrupt Enhancement - disabled
[    0.999700] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.999715] Dedicated Tx FIFOs mode
[    0.999978] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded04000 dma = 0x00000000ded04000 len=9024
[    1.000001] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    1.000012] dwc_otg: Microframe scheduler enabled
[    1.000065] WARN::hcd_init_fiq:457: FIQ on core 1
[    1.000082] WARN::hcd_init_fiq:458: FIQ ASM at c07ae224 length 36
[    1.000099] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[    1.000133] dwc_otg fe980000.usb: DWC OTG Controller
[    1.000163] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 1
[    1.000196] dwc_otg fe980000.usb: irq 36, io mem 0x00000000
[    1.000248] Init: Port Power? op_state=1
[    1.000257] Init: Power Port (0)
[    1.000514] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.000528] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.000539] usb usb1: Product: DWC OTG Controller
[    1.000550] usb usb1: Manufacturer: Linux 4.19.58-v7l+ dwc_otg_hcd
[    1.000560] usb usb1: SerialNumber: fe980000.usb
[    1.001085] hub 1-0:1.0: USB hub found
[    1.001134] hub 1-0:1.0: 1 port detected
[    1.001744] dwc_otg: FIQ enabled
[    1.001753] dwc_otg: NAK holdoff enabled
[    1.001762] dwc_otg: FIQ split-transaction FSM enabled
[    1.001775] Module dwc_common_port init
[    1.001962] usbcore: registered new interface driver uas
[    1.002045] usbcore: registered new interface driver usb-storage
[    1.002218] mousedev: PS/2 mouse device common for all mice
[    1.003385] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.003566] bcm2835-cpufreq: min=600000 max=1500000
[    1.004141] sdhci: Secure Digital Host Controller Interface driver
[    1.004150] sdhci: Copyright(c) Pierre Ossman
[    1.004524] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.004888] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.007838] ledtrig-cpu: registered to indicate activity on CPUs
[    1.007977] hidraw: raw HID events driver (C) Jiri Kosina
[    1.008091] usbcore: registered new interface driver usbhid
[    1.008100] usbhid: USB HID core driver
[    1.008825] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    1.010426] [vc_sm_connected_init]: start
[    1.018473] [vc_sm_connected_init]: end - returning 0
[    1.019549] Initializing XFRM netlink socket
[    1.019576] NET: Registered protocol family 17
[    1.019649] Key type dns_resolver registered
[    1.020003] Registering SWP/SWPB emulation handler
[    1.020579] registered taskstats version 1
[    1.020594] Loading compiled-in X.509 certificates
[    1.028264] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.028326] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 33, base_baud = 0) is a PL011 rev2
[    1.031267] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.031812] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    1.032412] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.032424] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.058444] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[    1.076732] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.078337] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.079970] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.082858] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.084463] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.092482] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.094825] of_cfs_init
[    1.094992] of_cfs_init: OK
[    1.095639] Waiting for root device PARTUUID=95daf38a-02...
[    1.139976] random: fast init done
[    1.150098] mmc1: new high speed SDIO card at address 0001
[    1.195355] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    1.196465] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.198744]  mmcblk0: p1 p2
[    1.222958] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.222999] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.223670] devtmpfs: mounted
[    1.230145] Freeing unused kernel memory: 2048K
[    1.251912] Run /sbin/init as init process
[    1.619641] systemd[1]: System time before build time, advancing clock.
[    1.700652] NET: Registered protocol family 10
[    1.701914] Segment Routing with IPv6
[    1.735244] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.735903] systemd[1]: Detected architecture arm.
[    1.744099] systemd[1]: Set hostname to <raspberrypi>.
[    1.751689] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    2.011340] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    2.011361] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.355901] random: systemd: uninitialized urandom read (16 bytes read)
[    2.367705] random: systemd: uninitialized urandom read (16 bytes read)
[    2.368289] systemd[1]: Listening on udev Control Socket.
[    2.368710] random: systemd: uninitialized urandom read (16 bytes read)
[    2.373834] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    2.373992] systemd[1]: Reached target Swap.
[    2.375247] systemd[1]: Created slice User and Session Slice.
[    2.512918] i2c /dev entries driver
[    2.962009] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.057661] systemd-journald[108]: Received request to flush runtime journal from PID 1
[    3.566247] argon-mem feb00000.hevc-decoder: argon-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[    3.566623] argon-mem feb10000.argon-local-intc: argon-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[    3.566967] argon-mem feb20000.h264-decoder: argon-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[    3.567315] argon-mem feb30000.vp9-decoder: argon-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[    3.584191] media: Linux media interface: v0.10
[    3.609073] videodev: Linux video capture interface: v2.00
[    3.615282] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    3.617175] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    3.617189] [vc_sm_connected_init]: start
[    3.620252] [vc_sm_connected_init]: installed successfully
[    3.643264] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.644169] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.655213] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.663703] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    3.668393] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    3.668406] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    3.681516] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    3.681530] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    3.693873] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    3.693887] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    3.744361] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.763806] bcm2835_audio soc:audio: card created with 8 channels
[    3.826984] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.986404] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.008469] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    4.078548] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.089967] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.090684] usbcore: registered new interface driver brcmfmac
[    4.127427] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[    4.127527] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    4.132176] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[    4.132190] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.132199] [drm] No driver support for vblank timestamp query.
[    4.132208] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    4.314980] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.327976] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[    6.102410] random: crng init done
[    6.102424] random: 7 urandom warning(s) missed due to ratelimiting
[    6.161183] uart-pl011 fe201000.serial: no DMA platform data
[    6.244656] 8021q: 802.1Q VLAN Support v1.8
[    6.445273] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    6.548951] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.548961] brcmfmac: power management disabled
[    6.922304] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[    6.922920] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.991911] bcmgenet fd580000.genet eth0: Link is Down
[    8.533744] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   12.785901] Bluetooth: Core ver 2.22
[   12.785974] NET: Registered protocol family 31
[   12.785984] Bluetooth: HCI device and connection manager initialized
[   12.786010] Bluetooth: HCI socket layer initialized
[   12.786025] Bluetooth: L2CAP socket layer initialized
[   12.786068] Bluetooth: SCO socket layer initialized
[   12.799943] Bluetooth: HCI UART driver ver 2.3
[   12.799957] Bluetooth: HCI UART protocol H4 registered
[   12.800036] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.800262] Bluetooth: HCI UART protocol Broadcom registered
[   13.002358] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.002364] Bluetooth: BNEP filters: protocol multicast
[   13.002375] Bluetooth: BNEP socket layer initialized
[   13.098339] Bluetooth: RFCOMM TTY layer initialized
[   13.098357] Bluetooth: RFCOMM socket layer initialized
[   13.098373] Bluetooth: RFCOMM ver 1.11
sudo lsusb -v
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.19
  iManufacturer           3 Linux 4.19.58-v7l+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 fe980000.usb
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0000
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0001
  Self Powered
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.58-v7l+ #1245 SMP Fri Jul 12 17:31:45 BST 2019 armv7l GNU/Linux
